ECO Display Option On or Off
Discussion in 'Gen 3 Prius Main Forum' started by eh0013, May 20, 2011.
  1. eh0013
    eh0013 Junior Member
    Philly
    New owner, first time Prius owner. Searched high and low but perhaps the search options are too broad. I am hoping that there is a quick answer to this: Any technical difference between turning the ECO diplay "on" or "off" when setting display options? I know when "off", the ECO sign does not show but does it also mean the car runs differently? Is this just a way to avoid having that thing show up? Sorry but I am going with the idea that "there are not stupid questions" (I hope). Thank you.
  2. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    AFAIK it just makes the light not come on.
    You can still activate and drive in eco, pwr or normal modes even with the eco light turned off which gets shown in the MID.
  3. eh0013
    Philly
    Thanks, Paradox. It took me awhile to figure out what AFAIK meant but I got it. Just getting the light to go on and off seems to occupy quite a bit of technology/attention....being the first option to be listed. This was what made me wonder if this option meant more than that.
  4. Gaelic8
    Gaelic8 New Member
    Magalia, Ca 95954
    I keep it in ECON all the time. Is there a benefit in doing/not doing so? I never really understood.
  5. pfjmarina
    pfjmarina Junior Member
    46
    Marina, CA
    ECON mode just changes how the gearing is adjusted. Same for power mode. Power mode makes gearing more agressive, ECON makes it somewhat more economical, but at the cost of acceleration. When I first got my Prius (about a month ago) I left it in ECON mode most of the time, but have since just left it in normal mode. With careful driving it doesn't seem to effect mileage much if at all.
  6. cap160
    cap160 Older Member
    78
    Michigan
    OK I'll bite what is AFAIK?or give me a hink:confused:
  7. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    As Far As I Know
  8. billnchristy
    billnchristy Active Member
    924
    123
    GA
    2016 Chevy Volt
    Its not gearing though its pedal response.
    I work in normal and switch to power when I want to smoke someone off the line...not that you can't do it in any other mode but its fun to say "I just smoked you in a Prius and I didn't even have to floor it." :)
    The little eco oval will not appear in power mode but does in all others. I assume this is because the engine is kept at the ready in pwr mode.
  9. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    What is a "hink"? :D
  10. cap160
    cap160 Older Member
    78
    Michigan
    Thanks for as far as I know
    Sorry Spell check failed "hink"= hint
    Sounds,looks, like a good Vanity Plate
  11. Rocco42
    Rocco42 Member
    115
    30
    Rosendale, NY
    I know this is off topic, but it can be helpful. Anyone needing help with acronyms, you know those annoying letters that you don't know what they mean, just go to Acronymfinder.com , plug in your acronym, and Voila! there are all of the currently known abbreviation, acronym, or initialism stands for! Now when you find one, don't complain that there are many definitions to that acronym, just narrow it down by topic.
    They have more than a million acronyms there!
