2004 Prius Red Triangle still after changing 12V
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by atc789, May 11, 2011.
  1. atc789
    atc789 New Member
    Ontario CANADA
    Hi everyone,
    I have a 2004 Prius, the Red triangle came on intermittently and went off so I changed the 12V battery last night, after changing it the red warning light went off and everything seemed okay. Today while driving, the warning light came back on. I checked the battery voltage via diagnostic mode on the cars computer and the specs are what they should be. I noticed the following error codes in the computer:
    01-D5, Sub-code: 190-30-8
    01-DC, Sub-code: 190-B7-8
    01-DC, Sub-code: 1C6-4D-F
    Not sure if these are what is causing the problem, but thought I would post them.
    Any ideas what the problem could be?
    Thanks
  2. dogfriend
    7,512
    1,191
    Carmichael, CA
    01-D5 is a registration error in the AV-LAN (Audio Visual Local Area Network)
    01-DC is a communication error in the AV-LAN. The subcodes are clues to which components on the network are having the problem.
    I think these codes are AV diagnostic codes read from the MFD.
    I don't know if this is the source of the Red Triangle. I think you need to read the codes from the Data Link Connector to see if you have any Powertrain codes or other codes with a Toyota scan tool or equivalent.
  3. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,520
    Santa Fe, NM
    Pop the hood while in Ig On or Ready and see if the inverter coolant pump is running. That would be a typical cause of getting the red triangle after driving for a while, and having 12V battery problems. This would be trouble code P0A93. Otherwise, get the codes read with a scan tool. It cannot be done from the MFD.
