Scanguage2 question?
Discussion in 'Gen 3 Prius Main Forum' started by gqllc007, Apr 19, 2011.
  1. gqllc007
    gqllc007 New Member
    East Greenbush
    I had my scanguage 2 connected to my honda civic. Will it also connect to the 2011 Prius? Also does anyone have a picture of where is connects to on a 2011?
    Thanks
  2. jdenenberg
    jdenenberg EE Professor
    3,943
    1,940
    Trumbull, CT
    2020 Prius
    LE AWD-e
    The ScanGuage2 works on my Gen2 Prius and will also work on the Gen3 (but fewer known xguages). The connection is under and to the right of the steering column in the Gen2 and probably in a similar location in the Gen3 (just look for it as it is obvious).
    JeffD
  3. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    The ScanGauge2 will work on any car with OBDC. The connector is below the steering wheel & remember to change the mode to "hybrid" or it will turn off with the ICE.
  4. gqllc007
    gqllc007 New Member
    East Greenbush
    Ok...How do I change the mode to "hybrid??"
  5. gd540
    gd540 New Member
    Changing your SCII to hybrid mode is a very simple part of the set up. Read the instructions.
  6. gqllc007
    gqllc007 New Member
    East Greenbush
    Thanks but not very helpful. I have had my scanguage for over 3 years and do not have the instructions anymore...that is why I asked. If anyone can help it would be appreciated! Especially if it is very easy!
  7. fuzzy1
    10,474
  8. gqllc007
    gqllc007 New Member
    East Greenbush
    Thanks...I just found it and was coming back to the forum to say that! I appreciate the link!
  9. mikewithaprius
    mikewithaprius New Member
    656
    103
    Rhode Island
    You got it, for others searching later, MORE-->SETUP-->FUEL-->TYPE-->Hybrid, and be sure to hit SAVE.
  10. Dweezil
    Dweezil Cat Juggler
    162
    26
    St. Louis
    Speaking of Scanguage...what do you guys keep yours display set to monitor? I've gone through different settings, and wound up sticking with FIA, FWT, MPG, and MPH the longest.
  11. Paul58
    Paul58 Mileage Miser
    1,126
    125
    Atlanta
    I have mine set to monitor Instant MPG, Average MPG for Trip, Average MPG for Tank, and RPM (so I know when the ICE is running and when I'm on pure electric).
  12. Dweezil
    Dweezil Cat Juggler
    162
    26
    St. Louis
    Oops, you know what...I have RPMs running instead of MPH. I forgot. Yeah...I like to see when the ICE shuts down. Also like to watch the MPGs shoot up when ICE shuts down. :)
    So, it's:
    MPG (current)
    RPM
    FIA
    FWT
  13. Octane
    Octane Proud Member of 100 MPG Club
    384
    56
    The Swamp, Southern FL
    For the Prius, RPM doesn't really have much meaning to me. I prefer displaying HP. I know if the engine is on or off and how much power is coming from the ICE versus how much is being supplied by the battery. This combo works very nice for monitoring a PHEV addon.
  14. mikewithaprius
    656
    103
    Rhode Island
  15. Dweezil
    Dweezil Cat Juggler
    162
    26
    St. Louis
