What's a "pip" worth?
Discussion in 'Gen 2 Prius Main Forum' started by samaruf, May 15, 2011.
  1. samaruf
    samaruf New Member
    28
    Minneapolis, MN
    After my first fuel up last night and having driven around 70 miles, I'm surprised to see that all the pips are still lighted in the gas gauge. Anyone of you know how many miles on average does each pip weigh? I'm sure it depends on a person's driving, but would still be good to know what people are seeing on average.
    52,069
    the pips mean next to nothing because of your tank bladder. figure about 50mpg and 10 gallons max. fill up early until you get a feel for what you're capable of.
  3. macmaster05
    macmaster05 Senor Member
    4,050
    730
    It's always a little different. For me, I lose my first pip around 70-80 miles, then get ~40 miles from each pip after that. That means about 430-440 miles per tank, and I fill up about 8.25-8.5 gallons each time, which means I'm getting ~52mpg.
  4. dustoff003
    1,371
    335
    Waianae, HI (Oahu)
    I was wondering how much the flashing pip is worth and does it disappear?
    Posted from my iPhone via the Tapatalk app.
  5. macmaster05
    4,050
    730
    Of course! Maybe another gallon, but I would not test it...
  6. samaruf
    samaruf New Member
    28
    Minneapolis, MN
    I signed up at fuelly.com and also got an android app for my EVO 4g phone to help me track fill ups and mpg. So you are saying due to the bladder tank, the amount of gas in each fill up will vary. I wonder what's the logic behind this technology instead of having a solid fuel tank. With our Minnesota winters, rubber is not exactly the best material to store fuel.
  7. bisco
    52,069
    it was an engineering mistake. if you get a gen III ( 2010 or 2011), the bladder is gone. the cold won't matter much, it's bad all year round. you'll adjust as you become familiar with your particular car, they are all a little different.
  8. dinger_greg
    dinger_greg New Member
    86
    Brookfield, WI
    Not sure the logic behind the bladder tank. I can put more fuel in my Prius when it is warm out compared to when it is cold. I live in Wisconsin so our Winter's are similar in temperature.
  9. bisco
    52,069
    it probably disappears with the gas. i wouldn't chance it. i ran out once because i forgot about the flashing pip. and i think every car is a little different. there are some threads here reguarding this if you look around.
  10. macmaster05
    4,050
    730
    Yup. In my experience, the bladder is a problem when I stray from my fill-up routine. I usually let it go down all the way to the last pip, and then refill completely. The 70-80 mile first pip thing I told you about only happens when I do this. For example, one time I had to get gas in the middle of my cycle and my first pip disappeared in 36 miles. That tank, I only got 38mpg. Worst in my history of ownership. Although the tank before it was 56 mpg, and the tank after it was 59mpg. Still, I don't like the inconsistency. It scares me.
    Now I always wait for my gas to go down to the last pip. That always gets me above 50mpg. :)
  11. mikewithaprius
    mikewithaprius New Member
    656
    103
    Rhode Island
    The logic is that in an emptier tank vapors can form and escape, thereby wasting the gas you've purchased. The idea was to keep down the volume to prevent vapors from having room to form. In theory it would completely expand on fill-up, but we all know that doesn't always happen.
  12. samaruf
    samaruf New Member
    28
    Minneapolis, MN
    As a software engineer, this bothers me. I mean why should there be this much mpg variance based on when the tank is filled. With so much cool technology embedded in this vehicle, I'm surprised they goofed up this crucial piece. Since my first fill up was done at two pips, I will try to maintain consistency.
  13. Rocco42
    Rocco42 Member
    115
    30
    Rosendale, NY
    The idea behind the bladder was to not produce as much evaporate, helping you save gas, and helping prevent the emissions of hydrocarbons in the atmosphere. It also prevents the fuel from sloshing around a little bit.
    Evaporate canisters also provide some of this, but a bladder provides more prevention of this evaporation.
  14. macmaster05
    4,050
    730
    It bothers me too. To expand on my experience, I found your "miles per pip" (mainly the first pip) is proportional to how many pips I had left before refueling. For example, when I have 2 pips left and fill up my first pip usually drops in 70 miles. When it's 3 pips, ~60. 4 = 50. And 5, halfway was about 40, my nightmare as I described previously. In the summer, I've gone down to 1 blinking pip and my first pip was lost after 120 miles! :D Now that was fun.
    But really, there's nothing I can do about it. As long as I keep driving well, everything averages fairly over time.
  15. mikewithaprius
    656
    103
    Rhode Island
    Me three. It might just be the warmer weather, but I've been filling nice and slowly recently and the thing seems to get more gas in. It just went from three to two pips today around 450 miles. It may well be useless, but I figure it doesn't hurt to try if you have an extra minute or so at the pump.
  16. stefano5777
    stefano5777 Member
    380
    47
    St. Petersburg Florida
    I used to get anywhere from 215 to 226 miles from my first pip and 30 to 40 from second and then roughly 50 miles every pip after that.I usually get 630 to 680 a tank with best being 700. Just installed enginer kit 502 miles driven only used 3 pips!
  17. samaruf
    samaruf New Member
    28
    Minneapolis, MN
    That's amazing. Will have to read up on what "engineer kit" means. Some kind of an after market modification of the hybrid system?
  18. mikewithaprius
    656
    103
    Rhode Island
  19. stefano5777
    stefano5777 Member
    380
    47
    Enginer kit is a plug in conversion for all hybrid vehicle it is the cheapest system you can buy. Only draw back is it is about 90% reliable in the stock form with modifications you can get 95/96% reliability.
  20. samaruf
    samaruf New Member
    28
    Minneapolis, MN
    Very nice, but I'm afraid on top of the premium price paid for the hybrid and add to that the cost of the enginer kit, will there be any savings? I mean the main goal of this exercise is save money on gasoline. When I bought the Prius, a 2008 corolla or civic with similar mileage was going for $14K-$15K. So I paid around $4K in premium for the Prius and hope that my mpg(and gas prices) will be high enough during the next 4-5 years for me to recoup the difference. I guess on the flip side I could always buy a beater for couple of grand and drive it to death and come way ahead in savings in the long run :noidea:
