Ev/Eco/Pwr/Normal gives 6 modes, not 4!
Discussion in 'Gen 3 Prius Main Forum' started by tomlouie, May 14, 2011.
  1. tomlouie
    tomlouie Member
    118
    Boston, MA, USA
    2023 Prius
    I've noticed that almost every description of the GenIII modes treats EV mode as if it was another exclusive mode like the way Normal, Eco and Pwr are exclusive modes. Ie: if you're in Eco, you're not in Pwr nor Normal.
    But EV is a toggle mode that's independent from Normal/Eco/Pwr, meaning you can have:
    1. Normal
    2. Eco
    3. Pwr
    4. Normal+EV
    5. Eco+EV
    6. Pwr+EV
    Admittedly, I don't notice that big a difference among the last 3 in terms of performance or FE, so one could argue that modes 4,5,6 are effectively just "one" EV mode.
    Anyone notice a significant different?
  2. Tideland Prius
    16,665
    If I'm not mistaken, if you activate EV Drive mode in PWR mode, it'll cancel PWR Mode (and go to the normal setup)
  3. tomlouie
    tomlouie Member
    118
    Boston, MA, USA
    2023 Prius
    I just sat in my running 2010 GenIII (but still in P) and took these 6 photos of each mode.
  4. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    I've noticed that, but it's not like you can go fast in EV so that's moot.
  5. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    When you say you "don't notice that big a difference among the last 3 in terms of performance or FE" what difference exactly did you notice?
    I don't think there's any difference in your 4 - 6 above, vs. 1 - 3. When you enable EV mode, it's in EV mode until the system goes outside the parameters for EV mode, and it then goes back to whatever mode it was in before. And EV mode is the same regardless of what mode the car was in prior to EV being enabled.
  6. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    Is A/C less aggressive in Eco+EV vs. Normal+EV?
  7. RRxing
    RRxing Senior Member
    2,561
    1,837
    NEPA
    It won't matter what mode you're in if you don't get gas soon... :D
  8. tomlouie
    tomlouie Member
    118
    Boston, MA, USA
    2023 Prius
    I haven't looked for an A/C diff, but I can look at the A/C power draw with my SCII the next chance I get.
    Eco+EV compared to Normal+EV seems to have a mushier throttle, and Pwr+EV compared to Normal+EV feels like it has a snappier throttle. Since you want to avoid too high an acceleration rate in order to stay in EV mode, then being in Eco+EV makes more sense than Normal+EV or Pwr+EV.
    And yeah, I gassed up later that evening. :)
  9. qbee42
    3,081
    Don't forget Reverse and B mode. Factor those in and you can get 18 modes. We should probably also count Off mode, Neutral mode, and Park mode. Now I've lost count.
  10. airgas1998
    airgas1998 New Member
    78
    iowa
  11. Dweezil
    Dweezil Cat Juggler
    162
    26
    St. Louis
  12. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    Don't forget the Sikes mode!
    2 people like this.
  13. dustoff003
    1,371
    335
    Waianae, HI (Oahu)
    Wouldn't EV mode trump whatever other mode is selected/illuminated rendering it ineffective as long as you were in EV mode?
    Posted from my iPhone via the Tapatalk app.
  14. stream
    2,977
    452
    Long Island, NY
    Agreed. See post #5.
  15. johalareewi
    johalareewi Member
    393
    44
    uk
    But see post #8.
    I have had a play and you still get the different accelerator mappings when in EV+ECO or EV+PWR mode.
  16. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    And then you can have any of the 18 modes with or without pie a la
  17. jamesa53
    jamesa53 New Member
    74
    Indiana
    Aahh...theres probably 100 miles left at one bar, even if its blinking!!:D
  18. 007
    007 New Member
    157
    Antigonish, Nova Scotia
    hmmm...you're gonna need some gas soon too!! lol
    er....never mind, I see someone else already mentioned it....RRXing beat me to it. :)
  19. tomlouie
    tomlouie Member
    118
    Boston, MA, USA
    2023 Prius
    I wouldn't put it past someone see what mileage they get in EV+Eco+Neutral+NoAC+NoLights. :)
