17" Wheels offset
Discussion in 'Gen 2 Prius Accessories & Modifications' started by powerjo, May 18, 2011.
  1. powerjo
    powerjo Member
    112
    42
    Hong Kong
    As far as I know, the Prius II's wheels offset is 45mm max.
    What if I install the wheels with 50mm?
    Will work?
    Thanks!
  2. macmaster05
    macmaster05 Senor Member
    4,050
    730
    Don't know for sure, but even if it works, 50mm is pretty narrow don't you think?
  3. HI MPG
    HI MPG Active Member
    789
    133
    93
    Orange County, CA
    I guess that depends on how wide the tires and rims you are planning on installing.
  4. powerjo
    powerjo Member
    112
    42
    Hong Kong
    I'm going to install 215/45/17
  5. macmaster05
    4,050
    730
    wats the rim ? :)
  6. dustoff003
    1,371
    335
    Waianae, HI (Oahu)
    That is the stock tire size for the Prius V/Five. I have those on my car with the OE 17' wheels but I have no idea what the offset is. I am sure that somebody here does. I think it is maybe 40mm?
    Posted from my iPhone via the Tapatalk app.
  7. powerjo
    powerjo Member
    112
    42
    Hong Kong
    As somebody sells Rays CE28N 17" 7.5 50 100.
    I wanna buy them, but worrying about the offset... :(
  8. macmaster05
    4,050
    730
    Those are hot. Worst case scenario, you'll need spacers. Would the seller let you try them on first?
    These rims come in a lot of sizes/options and they're not discontinued so maybe there's a good chance you can find another set from another seller...?
  9. a_gray_prius
    2,927
    783
    IL
    Ce28Ns are a_gray_prius approved(TM).
  10. powerjo
    powerjo Member
    112
    42
    Hong Kong
    haha, since those are 2nd hand rims but in good condition and very attractive price. So, no options ! :D
    Maybe spacers are the solution~
    Is the PIII in same specification for the wheels installation?
    As I found that somebody here installed the wheels which are 50 offset...
  11. powerjo
    powerjo Member
    112
    42
    Hong Kong
  12. HI MPG
    789
    133
    93
    Orange County, CA
    You should be okay running the +50 offset. My rims are 16s with a 50 offset and my tire width is 205. Like Mac said, you could always use spacers.
  13. dustoff003
    1,371
    335
    Waianae, HI (Oahu)
  14. F8L
    19,011
    4,083
    Grass Valley, CA.
    I'd caution going too extreme on offset unless you plan on keeping the car at stock height. If you lower the car then offset will become more critical. Obviously at any height you'll have to consider if the wheel will clear the struts.
    Push the offset too much and you'll sink the wheels so far into the wheel well (positive offset) that the car will look goofy and it may negatively affect handling. The more you push the wheels outside the wheel well (negative offset) the better the handling (within reason).
  15. powerjo
    powerjo Member
    112
    42
    Hong Kong
  16. F8L
    19,011
    4,083
    Grass Valley, CA.
  17. powerjo
    powerjo Member
    112
    42
    Hong Kong
    I am not so familiar in cars. But seems we have no LRR in the market.
    Just surfed on the web, Bridgestone seems does not sell GR90 in US market. :)
  18. Mendel Leisk
    41,519
    Tirerack shows some choices:
    Tire Search Results
  19. F8L
    19,011
    4,083
    Grass Valley, CA.
  20. kewrad
    kewrad New Member
    Maryland
    According to the Prius specs it can take a range from +35mm to +48mm. I don't want to mislead you but there was a forum which I read that the Prius V 17" OEM Wheels are +50mm. If this is not true then you can always put spacers. I've been looking around to put some 17" Corolla XRS with +39mm on my Prius II, which so far I believe it will work since they stay in the 35-45 range.
