Dash-mount GPS - adhesive disc question
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by TheBlueWedge, May 5, 2011.
  1. TheBlueWedge
    TheBlueWedge New Member
    49
    USA - Vermont
    Hi everyone,
    I have a Garmin GPS unit that I would like to mount on the dash of my 2010 II. I've noticed that the dash is pretty susceptible to scuffs and whatnot, so I'm a bit worried about using the adhesive disk that came with the GPS unit (one of these guys: link). Does anyone know if it will leave any residue or marks down the road?
    I know there are the bean bag type mounting solutions but I'd rather not shell out the cash if I can avoid it.
    Thanks for any thoughts!
  2. VoicesInMyHead
    VoicesInMyHead New Member
    52
    Georgia, US
    I don't have anything to offer up as far as advice for the adhesive disc, but my preference (albeit slightly costly approach) is to use the custom-made mounts from ProClips. I have the one that attaches to the center air vent, and it is fantastic. Within reach, but not in the way and no permanent changes.
  3. tomlouie
    tomlouie Member
    118
    Boston, MA, USA
    2023 Prius
    I also use the ProClip mount. Very sturdy, beats having to fight the suction cup.
    Best of all, if you install the ProClip without the adhesive, you can remove it afterwards if you change your mind. Ours stays put even without the adhesive.
  4. Troyroy
    Troyroy Member
    373
    30
    Troy, NY
    Using the adhesive disc tells a possible thief that you have a GPS......and it could be inside of the car......I have heard stories where even the smudge that the windshield mounts leave will tell the thief that you have a GPS. Go with the dashboard sandbag, when you remove your GPS.......throw the sandbag on the floor our under a seat....
    Even if you remove your GPS......the thief sees that you have a GPS mount...he will think that it's in your console....or glovebox.....don't give them a reason to break into your car. !!!
  5. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    If you use the adhesive disk, just figure it will still be in the car when you trade/sell it. They are pretty hard to remove, for good reason. I use it on my Highlander Hybrid and it works great. Just make sure you determine exactly where you want to place it before sticking it to the dash. There are no do-overs.
  6. viclavigne
    viclavigne New Member
    76
    Georgia
    I know the OP didn't want a bean bag, but I have found that for portable GPS, that is the real bomb. Reposition as needed for driver or navigator, reangle the GPS to get the glare of the sun off it, and best of all, no tell-tale evidence for a would-be thief to know that you have a GPS in the car. As a bonus, a bean-bag/portable GPS makes a great combination to move to another car if you need to.
    Vic
  7. TheBlueWedge
    49
    USA - Vermont
    Thanks for all the replies. Since I'm on a lease it seems like biting the bullet and picking up the beanbag thing is indeed the best option... luckily they're only 20 bucks (cheaper than I thought). Thanks very much again for all the replies.
  8. jb72
    jb72 Junior Member
    Ohio
    If clipping the GPS (or iPhone) to the vent, isn't there a problem with the hot (or cold) air, from the vent, hitting the electronic instrument?
  9. sipnfuel
    sipnfuel New Member
    1,080
    174
    So. Cal.
    I have a couple extra bean bag style GPS mounts, unopened, if anyone is interested.
  10. lenjack
    lenjack Active Member
    804
    114
    Pennsylvania USA
    Bean bag mount is the ultimate...solves all the problems.
  11. TheBlueWedge
    49
    USA - Vermont
    Yep, I ended up picking one up for 18 bucks. It does indeed solve all the problems. Now I need to find some clips to attach the GPS wire under the steering wheel so I can have the unit on the left side of the dash...
  12. twittel
    twittel Senior Member
    1,605
    148
    Mt. Pleasant, SC
    I have a TomTom putting their self-adhesive holder on top of the flip up drink holder lid. When I'm out of the car and not using the GPS, I flip up the drink holder lid, so no one can tell that I have a GPS mount. I connect my GPS inside the sliding console, so very little wire shows while I'm using it. When not using the GPS, I store it inside the sliding console on top of the small flip up tray.
  13. tonyrenier
    tonyrenier I grew up, but it's still red!
    362
    44
    Green Bay, WI
    That's what I do. Sandbag works in various cars with any expanse of flat dash, and has never moved on me even without the adhesive anchor.
  14. stevemcelroy
    stevemcelroy Active Member
    873
    194
    Boulder, CO
    This is the one that I use from Overstock - I paid under $10 for mine though. I have a 2009 and it fits well on the hump over the MFD and I also got one for my Dad who has a 2010 and it works well on that dash as well.
  15. VoicesInMyHead
    52
    Georgia, US
    Yes, it does partially block one of the vents. But, it doesn't seem to affect the device at all and I haven't noticed any appreciable change in comfort.
  16. ETC(SS)
    7,302
    The GPS receiver is fairly sturdy thermodynamically speaking. They have to be, as car interiors can get pretty dang hot when the consumer leaves the unit plugged in after leaving the car. The cold air from the vent won't bother the unit at all.
    IIRC, Garmins have a protective thermal shut down. Garmin wanna-be's probably do as well.
    You don't want to live on that feature. It's best to shut down the unit for reasons of security as well as longevity when you leave the car, but you don't really have to worry about that either. Priuses don't have retained power to their 12-V accessory plugs after you leave the car, presuming that you usually shut your car off before you leave it, and most units do the auto shut down thing by default once primary power is removed (to prevent the user from leaving it energized in a car after they walk away from it would be my guess…)
    I don't recall what the operating temp range is for my GPS---and it's usually a SWAG anyway, but 0-120 degrees (F) is fairly typical.
    I don't think you'll see temperatures exceeding this range from your HVAC system for extended periods at all.
    Short answer: Don't worry about it. :cool:
  17. walter Lee
    1,126
    376
    Maryland
    Adhesive backing on the 3M velcro cannot not hold onto the textured surface of the 2010 Prius III dashboard so I took a big metal clip paper binder and clipped it onto the HSI sun visor part of the dashboard. I removed the two metal tongs to the paper binder and then attached some velcro to the smooth top side of the paper binder. I attach the other velcro to my scangauge II and I mount the scangauge II over my hsi display. My Garmin Nuvi GPS is mounted via a windshield suction cup over the scangauge II.
  18. cappyb
    cappyb New Member
    Bossier City
    Hi all. I have a found a solution to this that I really love. Motor Trend makes a "Dash Pad" and I got mine at an Advance Auto store. It basically is a flat rubber pad that lays atop of your dash with the shiny disc in the center to mount your GPS suction mount to. The part number is MT-GPDP. Be sure and take the part number with you b/c the guy I asked told me they didn't have it until he entered the part number. I believe this is the perfect solution as it does not slide, and you can easily pick it up and stash it when not in use. I can place precisely where I want it so that the cord hangs down just to the left of my glove box. It's a tad cashy at 29.99 but I must say it was money well spent.
