45 mpg
Discussion in 'Gen 3 Prius Fuel Economy' started by bnaccs, Apr 30, 2011.
  1. bnaccs
    bnaccs bnaccs
    191
    Colorado
    I filled up with Shell 87 octane gas and drove the first 100 miles in eco mode in the city. I turned off the eco mode after the 100 miles. My mileage has been only 45 no matter how hard I try. My car has 2,800 miles on it. It has never gotten lower than 48 in the last 5 tank fulls in just normal mode. Could it be the gas? The temp has been pretty much anywhere from 40-70.
  2. rebenson
    rebenson Member
    364
    43
    Suburb of Chicago
    Odd, unless a lot of short trips or drove differently. I would say, may have gotten bad gas. I actually will buy shell if within a few cents of other stations. I have gotten bad gas before... Since youre from colorado, the whole trip wasn't up hill by chance.... was it?
  3. bisco
    52,408
    it's colorado.
  4. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Are you on the frontrange or out in the plains? If you can see hills, then why are you using 87? Use Shell 85, the altitude makes it equivalent to 87 at sea level.
    Also, stop trying. Drive the car like normal until you learn it. Then try. Usually those that try too hard get worse mileage then those that dont.
  5. Troyroy
    Troyroy Member
    373
    30
    Troy, NY
    Is there any chance that your Ethanol % has gone up in Colorado ?
  6. bnaccs
    bnaccs bnaccs
    191
    Colorado
    I still think it is 10% ethanol. Will 85 be alright to use in the ca?. I heard it does not have as many cleaning additives. My daily commute is about 6 miles each way, and then on weekends I do longer drives around Denver and my MPGs usually go up then.
  7. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    45mpg with a 6mile drive is not bad.
    Yes 85 is fine. NOT E85. Just normal 'ol 85 petrol. If you are worried about your additives, then put a tank of VPower in every now and then. But really, it's no big deal.
    You are lower then I am in elevation being in Denver, but you are still high enough up that your 85 works like the 87 on the coasts. That's why our "premium" is 91 and not 93, 94, or even 97.
  8. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
    What mileage are you expecting and why?
  9. bnaccs
    bnaccs bnaccs
    191
    Colorado
    I have never got below 48 even in 20 degree weather. That's why the 45 seemed low. I was just wondering if it is the gas. I might try 85 octane.
  10. amorris
    amorris Junior Member
    57
    Dallas TX
    Our first tank was 48.1, and succeeding tanks were even less. We hit our valley at 43.1 after a long drive through rainy weather having to run the defroster. Then, it started going back up. Now, after 9000 miles we consistently get 50 mpg or better per tank. Don't know if warming weather, gasoline differences, or smarter driving is the reason, but I like where we are now.
    BTW, 45 mpg isn't that bad. Compare it to your last vehicle.
  11. jamesa53
    jamesa53 New Member
    74
    Indiana
    Recommended octane is 87.
  12. tonyrenier
    tonyrenier I grew up, but it's still red!
    362
    44
    Green Bay, WI
    bingo! Has that decreased?
  13. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Yes, but that is at lower elevations. He is 5000ft+ above sea level, I am 7000ft-10000ft above. They sell 85, 87, and 91 here for the 3 ranges. Not 87, 91, 93 like at lower elevations. It is known here to use 91 for cars that need 93 or above premium and 85 for cars that need 87 regular.
  14. Tomek246
    Tomek246 New Member
    New jersey
    I also gived up on the ECO mode do to the low MPGs swiched to the PWR mode, not only the car drives like a car but my MPGs have bean in 50s
  15. tiger64
    tiger64 Junior Member
    Teneessee
    I also switched from ECO but to Normal mode. My MPG increased from ~48mpg to 53-54mpg. I have only had my Priuis since March so the weather may have contributed and my driving habits have improved. I guess the next step is switch to Power Mode and see what happens.
  16. bnaccs
    bnaccs bnaccs
    191
    Colorado
    Is anybody getting in the 50 using powermode? I have only used it a few times when merging. When is it intended to be used?
  17. cwerdna
    12,545
    2,125
    SF Bay Area, CA
    It sounds like you're reporting some sort of mileage drop, despite warmer weather. Is that right?
    Is there a reason why you mention 50 mpg?
    I noticed you said your daily commute is 6 miles, each way. That's a pretty short trip and not likely to yield great mileage.
  18. bnaccs
    bnaccs bnaccs
    191
    Colorado
    Because the epa rating is 51.
  19. cwerdna
    12,545
    2,125
    SF Bay Area, CA
    Please read http://priuschat.com/forums/other-c...uth-about-epa-city-highway-mpg-estimates.html and Your Mileage Will Still Vary. Then, compare their test procedures to your driving
    Hints: They don't drive on a real road, they don't measure actual fuel consumption, their highest average speed for any of their test cycles is a mere 48.4 mph and their cold (engine) start tests are 31.2 minutes long.
    Here are results on a totally different set of tests: http://www.consumerreports.org/cro/...ce/most-fuelefficient-cars/overview/index.htm.
