Stuff to put in the hatch underfloor tray
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Mendel Leisk, May 1, 2011.
  1. Mendel Leisk
    41,205
    A few ideas, to start it off:
    * Some sort of reflective triangle, or collapsible traffic cone: brightly colored and retroflective
    * First Aid Kit (one caveat on this: if you buy a made-up kit, have a look through it, make sure it's fairly complete, and you understand all the components. I'm in this boat: we got one, but I've yet to have a good look through it. Am thinking to just throw in a pack of regular bandages, for one.)
    * Wheel Chocks (In the Owner's Manual: supposed to be used on the tire kitty-corner to the flat when jacking. I've put some heavy duty ones in, but am thinking to look for an extra, light weight pair.)
    * A sturdy flat piece of wood, somewhere between 8" and 12" square (to stabilize and spread the load of the jack if you're on soft ground)
    * A couple of clean rags (Owners Manual suggests to wipe contact surface between wheel and hub when changing a tire, to avoid torquing the spare tire with some trapped grit in there. Why two: one for the real messes, one to finish)
    * Just my preference, but worthwhile I think: a compact trickle charger kit.
  2. Flaninacupboard
    Flaninacupboard Senior Member
    1,297
    213
    Midlands - UK
    4 kwh of battery pack...
  3. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Sub-woofer and amplifier. Your ideas are good too. :)
  4. Ryanpl
    Ryanpl Active Member
    780
    158
    Brooklyn, NY
    we keep some shelf stable milk, individual serve packets of PB, water, a box of matzah in case the kids need a snack while we're out and about. We also keep jumper cables.
  5. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    I have an earthquake survival kit I put together (first aid, food, water, flashlight, space blanket, cash, etc. in a backpack), a sheet for trips to the beach, and paper towels & latex gloves for roadside emergencies.
  6. sipnfuel
    sipnfuel New Member
    1,080
    174
    So. Cal.
    Some random stuff that comes in handy once in a while: Scissors, 4-In-1 Screwdriver, Rags, Zip-Ties, Extra Trash Bag(s), Gloves, Pencils (doesn't leak), Rope, Tie Downs, Bungee Cords
    I keep the scissors there so it doesn't become a projectile in a collision.
  7. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    I keep a DC air compressor in there, some bungee cords and an 8oz flask filled with bourbon... :D
  8. Mendel Leisk
    41,205
    I was thinking about jumper cables: maybe as long as you're the jumpee, not the jumper, ie: the Prius 12 volt is pretty dimunitive, might be overtaxed giving assist. I have a portable 12 volt source, toyed with the idea of putting that in there, but it's close to 20 lbs, and I start digging in my heels on the added load. Maybe in certain cirumstances.
  9. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    The output of the inverter is better than what any conventional alternator can put out if needed. I would get "smart cables". Basically polarity independent and they have a delayed connect so no sparks at the batteries (or mating posts in the Prius). I have a pair, but I don't carry them. Only thing I carry with me is a set of Alpine chains that I thankfully have not had to use yet and a AAA membership card. :)
  10. JimboPalmer
    12,470
    6,877
    Greenwood MS USA
    I have a tire wrench, auto polarity jumper cables, coat, emergency pants, first aid kit and an air compressor. then for work I have a 3/8 drill, 20 and 100 foot extension cord, power strip,56" drill bit. I also have the world's silliest umbrella.
    ThinkGeek :: Blade Runner Style LED Umbrella
  11. pakitt
    pakitt Senior Member
    2,173
    1,313
    Colorado
    In mine I have:
    - a thick blanket (mainly to avoid noise from all the other stuff that might move around when turning...)
    - triangle and first aid kit: both are compulsory in Germany (and most of EU)
    - 1.5L plastic bottle full of windshield wiper no-frost liquid
    - an elastic cable with hooks to fix stuff in the trunk by using the available rings
    - toilet paper (you never know...)
    - a foldable plastic box (handy when grocery shopping - you don't need plastic bags)
    - 2 foldable strong fabric bags (also handy when grocery shopping - no plastic bags needed)
    - 1 thermally insulated plastic bag (for stuff that need a refrigerator when grocery shopping.... ;))
  12. qbee42
    3,079
    A handful of marbles so that the dash rattle won't bother you.
  13. twittel
    twittel Senior Member
    1,605
    148
    Mt. Pleasant, SC
    Pakitt, really toilet paper? That's just too funny, but you're right...you never know. lol...
  14. Prius 06
    Prius 06 Member
    283
    29
    Ontario, Canada
    I've got my amp and a cap in there.
  15. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    I have a small tool set and a set of jumper cables so far in a tray with dividers.
  16. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    I keep a winter survival backpack for 2, in winter,a small tool set, a complete socket set,jumper cables, flashlight,electric jack ,mechanical jack (not the piece of junk that came with the car) one qt. of oil, many white clean napkins and last but not least, a fire extinguisher. Now under the seats I have....................................................
  17. sipnfuel
    sipnfuel New Member
    1,080
    174
    So. Cal.
    Thumbs up for the TP (no pun intended).
  18. Mendel Leisk
    41,205
    We also have a blanket, well: that's our "trunk tray". Good protection for the carpet, keeps the pizza warm, can keep stuff from rolling around, might save your life in a blizzard.
    Several people mention rope, string, bunjee cords. Good idea. I'm thinking a coil of twine and some box cutters or scissors.
  19. bisco
    51,781
    duct tape and plastic sheeting. (sorry, i used to work for tom ridge)
  20. macman408
    1,179
    367
    So that's where they went! And here I thought I had lost mine...
