Repair of MFD - your Display unit
Discussion in 'Gen 2 Prius Technical Discussion' started by Newsmom, Oct 2, 2010.
  1. Newsmom
    Newsmom Junior Member
    Laurel, MD
    My electrical engineer did the work on my 2004 MFD, after the local dealership quoted a $5,000 replacement cost.
    He says he'd be willing to do the work for others with '04 (and some '05) displays that have these "pin 60" problems:
    -- screen message that the Air Conditioning is not connected
    -- Audio Off and the console Power button for stereo ineffective
    -- No display of outside temperature
    e-mail me if you're on the EAST COAST and can bring your Prius to suburban Maryland for the repairs.
    His charge is 1/10th what the dealer wants.
    :cheer2:
  2. alicemd1000
    alicemd1000 New Member
    Kennett Square, PA
    I have a broken MFD in a 2004 Prius and can drive to suburban Maryland. May I find out the name of the electrical engineer, please.
    Thank you very much.
  3. stefano5777
    stefano5777 Member
    380
    47
    St. Petersburg Florida
    You can buy a used mfd on Ebay anywhere from 400.00 to 800.00 on ebay with 30 day to 90 day warranty.
  4. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Or you can buy a $8 kit from Radioshack that has a soldering iron, desoldering wick, a stand, and some solder and have at it yourself.
    KK6PD likes this.
  5. jdenenberg
    jdenenberg EE Professor
    3,939
    1,937
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Call Steve at Plug In Hybrid Electric Vehicle PHEV and he will fix your MFD for a reasonable fee. It will require you to remove it and send it to him in Indianapolis and then reinstall it. Any car stereo shop can do the removal/reinstallation for you if you feel that you can't do it yourself using the instructions on Steve's web site. I fixed mine myself using the instructions at: Prius MFD thanks to the Hobbit.
    JeffD
  6. tdn
    tdn Junior Member
    Russia
    Work to repair the MFD cost me $ 10 :)
  7. jeff callahan
    jeff callahan New Member
    hello
    i also live in Rockville and have been dealing with a dead mfd for 4 years. Can i ask the name and phone number of your friend
    thanks
    jeff
  8. walpoleauto
    walpoleauto Junior Member
    48
    Walpole, Massachusetts
    There is a place called BBA Reman in Taunton MA that can rebuild it for cheap money and give a lifetime warranty.
