Battery life in the winter
Discussion in 'Newbie Forum' started by Behindblueii, May 10, 2011.
  1. Behindblueii
    Behindblueii New Member
    Lyndhurst, NJ
    Ok I just heard that some prius were experiencing battery issues in the winter... I live in Lyndhurst NJ and have a 2011 Prius IV .... should I be concerned?
  2. Michgal007
    Michgal007 Senior Member
    1,321
    98
    Macon, GA
    Which battery? 12V? I have had no issues in the Midwest. I have even left the car for weeks in frigid temperatures and nothing happened.
  3. john1701a
    john1701a Prius Guru
    12,833
    5,310
    58
    Be aware of source, since there are some intentionally spreading misconceptions... especially now that gas prices are getting high.
    I certainly haven't had any trouble over the previous 11 years driving Prius in the winter in Minnesota...
  4. Behindblueii
    Lyndhurst, NJ
    This is true... Haters!!! Lol how does it handle in the snow?.... I traded in an fj cruiser that was amazing in snow.
  5. Zythryn
    Zythryn Senior Member
    6,408
    4,407
    The oem tires are poor.
    We got snow tires for one and a good set of all-season tires for the other. Both performed very well for us in Minnesota.
    PS Have had no issues with the battery in either car (except one that we didn't start for ~4 months).
  6. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    No problems with either battery up here (AK). Use studded snow tires in the winter... highly recommended. The Prius does just as good as any other front wheel drive car I have ever driven in.
  7. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    Every so often our Prius show us what we don't know. The 12 volt battery in the Prius tends to last about 4 years, and this is true in most every other car as well, no surprise. But the 12 volt battery in the Prius does not run a starter, do you know another way to predict upcoming failure other than that slow starter sound?
    A Prius owner can be blindsided by a dead 12 volt battery through not recognizing symptoms. If your Power Windows are much slower in Accessory than in Ready, if your Radio Presets or trip odometers forget what they were set at, if your Prius seems to run at stop signs/lights more than it used to, suspect and test the 12 volt battery.
    http://priuschat.com/forums/gen-ii-...y-check-without-switching-headlights-off.html
    2 people like this.
  8. Mendel Leisk
    41,921
    To add to the chorus: which battery?
  9. car78412
    car78412 Member
    284
    32
    Hudson Valley, NY
    Those are great pictures. Thanks for sharing!
  10. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
    Yep and the other question is: source? If it's a person, do they even own a Prius?
  11. F8L
    19,011
    4,083
    Grass Valley, CA.
    John, that 3rd picture is awesome!
