ICE in Reverse?
Discussion in 'Gen 3 Prius Technical Discussion' started by pictone, May 15, 2011.
  1. pictone
    pictone Junior Member
    Atlanta
    Why does the ICE start up every time I power on the vehicle and use reverse to back out of a parking space? This happens even with AC, fan and audio turned off. It comes on during the reverse process and then remains on until I come to the next full stop, even though I do not go over 10mph the whole time. Seems like a waste.
  2. sipnfuel
    sipnfuel New Member
    1,080
    174
    So. Cal.
    The ICE turns on to warm itself up. This happens whether you want it to or not, unless you hit the EV button and EV mode is available.
    EV mode won't be available dependent on some conditions such as if the ICE is below a certain temperature, the HV battery is above a certain temperature, the heat is on, etc. In that situation, the ICE will always start regardless of your preference.
  3. jdenenberg
    jdenenberg EE Professor
    3,954
    1,952
    Trumbull, CT
    2020 Prius
    LE AWD-e
    The ICE is used to generate electric power using one of the MGs to drive the other MG in reverse. Your Prius is a serial hybrid when going backwards.
    JeffD
  4. Corwyn
    Corwyn Energy Curmudgeon
    2,171
    659
    Maine
    Mine doesn't. The only time that the engine runs when I am in reverse is when it is warming up. Otherwise reverse is electric only. It is my understanding is that this is how it is designed.
  5. pictone
    Atlanta
    Thanks for the education!
  6. mikewithaprius
    mikewithaprius New Member
    656
    103
    Rhode Island
    Yeah, I agree with Corwyn. When you're in reverse, MG2 (the main electric motor) moves the car. If the ICE is on when reversing, it's usually because you just turned on the car, so the car runs the ICE to warm up everything up, assuming you'll continue your voyage longer than a few seconds. The ICE does not at all power the car in this case.
    That's why if I have to move the car to the driveway, I throw it in neutral the second the "ready" light pops up, and a few nice gravity-aided swoops later, I'm parked in a new location without the engine having to turn on. Now moving it out of the driveway is another matter...
  7. qbee42
    3,081
    This depends on how far you need to back up, and how much charge you have in the HV battery. If the HV battery SOC is high enough, the Prius won't start the ICE unless it does so for heat. However, once the SOC gets low the ICE comes on to supply power. In this case it is indeed a serial hybrid.
    Backing up, the serial hybrid mode of the Prius is not very efficient. Since the torque split through the PSD is fixed, the ICE tries to move the car forward while MG2 moves it backward. MG2 wins, but it's not very elegant. Fortunately, backing is not a common form of travel.
  8. DaveLevenson
    DaveLevenson Junior Member
    It is my understanding that when the hybrid system is turned on, the ICE runs as soon as the coolant has been pumped from the thermos into the engine, for as long as it takes to bring the catalytic converter up to operating temperature. Backing up is often the first maneuver of a trip, so it appears to start when backing up. It starts at about the same time after power-up, even if the car is moving forward, or if it's not yet moving at all.
  9. tomlouie
    tomlouie Member
    118
    Boston, MA, USA
    2023 Prius
    If you back into your parking spot at the end of your trip, you'll avoid the need to back out at the beginning of your next trip. It's a double win:
    1. the warmed up car is more fuel-efficient backing up than the cold car,
    2. less likely to get in a collision backing into a spot than backing out of a spot.
  10. adamace1
    adamace1 Senior Member
    1,403
    193
    Charlotte, NC
    it's for emmisions, it tries to warm itself up before you take off onto the roadway. It's preventing a cold ICE start when someone may leave their driveway and have to start going 50mph on a cold ICE.
  11. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    The -correct- answer is buried up there in all those messages. ;)
    First, it's a GIII so no pumping of coolant.
    Whether the A/C system is demanding heat or not and whether the ICE is warm or not, AND whether the cat is warm or not, the ICE will run to warm up the cat, for a minimum of about 20 sec. EVERY TIME you shut down the car (go from "ready" to off) and start back up (put the car in "ready").
    Yup, it could be considered "a waste". But it's required to meet the EPA rating Prius has earned.
    So just tell yourself "It's all good!" :)
  12. cobradb
    cobradb Member
    105
    tn
    i seem to remember that the ICE has to reach 100 deg F before it shuts down.
    mine also want to run for abt one mile after i start it up from a short stop.
  13. David Beale
    5,963
    1,989
    Edmonton Alberta
    Don't see that. It's timed or cat. sensor defined, not temperature of the ICE. Pearl shuts off the ICE even if the ICE is still at 45C or lower, for example.
    Also note that the car is rather "limp" for about a minute, perhaps less, from a cold start. This to keep the ICE from running at power to keep emissions down while cold. I suspect this is why many reviewers think the Prius is gutless. It isn't, it just has certain "different" operating methods, such as a slight delay when you floor it. It WILL "scat" very well. I often leave traffic behind at lights.
  14. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    FWIW, I see with my SG that the engine will shutdown, if it can, @ 103 degrees every time in ECO mode.
  15. Codemonkey812
    Codemonkey812 Junior Member
    22
    Kent, Ohio
    Picking up on an old thread but, I wish this was something better explained to new Prius owners. I almost got stuck in a driveway with a very steep grade, when I had to back out of it. I did not realize the ICE cannot assist in backing up. I had to wait for the battery to charge and the ICE to shut down before I could back out.
