Parking brake pedal cover keeps coming offs...
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by chris1964, May 9, 2011.
  1. chris1964
    chris1964 Junior Member
    San Diego
    It seems about once a week the rubber cover that goes over the food pedal for the parking brake comes off. I've been careful to replace it correctly but it still keeps happening? Anyone else have this issue? Btw it's a 2010 v with atp
  2. Corwyn
    Corwyn Energy Curmudgeon
    2,171
    659
    Maine
    Perhaps a bit of shoe-goo would help.
  3. Yiannifun
    Yiannifun New Member
    Athens, Greece
    I dont have a prius yet, but for my hiundai scoop (back in 90') super glue in the rubber slot and correct replacement worked!!
    And you can still remove it if needed, but i dont think you will need to remove it again anyway!
  4. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    Have the dealer replace it under warranty.
  5. mightyyam
    mightyyam New Member
    Austin
    I had the same problem. I had it repaired (reattached with glue) under warranty while I was at the dealership for an oil change.
  6. scottalan
    scottalan New Member
    30
    Omaha
    I had the same problem with my 2010 II. It was replaced under warranty. I think the original one had a small tear in one of the corners so it did not fit tight enough to stay on.
  7. mrajdstp
    mrajdstp Junior Member
    25
    St Paul, MN
    If you want a do-it-yourself solution, I'd use clear hot glue. I've found it very useful for a variety of interior automotive fixes. With some heat applied, can be removed in the future without damaging the surrounding parts.
  8. Whiteyprius
    Whiteyprius Active Member
    389
    105
    North Carolina, USA
    Easy fix. Get one of those self-locking bands, one that's about 8 inches long. Loop it vertically around the middle of the pedal, pull tight & cut off access. Mine fell off over 100,000 miles ago (on my '08), and this has worked perfectly ever since.
  9. chris1964
    San Diego
    Wow that happens to me all the time as well on my 2010 v. Had the dealer 'fix' it under warranty and the fix lasted about a day :(. Guess I will try gluing it
  10. hlunde
    hlunde Member
    419
    75
    I noticed that shoes with knobby soles tended to catch the pedal cover and pull it off. But, glue works.
