Life Expectancy of OEM 12 Volt vs Optima(LearningAid)
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by dorf, May 9, 2009.
  1. dorf
    dorf Member
    132
    Little Rock
    I've read the prior posts on the 12 volt life expectancy but nothing posted on the Optima life expectancy.
    I'm used to purchasing a 60 month battery and then just replacing it in about 36 months.
    That seems to provide a measure of safety,of not getting stranded with a inop battery.
    I'm assuming that the OEM 12 volt should be reliable for about 36 months and the Optima should last longer, but the Optima web site claims free replacement for 36 months nothing further ????
    Anybody have actual and factual comments to share ???
  2. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    Over last weekend my dome light got left on [cause uncertain,
    not going to point fingers] bringing my Yellowtop down to about
    7V for the first deep-drain since I installed it. I hooked up my
    small UPS to the parallel Anderson connector to boot the car.
    After having the system powered up for a while the battery seems to
    have bounced right back; no perceptible diminished IG-ON voltage or
    capability seen so far. And I'm pretty aware of subtle changes
    in these areas...
    _H*
  3. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,520
    Santa Fe, NM
    *BUMP*
    Has anyone had an Optima Yellow top battery fail? This is one of the most popular, if not the most popular mod. The claim is that the Optima is a high quality deep cycle battery that can be discharged many times, while the stock Panasonic or GS battery will sulfate and die after just one visit to long term airport parking.
  4. Patrick Wong
    18,210
    6,516
    I've noticed a very few posts having to do with Optima failure.
    Further, consider the possibility that a Prius owner will allow the original equipment battery to discharge for whatever reason, such as leaving cabin lights on, etc., not realizing this is a problem.
    Then, after a new battery is installed and the owner is ~$200 poorer, s/he may be motivated to not allow the battery to discharge. To the extent that the replacement battery lasts longer, this may be due to better owner behavior and not necessarily to the characteristics of the battery itself.
  5. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    The Prius is all about Owner Obedience Training. ;)
    If we are ever forced to drive other cars, they going to get better gas mileage than with other owners, who have not been through the course.
    MizzzC likes this.
  6. mlbumiller
    mlbumiller Junior Member
    sage cali (near temecula)
    what part number for the Optima Battery?
  7. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
  8. F8L
    19,011
    4,083
    Grass Valley, CA.
    I think Patrick nailed it. Whether or not the Optima lasts longer than the OEM battery is up in the air but the Optima provides insurance against unexpected battery drains. The Optima can handle repeated drains whereas the OEM battery cannot without losing capacity.
  9. dacatz
    dacatz Junior Member
    toronto
    can anyone take a pics for me w/model number of the battery....i want to get the kit....but it will be 2 expensive just to ship to canada!
  10. Rest
    Rest Active Member
    1,210
    CA
    An Optima battery's life is like any other wet battery, some fail early and some last beyond their rating. The main selling point to an Optima is that they are not liquid filled, so they won't leak and can be mounted in any position.
  11. pachai
    pachai Junior Member
    I was just wondering if anyone has follow-up on this thread? - About 2 years ago, I replaced the battery in my 2004 which I bought used. When I got the diagnosis (from this list :), I did not have the time to do anything fancy, so I bought an original replacement.
    It's almost time to worry about a new one.
    And my kids are not interested in any more
    DVD-in-auto-parts-parking-lot instead of
    doing a real activity, so planning may help.
    Thanks
    Seth
