Eclipse avn-726e
Discussion in 'Gen 3 Prius Audio and Electronics' started by inseek, Apr 20, 2011.
  1. inseek
    inseek Enthusiast
    142
    46
    NY
    Hello everybody,
    Just got brand new Prius Two 2011 and immediately started thinking about aftermarket HU with navigation. MY installer suggested a ECLIPSE AVN-726E which I can get for $600. This is significantly less than Kenwood DNX6960, 6980, 9960 or newest 9980. Any thoughts?
  2. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    If I remember, Eclipse is out aftermarket. They won't make or update the units anymore. That means no map update, etc...
  3. rrolff
    rrolff Prius Surgeon
    1,610
    246
    So Cal
    The Sony is in that range too - has TomTom maps. I almost swapped my Pioneer Z120BT for it (the Pioneer does poorly on BT voice calls). Glad I kept mine (nicer GUI - slightly worse GPS). It's kinda a toss up for me - since I've already got lifetime XM, and everything dialed in, I decided to tough it out...
  4. inseek
    inseek Enthusiast
    142
    46
    NY
    It is better to go with Kenwood then. Thanks for your help, guys.
  5. kormaster
    kormaster Junior Member
    92
    Playa Vista
    I have that unit for my 4runner. It is cheap but you will get annoyed with Nav software - when you click "I agree" with the disclaimer, then the map software starts to load. Doesnt matter if you were driving for 1 hr or 1 min, the software boots up when you press the NAV button and I agree. Doesnt find SAT signal and the voice prompt will say "Signal Lost" or something. SOmetimes it takes 1-3 minutes to load up. So annoying.
    Get something better if you are looking for a good Nav unit. Rest of the multimedia function works very well though.
  6. inseek
    inseek Enthusiast
    142
    46
    NY
    My old HU in my Ford SUV was Eclipse AVN7000 and the maps were available instantly after I tap "I agree"... never had a problem with signal, the unit gets my location almost instantly after I turn the navigation "On"... The main problem with AVN7000 navi was that it uses old ugly maps that you cannot update yourself - you should send the unit to Fujitsu so they can put the only available map update on it (since 2005 when the unit was produced) for a $330... I just decided not to install AVN7000 in my Prius and just get a new HU that I can update without sending it to manufacturer. I've ordered Kenwood DNX-9980HD.
  7. frodoz737
    frodoz737 Top Wrench
    4,697
    2,496
    33
    You won't regret it.
