Will the Chevrolet Volt be a failure or a success?
Discussion in 'Chevrolet Volt' started by Reginnald, Jan 20, 2011.
  1. Corwyn
    Corwyn Energy Curmudgeon
    2,171
    659
    Maine
    I demanded the same thing for the Prius.
    $394M for Prius
    $1.5B for Volt
    Volt get 3.8 times as much.
  2. john1701a
    john1701a Prius Guru
    12,818
    5,303
    58
    Let's not forget how different the purpose was.
    Prius was already a well established vehicle at that point (2006). The purpose of the credit was to expand upon the mainstream sales rate already achieved. That's 60,000 per year prior to the tax credit.
  3. mfennell
    mfennell New Member
    241
    39
    But we already established (post after post after post) that the Volt will be an abject failure, won't it? GM will NEVER sell 250k of them, right?
    No worries.
  4. mfennell
    mfennell New Member
    241
    39
    Your ability to just make stuff up out of thin air to suport your argument is just awesome. I never tire of it.
    I stopped commuting in a supercharged sedan that returned 15mpg.
    Except for gwmort and I, who live in Delaware and NJ, respectively, even assuming that was the actual point. Maybe it is for some. *shrug*
  5. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    Don't take it personally. My statements used a comparable size cars and average emission from the grid electricity. I know you are the exception.
  6. gwmort
    gwmort Active Member
    985
    211
    Delaware
    For those who are interested in some Volt performance data:
    I had a 293 mile drive in my Volt this evening to travel from Middletown Delaware to Gettysburg PA and back. For this trip I got the following results:
    Total miles traveled - 293
    Total EV miles - 41.4 (my personal best yet)
    Fuel consumed on the trip - 6.24 gallons
    vehicle trip mileage readout - 47 mpg
    mileage in CS mode - 40.2 mpg
    Along the way I had to refuel for the first time since April 4, 2011. On the 4th I had purchased 7.6 gallons, that fuel took me 1001 miles until I refueled this evening buying 7.7 gallons
    Lifetime numbers are now:
    Total miles traveled - 1648
    Total EV miles - 927
    Total fuel consumption - 17.7 gallons
    vehicle lifetime mileage readout - 93.4 mpg
    mileage in CS mode - 40.7 mpg
    approx. electrical power consumed - 333.7 kwh (using 36 kwh/100 miles)
    cost of power consumed at local rate (11 cents) - $36.71
    cost of fuel ($4/gal) - $70.80
    combined power/fuel cost per mile - 6.5 cents
    For comparison:
    Amount of fuel a 50 mpg prius would have consumed - 32.96 gallons
    Cost of fuel prius would have consumed - $131.84
    prius cost per mile - 8 cents
    2 people like this.
  7. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    ^^ speed during the trip ?
    I cannot help but shake my head in wonder every time a Volt owner has to guess at electricity consumption. Fwiw, you probably used less electricity than estimated since your petrol consumption is better than EPA. This correlation will be true until you heat the cabin.
  8. gwmort
    985
    211
    Delaware
    Most of it was 65-75 mph, the 30 miles or so closest to Gettysburg are smaller country roads so maybe 45 mph average through that 60 miles round trip.
    Temps were back in the 40s by the time we got home. I had the climate control set to "Eco", "auto", and 70 degrees the entire trip. I also think I likely did use less electricity than estimated, but I prefer using a conservative estimate anyway.
    Overall I am very pleased with the results I have gotten so far.
  9. gwmort
    985
    211
    Delaware
    One more stat I know you guys will appreciate:
    Assuming fuel savings of 1.5 cents per mile over prius and average travel of 15,000 miles per year, the total time for fuel savings to offset $10,000 higher purchase price than Prius IV = 44.4 years :)
  10. SageBrush
    11,627
    2,533
    Southwest Colorado
    I was lazy, and figured 240 miles at 70 mph and 60 miles at 45 mph. 70 mph consumes about 33% more energy/mile than 45, so
    300 miles
    60 miles @ 70 mph
    60 miles @ 70 mph
    60 miles @ 70 mph
    60 miles @ 70 mph
    60 miles @ 45 mph
    x = fuel consumed during 45 mph run
    4x/3 = fuel consumed during each 70 mph run
    300/40 mpg = 7.5 gallons
    19x/3 = 7.5 gallons -> x = 1.184210526 gallons
    4x/3 = 1.578947368 gallons
    60/1.578947368 = 38 mpg at 70 mph. A tad better than EPA.
    :) on the payback. Honestly though, if you include winter Volt consumption and compare to a Prius II you might hit a century.
  11. Skoorbmax
    Skoorbmax Senior Member
    2,641
    265
    Western NY
    Good data!
  12. mfennell
    mfennell New Member
    241
    39
    It's the Internets. I don't take it personally. :D
    My point is that it was a false comparison. Neither of us have any idea what kind of cars are being replaced by the Volt.
  13. mfennell
    mfennell New Member
    241
    39
    My experience is that I'm destroying the EPA numbers in electrical consumption now that it's warmer (AM temps in the high 40s) and I have no need for climate control. So much so that I was questioning whether my Kill-A-Watt might be defective but I just noticed that the EPA sticker shows a full charge taking 12.9 kWh and I did 12.6 last week for a day that had left me with one mile left.
    My typical daily drive is at 35-50mph. I occasionally take a 10 mile highway trip at 68-70. There are probably 4 of those reflected in the data below.
    Anyway, I don't know how to do a table so I used the code tag to make it somewhat readable:
    Code:
    MILES       kWh        kW/100mi   mi/kWh
      42.2       12.6       29.9       3.35
      30.9        8.75      28.3       3.53
      30.2        8.5       28.1       3.55
      29.8        9.15      30.7       3.25
      40.6        11.85     29.2       3.42
    EPA says 36kWh/100mi or 2.78 mi/kWh. I'm averaging 20% better than that the past two weeks. I'm not cherry picking data, that's just what I've remembered to record. It's better than anything I see on the Leaf forum (of the few who report wall power data) but, to be fair, a lot of them live in the hilly Bay Area.
    On the other end of the spectrum, I know my wife once broke 45 kWh/100mi with an 85-90mph highway drive and I know I hit 35 at least once but I no longer have the raw data.
    To get back to gwmort's drive, any time you kill the battery (EDIT: assuming you started with a full charge and didn't do a partial charge in between), it's easy to convert back to electrical use. Just use 12.9 kWh. 41.4 miles is 31.2 kWh/100mi or 3.2 mi/kWh.
  14. SageBrush
    11,627
    2,533
    Southwest Colorado
    IF you start from a full charge.
  15. gwmort
    985
    211
    Delaware
    Thank you, I did start from a full charge in this instance.
    I can't really use that value for the lifetime numbers though because I do a lot of partial charging (usually get to work with 20 miles range left and plug in again to top off, etc..).
    To get the 1001 miles since last fill up I had to push it into the low fuel warning. It was kind of interesting, first the last blue bar in the fuel tank graph turns orange, then after 40 miles fuel range left the estimate turns to just "low", then I got the low fuel light and a message saying low fuel in the center of the display, then the nav screen changed to say I was low on fuel and would I like it to show nearby gas stations. Funny part is it was one after the other and not all at once so it was like "come on I get it I need to get fuel". I had been in mountain mode trying to save some all electric driving for my nephew to see, so I swapped back to regular and did the last 3 on electric til I got to the next gas station. Still had a good12 miles of electric range when I picked him up.
  16. gwmort
    985
    211
    Delaware
    Its tongue in cheek, but looking down the road rising fuel costs will work to the advantage of the volt in this analysis, particularly once my PV system is in and my electric costs will be more or less stable for the next 15 years (barring some huge increase in demand beyond the capacity of the system).
    At $10/gallon gas the payback period would only be 8.9 years.
    When you consider that some drivers in other countries are already close to this figure it makes the European version appear to make a lot more sense.
  17. tpfun
    tpfun New Member
    791
    Oh Never Mind,CA
    :thumb:
    Recall his average US GHG emissions from the grid excludes everyone in CA.
  18. austingreen
    austingreen Senior Member
    13,699
    4,228
    Austin, TX, USA
    Remember YMMV. The epa inflates the number they get on their tests by 30% to account for real world driving habbits, HVAC, hills, speeds, etc. It has not been well calibrated for evs. I get 16% worse than epa in my prius. Your mileage is with in. I don't think people need to be so precise and buy a kill-o-watt. A couple of runs using all ev power should allow you to guestimate your real numbers relative to the epa's 2.78 mi/kWh.
  19. mfennell
    mfennell New Member
    241
    39
    Never underestimate my level of nerd-ness. :) Note that I previously data logged ICE warm up with my scanner because I was curious how long it took.
  20. austingreen
    13,699
    4,228
    Austin, TX, USA
    Well too bad bob isn't still on the board. I wasn't criticising your nerdiness, but there was some criticism that gwmort didn't have a device to know exactly what power was being used. If you need to go to the extreme we need you to team up with a phv prius and a gen III prius, drive exactly the same route and tell us your readings. But really if its 0.38 or 0.28 kwh/mi I doubt it would change your choice.
