Lower Rear Window Tint
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Dweezil, Apr 26, 2011.
  1. Dweezil
    Dweezil Cat Juggler
    162
    26
    St. Louis
    Is there some kind of "trick" to tinting this window? The shop I took my car to tinted all of the other windows without issue, and didn't do the bottom rear because he said something about using the outer side of the window as a template. Since the spoiler is there, he said he can't make a good/accurate cut. Currently, the side windows are at 38%, and the upper rear is 18%. I was going to have him put 38% on the lower portion.
    I really want to get this resolved because right now, it's a little distracting to drive as I almost feel like I only have one little window to look through back there!
  2. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    The spoiler can be removed. I question your installer's competency.
  3. Dweezil
    Dweezil Cat Juggler
    162
    26
    St. Louis
    He's always done great work on all of my other cars...and the work he's done on this one is one of the best jobs he's done for me...except for that little window back there. I will look at the spoiler this evening and see what I can do. I didn't even think about trying to remove it.
  4. wernolabound
    wernolabound Junior Member
    40
    Miami, FL
    My installer had no problem making the cuts. I watched him do it. I suggested that perhaps we didn't need to do it at all. He said he thought it would be distracting if we didn't. My installer has been doing tinitng (reidential, auto, boat etc.) for 25 years though...
  5. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    Isn't the lower section of your rear window already tinted?
  6. 32kcolors
    5,683
    954
    124
    Redondo Beach, CA
    It's already tinted 29% in the glass, but it's lighter than the OP's upper hatch (with 18% tint, for an aggregate of ~13%).
  7. macmaster05
    macmaster05 Senor Member
    4,050
    730
    I didn't even bother to tint the lower batch window. It was an extra $30. Nobody can tell and you won't be able to see anything at night.
  8. Dweezil
    Dweezil Cat Juggler
    162
    26
    St. Louis
    It's a huge difference from the upper tint though. As in, you can't tell (from inside the car) that the bottom window is even tinted at all. From the outside, you can tell if you know to look. Right now, it's just distracting to drive with one bright "port hole" in the back of my car. :twitch:
  9. BtotheG
    BtotheG New Member
    34
    Los Angeles
    I didn't tint mine and you get used to it. You won't even notice in a couple weeks.
  10. firepa63
    1,761
    208
    I think the whole idea of the rear window is to be able to see through it from the inside...
  11. Mendel Leisk
    41,901
    I know they lay the film on the outside to sort out where to make make splices, synced with the heater wires. It's such a narrow strip it could be they don't even need a splice along the heater wires: just going from memory I think that glass does not have much of a compound curve (which necessitates splicing).
    I can't see them having a problem with that lower glass, with the spoiler in place. And I would not undertake taking the spoiler off (either you or them). Just can't believe it's necessary, and I've heard the spoiler has some very tricky fasteners.
    BTW, I personally do not like tinting anymore, but just my opinion.
  12. Dweezil
    Dweezil Cat Juggler
    162
    26
    St. Louis
    In response to Firepa63:
    LOL..true. However, it is quite easy to see out through both the upper and lower rear windows of my car. It's the contrast between the two that is bugging the h3LL out of me. Such is the life of an obsessive/compulsive Prius owner. :D
  13. Dweezil
    Dweezil Cat Juggler
    162
    26
    St. Louis
    Here in the hot/humid Missouri summers, tinting is almost a necessity.
    I looked at the spoiler last night, thinking that I might undertake removing it, then taking the car to the tinter. It took me all of 5 minutes to decide not to. I may just go to a different tinter and be done with it.
  14. 32kcolors
    5,683
    954
    124
    Redondo Beach, CA
    Some cars, especially convertibles, have worse rear visibility than the Prius even when blocking the lower hatch and lots of people tint their entire rear windows 5% limo tint. The OP isn't even approaching that.
  15. macmaster05
    4,050
    730
    That is what I suggest. You can also tell how skilled a tint specialist is based on how narrow of a gap they can get the film to the edge of the glass. Take a look at your back window. I'm proud to say you can hardly see a gap on mine. :)
  16. katiesdad7
    katiesdad7 Member
    172
    25
    Stuart, FL
    I have mine tinted and he had no problems. I can see thru it just fine. I like it tinted because it blocks the headlights of the people that ride my nice person.
  17. noweyout
    noweyout Trying to get used to it
    24
    SoCal - SGV
    Also had the lower window tinted on mine with no problems. No issues after tint, either.
    I also wonder if your installer just did not want to do it? I've seen bad tint jobs on other cars, for example, where they would cut around the 3rd brake light to avoid removing the back cover for a clean install. Cutting corners???
  18. Genoz World
    Genoz World ZEN-style living
    797
    22
    La Canada
    NAH, dont tint the bottom strip? Not a chance. When i had my car tinted, my tinter tried to tell me not to bother with the bottom. Once you have it done, it's epic. do it.
  19. Dweezil
    Dweezil Cat Juggler
    162
    26
    St. Louis
    Epicness has been achieved. I went to a different tinter. He completed the job in about 10 minutes with no issue for $15. It looks...well...epic. My car is now officially the shiznit. Bask in the greatness that is "The Blue Guacamole".
  20. macmaster05
    4,050
    730
    Nice but...that's probably the worst picture you could ever have to show off the lower hatch tint. ;)
