For Honda IMA hybrid owners, is this what it takes to keep ICE off in drive through?
Discussion in 'Honda/Acura Hybrids and EVs' started by cycledrum, Apr 30, 2011.
  1. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    Is it true, to move a Honda hybrid one foot, you have to turn the engine on, or the engine will come on, then you can move?
    Better Gas Mileage in a Honda Civic Hybrid | Hybrid Cars
    "Idle versus Shutdown
    In conditions that require you to wait for longer than one minute, (e.g., line at fast food restaurant) set your parking brake and shift into neutral. Turn the key one click to turn the engine off (provided that you do not need A/C, defroster, etc.).
    If you need the fan, radio, etc., then click once to "on" again, but do not restart the engine until the line you are waiting in has moved at least a cars length.
    If you need to move forward, restart the engine. If you think that you'll remain stationary for a minute or longer, once again shut down the engine. Practice stopping-restarting, stopping-restarting in moderation."
    The above sounds like operating a conventional car. Hahhhhh, what a joke!
  2. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    "To get the auto-stop to engage, you must travel at least 10 mph and then return to a stop. If auto-stop is engaged waiting at a light, and the car ahead of you "creeps" ahead a few feet, do not follow. Stay where you are as long as possible to keep the gasoline engine from idling.
    Note: The redesigned 2006 Civic Hybrid can deactivate all cylinders and go all-electric. We are currently collecting information about the best strategies for achieving all-electric mode in the 2006 Civic Hybrid. "
    Is the above implying the latest IMA hybrids can creep through a parking lot on battery alone?
  3. blown240
    blown240 Junior Member
    53
    SoCal
    I have an 01 Insight. It is true that the engine has to be on to move at all, but you do not have to reach 10 mph for it to shut back off. I do agree that the Prius has a better hybrid system, but you cant argue with the 1st generation insight MPG.
  4. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    You can creep now, but the engine does come on then off. Before I bought my Prius I looked at a new HCH and the salesman said it was possible to move around on all electric power. However he was unable to demo that to me since the engine turned on every time. Could be a "stage" system like the Prius has where certain conditions have to be met? I frankly dont care, Honda's IMA tech is like the Flintstone-mobile and wont even bother looking until they have something to compete with HSD.
    Of course you can. I love that the 1st gen insight started them off, but nothing has changed since. It was a very small, very lightweight vehicle with no room for anything. It worked very well. Now however a gigantic beast of a car like the Prius matches its economy. Great improvement as expected over a couple years. But Honda hasn't done anything... It's so sad when Ford has a better offering than Honda. :( So backwards. I'd still buy the InsightII over a Fusion though. ;)
  5. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    It's up to the driver. Put someone who at least half-way knows how to drive an Insight & you'll be hard pressed to come close to their numbers. Some years back Meredith won our rally with 75mpg. Hobbit was closest with 60 something. The next year another Insight won with 125 mpg. For the record I did beat an Insight in my Gen2 because its driver was so be he was almost a DNF.
  6. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    I would be annoyed with IMA ICE kicking in parking lots and drive throughs, etc ... when the HSD in same situation would tract on battery power.
    My Prius was very reliable in scooting through parking lots on battery - no noise, no gas burned.
    Honda needs to get their act together for a full hybrid. I supposed they are spread awfully thin building their motorcycles, jets and making new revs of ASIMO. :D
  7. Mendel Leisk
    41,318
    Your original quote sounds like description of Forced Auto Stop. As long as the car has sufficient charge, it's going to shut down anyway, in that situation, so no need to shift to Neutral and key-off.
    The second gen Civic Hybrid cannot start rolling by electric power only. The only time it will use electric only is at moderate speeds, near-level (or down incline), with no need to speed up. And it will do that just for short durations. An ever-so-slight increase in gas pedal pressure and the gas engine will kick in again.
  8. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    Not surprising as it's not a full hybrid.
  9. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    ASIMO is f***ing awesome! When my family dragged me to Disney-Whatever in California, the only thing I wanted to see was ASIMO at the tech centre. Also had the Microsoft Smart House there, Segway rides, and other miscellaneous robotics.
    The rest of Disney sucked big time, but those are wonderful gems.
    Maybe Honda can release an army of piggy-back giving ASIMOs :D
  10. amorris
    amorris Junior Member
    57
    Dallas TX
    This is the major area where my Prius completely outshines my Insight. When in a drive through or at a stop sign with several cars ahead of me I cannot predict how well the autostop will perform. Most of the time, it does what I need, which is kill the engine when I stop and start up when I lift my foot off the brake, but sometimes the autostop will not engage, and I'm sitting still burning gas. I HATE THAT. My Prius, however, never runs the engine at all. Much, much better performance.
  11. qbee42
    3,079
    But once again we are comparing a tiny, lightweight car against a much bigger and heavier machine. I used to get great mileage in my Honda CRX, and it had zero hybrid components. It was a two seat roller skate with an engine. The first Insight was essentially a lighter version of the CRX, plus the hybrid system. I suspect HSD could do pretty well with that chassis too.
  12. Mendel Leisk
    41,318
    I've heard various iterations of this phrase. Coming from 2006 Civic Hybrid ownership, to me it seems pure semantics. I know in our first test drive of a 2010 Prius, I was impressed: driving back into the dealer's lot, had come to a full stop, then started slowly up a ramp, and noticed it was running on electric-only.
    Yes, that would not happen with a second gen civic hybrid (still remains to be seen with the 3rd gen), and it's true: the gas/electric ratio is more tipped towards gas with the Civic, due to it's smaller battery pack.
    So, does this make it less than "full", maybe "half", LOL.
  13. blown240
    53
    SoCal
    The best I have ever done in my insight was from Moreno Valley, Ca to Huntington Beach, Ca. I was trying VERY hard to use as little gas as possible and was able to average 106mpg. Thats about 60 miles.
  14. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    They seem to be quite a bit less than fond of the Prius over at insightcentral.net ...
    In just a few posts, the Prius was referred to as 'giant golf cart' and 'moon mobile'.
    They seem to like the fact IMA will idle while in a parking lot and don't get why it's so cool to creep around on battery.
    Tell ya what, if I bought a 'hybrid' and it would idle when -
    * creeping around parking lot
    * waiting at metering light
    * going through drive through lane
    * pulling into garage
    * stuck on 2 lane road in gridlock
    * etc, etc, etc ....
    ... I would be sorta pissed.
    On honda's website, they hinted that Insight II could tract on battery power under certain conditions. I doubt it can move itself 3 feet forward without the gas engine kicking on.
  15. PriusSport
    PriusSport senior member
    1,498
    88
    SE PA
    We have an '08 Prius and a '10 Insight. The biggest differences: the Insight was $5K cheaper, it gets about 10% less gas mileage (low 40s)and is slightly smaller inside--mainly due to the center console, which my Prius II doesn't have.
    If I could have bought the Insight for $5K cheaper when I bought the Prius, I probably would have bought the Insight. The series vs parallel electrical configuration is of secondary importance to me. The bottom line is value.
    Pay no attention to the junk floating around the media about either car.
    That's your oil lobby at work.
  16. UsedToLoveCars
    UsedToLoveCars Active Member
    448
    102
    I thought they did something where they open up the engine valves so the engine could spin freely, and thus allowing the car to move on electric only, despite the electric motor being glued to the crankshaft...
    Or was this a prototype?
  17. UsedToLoveCars
    448
    102
  18. Southern Dad
    Southern Dad Active Member
    350
    212
    58
    Monroe, GA
    I'm new to the forum but I've been driving a 2000 Honda Insight MT since February. My autostop engages any time I am slowing when I go below 20 mph. If I want to start the engine, I shift into first. If I want the engine off, I shift into neutral. I don't have to get up to 10 mph between shut offs.
    For example if I am in line at a fast food drive thru... Each time I want to move, I shift into first move forward and then shift back to neutral. My engine is only running when I am moving forward.
    Actually, besides the backseat the ability to move on electric only is one of the reasons that I am considering adding a Prius to my vehicles.
  19. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    But you can't even do that with an Insight II or civic hybrid... The manual Insight I was and still is great. And with tricks like this, you can get better mpg's than a Prius (albeit with a much smaller vehicle). But these tricks don't carry forwards to other Honda hybrids.
  20. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    Yep, I had to laugh.
    As a result of learning about Hybrids and hanging around Prius Chat, that's almost exactly the same thing I do with my Non-Hybrid Honda Fit in that situation.
    So basically they are saying...You want the Honda Hybrid to "idle" without the engine running...turn off the engine...
    Wow...cutting edge stuff there...HSD beware....
