Drinking AC Condensate
Discussion in 'Fred's House of Pancakes' started by edthefox5, May 1, 2011.
  1. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    52,187
    would this work with the car a/c?
  3. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    AC units are typically full of all sorts of nasty mould, but if the water is properly filtered and aerated, it should be fine.
  4. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    I would rather drink a nice cold beer, if given a choice!!!
  5. J5A
    J5A Active Member
    592
    83
    Severna Park, MD
    Our condensate line poking out from our FL home had a slow drip.............drip..............drip, etc...
    I can't imagine GALLONS available daily.
    Maybe beneficial to someone who ran their a/c at 60 all day/night..and kept their windows open?
  6. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Living in a semi-arid desert I get no condensate even when turning down the portable-AC unit to 60F. The house's AC is usually around 72F and I never see anything dripping.
  7. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    The nasty stuff in the air gets absorbed by the moisture forming on the AC evaporator coils. It would be like drinking your farts and whatever else was contaminating the air.in your car.:eek:
    And as someone else said, mold that forms in the moisture in the AC.
    +, you don't get a lot of condensate unless you live in a humid area, and humid areas aren't usually the ones with water shortages. There are exceptions, but more often than not, places with low humidity climates are the ones with water shortages.
  8. ETP
    2,802
    1,170
    Auburdale FL
    Isn't this the way they make hard 90 proof in a still!:D
  9. Skoorbmax
    Skoorbmax Senior Member
    2,641
    265
    Western NY
    $3500 to grab that seems unbelievably expensive.
  10. qbee42
    3,079
    That includes the cost of the AC system. You don't want to drink water from any old AC condenser; they weren't designed for producing potable water. The one described here includes a special coated condenser unit, plus filtering.
    It wouldn't work for me, since we don't have air conditioning. Maybe with global warming we will eventually need it, but not so much for now. On the other hand, water is one thing we have in spades.
  11. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    Here, too. No AC, either, although the unit in the car sees infrequent use.
    But, I wonder if this 'water from air' idea might work for dry coastal areas. How feasible would it be to extract water from a moist onshore breeze?
  12. qbee42
    3,079
    It's called "dew harvesting". Here is one of many links:
    Dew Harvesting
  13. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    Oh, look at that. Thank you. I love it when I invent something and then there it is. :rolleyes:
  14. Dusty Chips
    Dusty Chips New Member
    85
    Laughlin NV
    I like mine with a twist...
  15. FL_Prius_Driver
    FL_Prius_Driver Senior Member
    4,319
    1,527
    Tampa Bay
    I
    That what comes from the insides of the coils, not the outside.
