What's the most water efficient way to wash dishes?
Discussion in 'Environmental Discussion' started by burritos, May 20, 2011.
  1. burritos
    burritos Senior Member
    4,946
    252
    For those who don't use the dishwasher? My wife thinks it is to let the dishes pile up at the end of the day and wash them all at once. Personally, I hate doing that cause then that becomes a time consuming chore. I prefer to wash the dishes after use, cause it takes little time to was a handful of dishes. And the food and drinks don't harden up where you have to use more water to dissolve it.
    The thing is when I wash the dishes, instead of soaking, I let the water run. Of course I let it run onto existing dirty dishes which I think dissolves more foody materials. If it's the last few dishes, I'll let the water run into our greywater bucket for our lawn.
    I don't mind doing dishes, I just don't want to do it all at once at the end of the day. My wife doesn't mind doing them all at the end of the day, but then I feel bad because it's now a real chore. But she gets annoyed when I do it my way cause my technique in her mind wastes more water. Who's right, or is it just a wash?
  2. Ryanpl
    Ryanpl Active Member
    780
    158
    Brooklyn, NY
    LOL, we tend to wash them at the end of the day.
  3. krelborne
    krelborne New Member
    295
    Alabama
    Just wash as you go and use a trickle of water. I don't see how you can beat that after you've let the food fuse to the dishes.
  4. Dave7
    Dave7 Junior Member
    45
    CT
    2020 Prius Prime
    I only put in less than an inch of water. Add soap and the utensils.As I wash I rinse into the same sink. Then plates , then glasses and so on, ends up using very little water and it's all right there to see how little you used. Less than half of what would have been used by filling the wash sink and then rinsing in the other sink.
  5. wick1ert
    wick1ert Senior Member
    1,311
    183
    Delawhere
    I've found that most people would say: the wife is always right. If she gets annoyed with your way, just let her do it her way. Buy her some flowers next time or something - I hear they like that kind of thing lol.
    I just let my cats lick the plates clean then re-use....J/K!! Everything goes in the dishwasher for me, except pots, pans, etc as they take up too much space.
  6. BrettS
    BrettS Active Member
    290
    136
    Orlando
    Honestly, there are so many variables that I think it would be pretty difficult to hazzard a guess. But this sounds like it would be pretty easy to test... one day you wash the dishes your way and let all the water drain into your greywater bucket and measure how much water you use... the next day let her do them her way and measure that water. If you really want to get all scientific about it, do it over a week or two and average the results.
  7. bisco
    51,781
    marine style, spit and polish.
  8. qbee42
    3,079
    Pee on them.
    If that doesn't work for you, then use your system, but use a commercial sprayer type of faucet where water flows only when you squeeze the handle.
  9. mikewithaprius
    mikewithaprius New Member
    656
    103
    Rhode Island
    I'm with Krelborne on the "trickle" method. Bare minimum needed to get the job done. It's like a pulse in P&G.
  10. stefano5777
    stefano5777 Member
    380
    47
    St. Petersburg Florida
    Most efficient way to wash dishes If water conservation is a concern is to use paper plates and cups :D you will also find this the most efficient on your time :)
  11. Michgal007
    Michgal007 Senior Member
    1,321
    98
    Macon, GA
    LOL! Are you a scientist by any chance?
  12. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    Burritos can rinse the dishes as they are used and leave just enough water so that they do dry out before his wife washes them at the end of the day.
    My family follows the 'wash after use' discipline because 1. I dislike seeing dirty dishes pile up; and more importantly, my kids get the wrong idea that they can just add to the dirty pile and never pitch in.
  13. icarus
    icarus Senior Member
    4,884
    976
    earth
    My opinion, machine wash full loads only, no dry cycle. Or wash smaller batches by hand. I tend to wash using a soap spongy thing, using the running water to rinse as I am filling, doing the cleanest first. A whole days wormy of dishes takes about 1 gallon of water,, solar heated of course.
    Icarus
  14. kenoarto
    kenoarto Senior Member
    398
    Chicago, IL
    Consumer Reports does test this kind of thing. A dishwasher uses much less water than washing by hand. Just be sure not to pre-rinse your dishes.
  15. Dusty Chips
    Dusty Chips New Member
    85
    Laughlin NV
    Put 'em in the lawn snd turn the hose on 'em.
  16. ursle
    ursle Gas miser
    1,049
    192
    NH
    No water... take them out to the sand box and rub them clean with sand, really
  17. paprius4030
    paprius4030 My first Prius
    2,077
    296
    York,Pa.
    Put them on the floor and let the dog lick them:washing:
  18. burritos
    4,946
    252
    I do that with large pots and pans that don't require much soap.
  19. burritos
    4,946
    252
    If I don't pre rinse my dishes, I have clean dried food stuck on many of my dishwashed dishes.
  20. mikewithaprius
    656
    103
    Rhode Island
    Would the used food be...burritos, by any chance? :D
