rt turn-car goes into neutral
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by malibucarl, May 3, 2011.
  1. malibucarl
    malibucarl Member
    237
    Malibu, Ca
    Yesterday in 3 separate 90 deg RT turns the car went into neutral. Was able to shift normally back into Drive. Many other right turns normal.
    First time it happened, we bought it new in 2007.
    The actual shift nob "sticks" when shifting into Brake. returns about halfway otherwise everything normal.
    Any help appreciated.
    Thanx,
    Carl
  2. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,512
    Santa Fe, NM
    Sounds like you need to replace the shifter assembly. When turning right, the knob would have a tendency to move towards neutral if the return spring is weak or broken.
  3. northwichita
    481
    102
    29
    Wichita KS
  4. malibucarl
    malibucarl Member
    237
    Malibu, Ca
    Thanx northwichita. I'm sure that's the problem. After some experimenting I found that the lever was not coming fully back so bumps or force could activate the Neutral "gear".
    I now have my own stick shift Prius until time for the mod.
    Carl
