Need help removing rear seat..
Discussion in 'Gen 3 Prius Audio and Electronics' started by banshee08, Sep 27, 2009.
  1. banshee08
    banshee08 Member
    284
    72
    El Monte, CA USA
    Anyone know how to remove the rear seat bottom cushion? I am working on sound deadening and only have the floor and rear seat left and was wondering how the heck to get the rear seat off.
    Anyone install leather covers that has taken removed the rear seat cushion??
    Thanks in advance,
    Chan
  2. radioprius1
    radioprius1 Climate Conspirisist
    1,355
    155
    Iceland
    Hi Chan,
    Just push your front seats forward to get a lot of room in the back, then reach on the bottom of the rear seat and pull upward with a lot of force. The seat will come off. It's just held in by a couple of clips.
  3. Boo
    Boo Boola Boola Member
    5,051
    488
    97
    Flushing, NY
    That's just like the Gen II's rear seat bottom. Good to know.
  4. banshee08
    banshee08 Member
    284
    72
    El Monte, CA USA
    Will give this a try next weekend. I need to let my back rest for a week before attempting that again. Wow, I remember sound deadening a much easier job when I was younger.
    Thanks again,
    Chan
  5. Boo
    5,051
    488
    97
    Flushing, NY
    If it's just like the Gen II, in the front there's a hook on the left and a hook on the right which you unhook by lifting the seat up from the center with your left arm on the left and your right arm on the right of the center hump.
    Once you lift the front up you should be able to see another hook or hooks in the back.
    Here are the Gen II Seat Assembly Instructions. Page 15 illustrates and describes how to remove the rear seat cushion:
    [​IMG] SE%20-%20Seat.pdf
  6. rrolff
    rrolff Prius Surgeon
    1,610
    246
    So Cal
    This is a great doc, as I have my Katzkins, and my hog clipper......
    Can anyone confirm this also applies to the 2010 model (for seats)??????
  7. blisspacket
    blisspacket Junior Member
    32
    StAugustine FL
    Yes, that doc applies to the 2010. It takes an inordinate amount of muscle to pull those steel loops in the seat bottom loose from their plastic sockets in the chassis. I wound up using nailpulling bars and broad tip screwdrivers for the pass. side. Drivers side came up readily enough. Just a bit of wiggling gets the back hooks loose from their frame.
  8. PaJa
    PaJa Senior member
    678
    114
    92
    Czech republic
    Find hooks on each side, use both hands very close to hook and lift up. The metal wire frame has a tendency to go off from cushion, so using both hands is essential.
  9. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Just curious, for those that have removed the rear seat... is there enough room under there for say a 3" high, 8"x12" amplifier?
  10. frodoz737
    frodoz737 Top Wrench
    4,693
    2,493
    33
  11. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
  12. frodoz737
    4,693
    2,493
    33
  13. Musicfan145
    Musicfan145 Junior Member
    24
    Decatur, GA
    This made me wonder if all the juice being the traction battery could cause noise or interference with a line-level audio component. It's normally advised not to route analog signal or digital data cables too closely to normal everyday power wires (12v DC or 120v AC), so I wonder how much electromagnetic nastiness might be coming out of that high voltage traction battery & wiring.
    Perhaps you can wrap the amp in some kind of combination heat sink/EMF shield and solve both problems! :D
  14. Musicfan145
    24
    Decatur, GA
    Hey Spiderman,
    I just took my back seat out today to run signal wires for my sub, and on mine, the seat is solid foam all the way to the bottom. There is really no cavity to tuck an amp into, even if it didn't need ventilation.
  15. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Thanks for checking on that! Guess I will leave the amp in the tote in the rear.
  16. blisspacket
    32
    StAugustine FL
    nope.
  17. MortenAZ
    MortenAZ Junior Member
    26
    Phoenix AZ
    I need some guidance as well. The directions I've found so far are not working.
  18. doncantwell
    doncantwell Junior Member
    St James, NY
    Gen 4 rear seat - is it removed the same way?
  19. Mendel Leisk
    41,352
    I think so. The PriusChat team at the Las Vegas reveal managed to pull the rear seat up while looking a car over, lol.
