Leak under body in the center rear
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by tom1l21, May 22, 2011.
  1. tom1l21
    tom1l21 Member
    268
    East Longmeadow, MA
    Directly under the body in the center, about 2 feet in from the rear, I noticed a small drip leak. There was a weak rubber plug that I yanked out and all of a sudden, about half a gallon of a water like substance poured out. Anyone know what this was?
    Update: it appears that the spare tire compartment was full of water. Any idea why or what could of caused this???
    PC36100 ?
  2. Britprius
    Britprius Senior Member
    5,194
    1,921
    Herefordshire England
    Likely to be water trapped in the spare wheel well, possibly leaking in through one of the rear light seals to the bodywork.
  3. Britprius
    5,194
    1,921
    Take out spare wheel clean and dry the well leave rubber bung out till path of water ingress is found and rectified.
  4. Rokeby
    Rokeby Member
    3,033
    709
    75
    Ballamer, Merlin
    +1 The Gen II rear light assembly gasketing is, well...
    let's say usually functional, but on the scant side...
    thin, easily compressible strip foam gasketing,
    apparently off a roll and applied by hand...
    Did I say cheesy?
    When I had both assemblies removed, to replace '08 lights with '06
    ones -- to get the black chrome brake light reflectors, I was suprised
    to see how different the actual paths of the gasketing was on the four
    assemblies.
    Lots of opportunities for leakage.
  5. Cip
    Cip Junior Member
  6. wjtracy
    wjtracy Senior Member
    11,362
    3,607
    Northern VA (NoVA)
