front windshield shade
Discussion in 'Gen 3 Prius Accessories and Modifications' started by gychang, Feb 19, 2011.
  1. gychang
    gychang Junior Member
    Davis, CA
    I am looking for double circular ring type with reasonable front windshield coverage (that folds in minimal space).
    If someone can refer me to amazon or local auto chain for the proper item I would appreciate it.
    gychang
  2. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    You may have seen the one sold here in the shop, but if you didn't it's here:
    PriusChat Shop : 2010-2011 Toyota Prius HeatShield Sunshade - Front [1215] - $32.00
    It rolls up to form a tube instead of the kind you're talking about but is a perfect fit in the front windshield and if you roll it tight, you can just toss it on the floor in the back seat... That's what I usually do in the summer when I have to use it.
  3. patsparks
    10,664
    567
    Adelaide South Australia
    Are you looking for a sunshade for a Prius? I see in your profile you don't own a Prius.
  4. gychang
    Davis, CA
    I should update, I do own a 2010 Prius. gychang
  5. gychang
    Davis, CA
    I am actually looking for a easy to store (don't need side windows etc) type.
    gychang
  6. fotomoto
    fotomoto Senior Member
    5,632
    3,805
    So. Texas
    I use the same sunscreen from our former nissan quest mini-van. Sorry, I don't remember where I purchased it but probably wal-mart or a national chain auto parts store. It's a large or van size.
    It's large enough that I don't have to flip down the sun visors (two less steps); rather I can tuck the screens in between them and the ceiling.
    It consists of two individual rectangle-ish shaped screens but combine and twist into one small circle for storage.
    I store it between the center console and passenger seat and it doesn't cause any problems with them or moving the seat.
  7. gychang
    Davis, CA
    Doug, this is similar to what I am looking for... Perhaps tiny bit smaller (don't mind flipping down the visors)
    gychang
  8. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    Do you belong to Costco? They have these kind in different sizes and take returns VERY easy.
  9. anthonylokrn
    anthonylokrn Member
    119
    I've still been looking for a circular sun shade to fit my gen2. I've tried both the Jumbo (largest size available) from Target and Walmart and they are both still too small even when used vertically.
  10. DeanFL
    DeanFL 2010 owner - 1st Prius
    1,015
    355
    Leesburg Florida USA
    I bought one off the PriusShop. It's of great quality and performs perfectly - but it is bulky. The unit rolls up and I flip it in the rear footwell when not in use. Does takes a bit of juggling to unroll and install but the coverage is close to 100%. I do like the idea of the smaller, easy to store types pictured in other posts below.
    But if you don't mind the size, the roll-up version works very well.
  11. J2014
    J2014 Junior Member
    37
    2014 Prius Plug-in
    Any new suggestions for the a windshield sun shade? I'm looking for one that will be easy to fold. I read the custom fit one from heat shield is difficult to fold?
    Would tinting the windshield be better?
  12. gychang
    Davis, CA
    I bought one from prius shop as recommended above, found it effective but chore to use... perhaps costco stock is what I would go with
  13. StarCaller
    StarCaller Senior Member
    1,275
    726
    Cedar Crest, NM, USA
    the folding's easy; as long as you do it outside the car/ ;)
    but, the protection is perfect - I can only recommend this product//// (y)
  14. Stratman
    Stratman Member
    334
    74
    Lilburn Ga
    Same here. Works great. I just roll it up and toss it on the backseat floorboard.
