Lost Audio
Discussion in 'Generation 1 Prius Discussion' started by clayte, Apr 29, 2011.
  1. clayte
    clayte Junior Member
    alton il
    I have a 2003 prius, lost audio, radio seems to be tuning the stations ok, just getting no sound. Wondered if anyone else has experianced this problem and what the fix was.:mad:
  2. mlibanio
    mlibanio Member
    304
    61
    Toronto
    2002 Prius
    I
    I had this exact same problem last year. Toyota said I needed a new radio. I got home and I unplugged the battery for half an hour. I am not sure what prompted me to do that. I plugged it in again and it worked, and has been fine for a year now, even working 24h on a drive from Toronto to Florida. Try this first before replacing the radio. I am not quite sure what the problem was, stuck relay, but I pray it works in your case.
  3. clayte
    alton il
    :(I tried the, disconnect 12 volt battery, but didn't restore audio, will start shopping for a new radio.
  4. clayte
    alton il
    Radio magically started working again after about 30 days, I don't know why, or why it quit working unless a relay somewhere was stuck and finally reset, but radio works fine now. Glad I didn't order a replacement. I was using a portable for about 3 weeks, then 1 day I tried the car radio and it was working again.
  5. tonyrenier
    tonyrenier I grew up, but it's still red!
    362
    44
    Green Bay, WI
    I know my Prius is a different generation, but two years ago when temps started to drop, I lost my audio as well. Dealer spent half a day on it with no luck. I told them that I would check my schedule the following Monday to set up a full day for them to look at it. That Sunday it started working again and has not failed since.
    Very weird.
  6. Patrick Wong
    18,210
    6,511
    Most likely, an intermittent solder connection; so don't be surprised if the radio stops working. Often an intermittent problem may be seasonal - will go away in hot weather and reappear in cold.
  7. pjdel51
    pjdel51 Junior Member
    Malvern, PA
    2003 Prius
    Hi all,
    I have a 2003 Prius. For some time the audio system would periodically lose all power - nothing would work - no AM, FM, CD or Tape. They simply wouldn't power on. If you pushed the "Audio" button, the screen would read "Audio System Turned Off." (Or something to that effect.) Then, after driving for a period of time - 5-20 minutes, during which time there might occasionally be a short click in the speakers - as if the power were trying to come on - they would power on. This usually happened on very humid or rainy days.
    For the last 2 weeks there has been nothing. I checked all fuses I could find today. Everything seems good. All other systems seem to be working fine. The CD player has power. All the buttons for the individual disks light up. I can get the Audio display to tell me that it's trying to play disk 1 or something, but the buttons controlling the audio system don't allow the signal to play sound. I tried disconnecting the battery for about 2 hours and reconnecting. Didn't do a thing.
    Any ideas?
    Thanks, Peter
