Max MPG readout
Discussion in 'Gen 2 Prius Main Forum' started by tootallrls, Nov 10, 2005.
  1. tootallrls
    tootallrls I have Prius NV
    22
    Carlisle, Pa.
    When I test drove a Prius in Sept. I was amazed to see it got almost 300mpg when slowing for a stop. I recieved my new 2005 Prius on Oct. 29th, and found the best I can do is 99.9mpg. Did Toyota make a change? My highway mpg is better than my intown mpg. Does the limits change the original mpg claims? I can get 49mpg on the highway, but I struggle to maintain that in town, even with gliding and very slow, controlled driving.
  2. maggieddd
    maggieddd Senior Member
    2,090
    Boston
    No, nothing has changed. You are probably confusing the miles driven and mpg
  3. tootallrls
    22
    Carlisle, Pa.
    Thanks, but I remember watching the mpg as I drove the car and seeing it go down to 12.8mpg the rising up as the car came over the rise in the road, and when I left off the pedal the mpg went to 286.9mpg.
  4. LaughingMan
    LaughingMan Active Member
    1,386
    Marlborough, MA
    If you test drove a standard Prius without any kind of display mod, there's no way for you to see more than 99.9. That's the highest the display goes. 300 MPG? I don't know where you saw that.
    You probably need to get used to the car before you can get higher mileages. At first it'll be easier to get higher mileages on the highway because it's fairly straightforward. Just drive it like any other car on the highway, but avoid acceleration, and you'll get close to 50s.
    In the city and surface roads, that's where you'll need to learn the proper technique, but it's also where you can get 60, 70 MPG depending on various factors.
    Do a search for pulse and glide. It's the central technique for getting high mileages on the Prius at speeds < 40 MPH.
  5. maggieddd
    2,090
    Boston
    you really must be mistaken. Trust me, maybe you were seeing extra digits? Not sure what to tell you, be nothing has changed with the Prius as far as the fuel economy.
    -or-
    Toyota made a special Prius and didn't tell us and you happen to test drive it, which I very highly doubt
  6. Maytrix
    Maytrix Member
    742
    Marlborough, Mass
    In town can be very tricky. Driving consistently at "in town" speeds would yeild you great results, but there are those few things that tend to put a damper on that - stop signs, stop lights, traffic..etc. The biggest killer is starting from a dead stop. The more you can avoid that, the better.
  7. tootallrls
    22
    Carlisle, Pa.
    Thanks all,,, not sure what I saw then,, BUT,reguardless,, I love my car and wish I could afford a second Prius as I have to share driving time with my wife..
  8. LaughingMan
    1,386
    Marlborough, MA
    I think the biggest killer is short trips, meaning 5-10 minutes. It doesn't give the system enough time to warm up and you burn gas for the whole trip.
  9. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    Curious I get mpg numbers like that on my ScanGage. I am not sure if that is how the mpg data comes from the CAN Bus having been calculate by one of the ECUs or if it derived from other information and calculated in the ScanGage.
  10. tootallrls
    22
    Carlisle, Pa.
    So, hdrygas, you've seen the high numbers too?
  11. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    Just on a separate instrument that you plug in the CAN Bus the readings are generic. The ScanGage is a generic aftermarket device. I have never seen the MFD do that 99.9 is the highest I have seen. The ScanGage displays it with more digits. I was just thinking out loud as to if the MPG data on the CAN Bus was sent with more significant digits and then displayed by the MFD as 99.9 anytime you are at that figure or above or if both the ScanGage and the MFD calculate the MPG on the spot from other data.
  12. rogerSC
    rogerSC Member
    170
    I hear that as the car breaks in, mpg will increase. I've experienced this to a small degree (I think), but still only have 1800 miles on my car. Part of the break-in is of course driver break-in...but I keep hearing stories about some point for most longer-term owners where mpg jumped some. And there's also the effect of inflating your tires to 42/40 (instead of 35/33), that added a couple of mpg for me.
    -Roger
  13. tootallrls
    22
    Carlisle, Pa.
    My wife drove the car home the day we bought it and just told me that she saw it go to 101.1mpg, but only once and not since. Happy here in Central Pa.
  14. maggieddd
    2,090
    Boston
    both you and your wife are seeing things that none of the Prius driver has ever seen
  15. tootallrls
    22
    Carlisle, Pa.
    Must be halucination then,, :D ,, The car only had 3 miles on it when we picked it up, so I know she didn't confuse it with miles driven.
  16. windstrings
    6,280
    378
    Central Texas
    Maybe, but have you ever tried to push a car by hand?... the most energy is getting the wheels moving.. once they're rolling its easier to increase.
  17. tootallrls
    22
    Carlisle, Pa.
    Makes me wonder how those people got 101 mile per gal on the test track if the readout only goes to 99.9. The way the tank fluctuates, there would be no accurate way to check mileage other than the factory guage.
