Metallic Rattling Noise from inside Passenger Seat
Discussion in 'Gen 3 Prius Main Forum' started by GrumpyCabbie, Jun 7, 2010.
  1. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    Lately I've started having an intermittent metalic noise that has been bugging me. At first it occured on long runs and sounded like it could have been the brakes or something similar. It is not too loud but is continuous, rather like gently rattling your set of keys.
    It got steadily worse and I eventually tracked it down to the passenger seat. When I held the seat the metalic rattle stopped.
    Has anyone else had a similar rattle from their seats? The passenger seat I refer to is on a RHD 2010 Prius, so maybe you get a similar rattle on the drivers seat on a LHD version?
    Any solutions to this rattle or is it a new seat?
  2. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    Can you repro the basic noise with the car sitting still and
    moving bits of the seat, like shaking the seatback in various
    axes? Then you can get your head down in there and try to
    localize it. With the various brackets and springs and bits
    comprising its frame, it could be nearly anything.
    I was gonna say "clean the beer bottles out from under there"..
    _H*
  3. bedrock8x
    bedrock8x Senior Member
    1,483
    137
    If the noise only happens when the seat is not occupied, the likely culprit is the seat belt buckle is twisted and hitting on the pillar or the seat. Check to make sure the seat belt on the pillar is not twisted.
  4. hsiaolc
    hsiaolc New Member
    617
    46
    UK
    I am surprised you don't have other rattles yet. Especially you are spending so much time in the car.
    The seat belt holder rattles. The Bottom of the seat belt also makes sound because of metal to metal contact.
    The seat belt holder rattle is not a constant though mind you. It comes on and off.
    As for seats I havn't had any rattles from the seat yet. But if it does I am glad I am getting rid of my car in about a weeks time.
  5. Jolly Paul
    Jolly Paul Member
    162
    28
    Could this be related to TSB T-SB-0288-08 with the seat guide pins and floor pan location holes? If they can cause a squeak, I suppose they might also cause a rattle. The cure was to cut the guide pins off as they are only used in assembly.
  6. tumbleweed
    tumbleweed Senior Member
    4,067
    690
    Eastern Oregon
    I removed my passenger seat thinking I could have the rattle addressed by the TSB. It's pretty easy to get out and I tied down the wires and cables under the seat bottom and put some support under the black box (inertia sensor I think) on the floor under the seat. So it wasn't a complete waste of time.
    But as to the guide pins, I found that they had inserted little soft plastic sleeves over them that just fit the holes, so no rattles from them.
  7. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    The rattle sounds like a muffled jangling, say if you held you car and house keys between both your hands and shook them. The noise appears to be coming from the bottom of the back rest.
    The dealers had a look at it when it was in for the oil change (see other thread) and they checked all the cables under the seat, all the mountings etc. You can get the seat to repeat the noise momentarily by shaking it, but otherwise it occurs at about 50mph upwards. It doesn't do it when someone sits in the front.
    Dealers are looking at maybe getting a new seat under warranty.
    I'm beginning to wonder with all these rattles in the Prius that I might have one of the very first (RHD) ones made. I looked at a new one in the dealers whilst I was waiting and it seems to have much improved fit and finish compared to mine (even allowing for 20k miles of use).
    Jrlennox74 likes this.
  8. timo27
    timo27 Member
    316
    52
    Baltimore, MD
    I have had this happen, exactly, to a 'T', what GrumpyCabbie describes. It definitely is not the seat belt. (It is the RH passenger seat, front). I can occasionally get it to go away by moving the seat up and back on the rails. It is very intermittent, and yes, it is annoying. I can imagine it would be quite hard to diagnose, unless you could convince a Toyota tech to drive around endlessly while s/he sits in the back seat waitinng for you to say "See? There it is!" Good luck on that. I'd love to hear a solution (pun intended).
    ~T
  9. mhajii210
    mhajii210 New Member
    Santa Monica
    I have this exact same problem as well here in the U.S. Over a year ago my driver's seat started making the noise you described GrumpyCabbie. After going back and forth to the service department, they eventually fixed it by replacing the seat assembly. Now my passenger seat is doing this and only when the seat is vacant. When it is happening I can make the noise temporarily stop by applying slight pressure to the seat-back. The weird thing is if I slide the seat forward or back on the seat track, the noise is gone for some time. It rears its ugly head pretty quickly if I drive the car on the freeway. I had an appointment this morning with the service department, but last night my girlfriend adjusted the seat so this morning of course it didn't make any noise. I just don't understand how the noise temporarily goes away after sliding the seat forward or back. I am extremely disappointed with my Prius as I went through a big headache just to get the service department to even hear the noise back when I had a problem with the driver's seat. Now I have to go through the whole thing all over again with the passenger seat. I am 39 and I've owned / leased many vehicles over the years and I've never had any issues like this in the past. I can't believe a car with only 15k miles has already had one seat assembly replaced and now needs to have the other one replaced as well! What a joke!
  10. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    I'm sure someone more technical and more qualified than me could confirm but my understanding is that some of the early gen3 Prius had a problem with seat rattles (in addition to the many other rattles). I had my seat base replaced AND also the seat belt socket as this rattled too. Since then those rattles have now gone.
    I really could be wrong here but I think there might have been a service bulletin for both of these rattles.
    Anyhow, they were replaced under warranty.
    Hope this helps.
  11. Dark_matter_doesn't
    Dark_matter_doesn't Prius Tinkerer
    691
    151
    Seattle, WA
    Folks, the noise is coming from the adjustment handle for moving the seat forward & back. The handle vibrates from road vibrations. When you hear the noise from the passenger seat while driving, reach over & down and just touch the handle - the noise should stop.
    You can create the noise at a standstill by lightly taping on the handle with your fingers.
    My fix so far has been to wrap electrical tape between the two handle sides parallel to the front of the handle. This changes it's resonant characteristics enough to stop nearly all of the noise on a variety of road surfaces. The tape is far enough back that it doesn't interfere with using the handle for seat adjustment.
  12. mhajii210
    Santa Monica
    It does seem to be the seat adjustment handle. Did you apply the electrical tape from the left side to the right side of the handle or vice versa? I would definitely like to try this fix. I initially reported to the service rep that I believe the noise is coming from the handle but he said there was no way to tighten or adjust it.
    mhajii210
  13. Dark_matter_doesn't
    691
    151
    Seattle, WA
    Yes, I wrapped the electrical tape somewhat tightly from left to right a few turns. This changes the handle's resonant characteristics just enough. The tape isn't visible unless one looks under the seat.
  14. seesfar
    seesfar New Member
    east texas
    I generally just turn my hearing aids off, fixes most rattles.
    SFO likes this.
  15. CTpriusV
    CTpriusV Junior Member
    70
    Bristol Ct
    Your right, just took my hearing aids out(40 years of racing) and ALL the rattles go away, must be the hearing aids?;)
  16. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    My understanding is that this particular rattle is subject to a Toyota dealer service bulletin. Perhaps anyone suffering this rattle should contact their dealer to check and/or get the item fixed or replaced.
  17. Jrlennox74
    Jrlennox74 New Member
    Boston MA
    I'm having this same sound in my passenger front seat on 2013 pruis c. I've taken it to the toyota dealer 7 times already and they have dobe so many different things to stop the noise With no luck. Their next step is to replace the whole seat. Has anyone had this problem fixed for good?
  18. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    My seat base was replaced and the problem resolved.
