Metra or Scocshe?
Discussion in 'Gen 3 Prius Audio and Electronics' started by javilesi, Apr 25, 2011.
  1. javilesi
    javilesi Junior Member
    34
    earth
    For those of you out there that have done an aftermarket nav, what kit did you use? Do you like it? Have you changed it?
    Pics?!?!?
    Thanks
  2. priusito_de_mi_vida
    priusito_de_mi_vida Junior Member
    78
    Spain
    Hello, i just installed my new HU, and used the Scosche.
    I'm not fully happy with it. There is a gap between thr HU and the scosche (maybe the culpit is the HU, not only the trim plate).
  3. EdwardPrius
    EdwardPrius New Member
    TheOC
    Thanks for the picture, I am just about to buy one of these. There is a factory one too isn't there?
  4. dopey423
    dopey423 New Member
    77
    Silicon Valley, CA
  5. rrolff
    rrolff Prius Surgeon
    1,610
    246
    So Cal
  6. javilesi
    34
    earth
    This is my before and after. My Garmin on a Proclip and now a Pioneer z130 on a scosche
  7. priusito_de_mi_vida
    78
    Spain
    I have to change my opinion about the Scosche.
    The gap between trim and HU was my fault.
    I took out the radio and installed it again. Now fits almost perfectly:
  8. mainemanx
    mainemanx Member
    355
    40
    State O' Maine
    I bought both because they were like $7 apiece from Amazon at the time... I thought Scosche might be better quality... but although they take slightly different approaches to filling the space, they seemed about the same quality.
    I ended up choosing the Metra because it leaves less blank space around the edges (where the switches are on the stock, Rosen, and Fly units)... if that makes any sense....
    P.S. I must learn how to post pictures in this forum :(
  9. austingreen
    austingreen Senior Member
    13,703
    4,229
    Austin, TX, USA
    I liked the scosche kit better. Both would be better if they matched the grain, but both are fine. I originally put in a pioneer with scocshe, then it was stolen. Insurance company put in a metra, so I have had both.
  10. rrolff
    1,610
    246
    So Cal
    Here's a picture of the Metra....[​IMG]
  11. MAPGPS
    MAPGPS New Member
    Looks like the opening of Metra is larger than the standard 2DIN size (180x100mm), is it 200x100mm?
    How about Scosche? Is it 180x100mm?
  12. frodoz737
    frodoz737 Top Wrench
    4,719
    2,517
    33
    The Toyota piece is just better for me. The radio already looks aftermarket. The Metra/Scosche just made it look worse by not matching the color and texture of the dash.
