First road trip tomorrow
Discussion in 'Gen 3 Prius Fuel Economy' started by MSB87, May 4, 2011.
  1. MSB87
    MSB87 Junior Member
    40
    Phoenix
    So first trip is tomorrow, Phx to Disneyland. Any advice on the best way to handle the climbing portions of the trip? Keep it in the econ portion of the bar? Just floor it up the hill? Should I use the b mode while going down or just glide down? So many options. I'm just looking for the best mix of mileage and performance. Thanks in advance.
  2. Saphteemon
    Saphteemon Junior Member
    36
    Orange County
    Relax and use the cruise!
  3. DetPrius
    DetPrius Active Member
    545
    92
    Southeast Michigan
    I agree with Saph - set the cruise at the speed limit, stay out of the fast lane, and enjoy the scenery! It won't net you the best mileage but for the first trip, enjoy the ride.
  4. mikewithaprius
    mikewithaprius New Member
    656
    103
    Rhode Island
    You can use B mode if you'll be braking a lot on a long mountain downhill, for the friction brakes' sake. If you see the battery is about full and you're on a long downhill with more regen braking ahead, use that A/C for your hot southern weather, you're getting it "for free".
  5. MSB87
    MSB87 Junior Member
    40
    Phoenix
    Made it! Set cruise to the speed limit and then glided on most down slopes. 49.5 MPG on the screen. For what I have calculated manually that is 48 for my car; nice. BTW - What is the max number of bars on the SOC? Does the top ever get a bar?
  6. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    Sounds like you weren't going slowly.
  7. fuzzy1
    10,603
    Max is 8 bars. To top out, you generally need to regenerate down a hill that is long and steep enough. In ordinary circumstances it should never top out on level ground, as it keeps some headroom in reserve for those mountain descents.
  8. MSB87
    MSB87 Junior Member
    40
    Phoenix
    Nope 75 in AZ and then 70 in CA.
  9. MSB87
    MSB87 Junior Member
    40
    Phoenix
    OK so I did see it full then. It was on the long downhill into the Indio area.
  10. MSB87
    MSB87 Junior Member
    40
    Phoenix
    It is done! Round trip from Phx to Disneyland...50.9 on the screen. Calculated was 49.5. I did the speed limit on all the highways and used the cruise when there was space. Thanks for the input...love this car.
  11. LulzChicken
    LulzChicken Prius Enthusiast
    791
    135
    Alabama
    Thanks for the report! I'm glad to see you were near 50!
  12. Gurple42
    Gurple42 New Member
    354
    Santa Monica, Ca.
    Did almost the same trip a week ago, also cruise control and set to speed limits. Santa Monica to Phoenix and back 50.8 Round trip on the screen. I guess we drive the same.....
