Steering Problems
Discussion in 'Gen 2 Prius Main Forum' started by mbarlow, May 21, 2011.
  1. mbarlow
    mbarlow Junior Member
    28
    Louisville
    I gave my '04 Prius to my daughter for graduation a month ago. As she was backing out of the dorm last week the steering knuckle failed and the dealership says time for a new rack. I agreed to an aftermarket replacement rack ($600 difference between the Toyota part and this new part). Dealer called back to say the clockspring in the steering column is broken and wants another $500 to fix. I just want the car back home (300 miles) where my trusted mechanic can take over. Dealership says car is in limp mode and can't be driven. Shouldn't there be a reset so that it can be driven even with the broken clockspring? Anybody have knowledge of a problem with '04 steering? I recall a comment about a TSB, but can't find it.
    I'm no conspiracy theorist, but starting to feel a little "bent-over" by this dealer. Thanks for your assistance.
  2. Patrick Wong
    18,210
    6,526
    There was a recall associated with replacing the intermediate steering shaft on earlier 2G vehicles.
    A failed spiral cable (aka clockspring) would potentially impair the driver's airbag in the steering wheel hub and the steering wheel controls, but it should not prevent the car from being driven.
    Either the car has other problems causing a "limp mode" or else your daughter has fallen into the hands of a crooked service dept.
    I am not aware that aftermarket replacement steering racks exist. Are you sure that this is not a salvage part? It would be interesting if you were able to identify the aftermarket manufacturer and part number.
  3. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,520
    Santa Fe, NM
    They probably broke the clockspring while putting in whatever rack. And the steering knuckle broke? How???
    There is no limp-in mode that I am aware of with regards to the clockspring. Probably the airbag light is on but that is it. Technically, the dealer can argue that the car is not safe to drive without a working airbag or horn. But that shouldn't stop you from retrieving the car and ALL parts that were removed.
  4. romad
    romad 2004 Prīus Base Former Owner (Sold 13 May 22)
    320
    57
    Prescott, AZ
    Yes, I've had a problem TWICE on my 2004. The first is detailed here: http://priuschat.com/forums/gen-ii-prius-main-forum/87621-close-steering-disaster.html
    The second happened yesterday, 20 May 11. As my wife backed out of the garage, she heard a noise like a snap or pop. When she tried to go forward there was absolutely no steering. I could just spin the wheel, even with all power off. We had it towed to the local dealer, where they found that the splines on the Steering Intermediate Shaft No. 2 were stripped/sheared. Now they were apparently still good last November when the Steering Sliding Yoke Sub-assembly was replaced. As it stands they are perplexed as to how this could happen and are going to investigate further, possibly getting Toyota involved. So we'll see what they say next week. Oh, since the wheel spins freely, they think the clock spring might also be broken.
    You also asked about the TSB: It is SSC-60C and I'll try to upload the PDF
    2 people like this.
  5. mbarlow
    28
    Louisville
    Your description is exactly what happened to my daughter's car. I'll ask about the part number for the replacement part. Theres a good liklihood you donked the assembly. The tech did say the airbag light was on. I understand the risk of driving w'out the airbag, but this is about 290 miles of parkway in rural west Kentucky.
    We should stay close on this issue because it is suddenly getting very expensive. Anyone with recall or TSB reference would be greatly appreciated (I've looked in the obvious places). Thanks!
  6. mbarlow
    28
    Louisville
    Romad, my bad, I'm half asleep and just noticed the reference & PDF. Many thanks!
  7. romad
    320
    57
    Prescott, AZ
    My dealer called today. The parts are ordered and I should have it back either tomorrow or Wednesday. Also, they said the repair would be at no charge to me. We'll see. They are replacing the Steering Intermediate Shaft Assembly #2, and the Sliding Yoke Sub-assembly, both of which were replaced back in June 2006 under SSC-60C, and latter part also was replaced in November 2010 when we had the steering break.
  8. romad
    320
    57
    Prescott, AZ
    Well, the steering is back in and working, but they are waiting for the clock spring to arrive tomorrow and then we should get the car back in the afternoon. They said again that EVERYTHING is no charge to me. Probably because it was less than 6 months since the last repair.
    mbarlow, what is the status of your repair?
  9. seilerts
    3,326
    1,520
    Santa Fe, NM
    Toyota parts carry a 1 year warranty. It's a pain to have them do it all over again, but at least it is free. I wonder what they did wrong 6 months ago. At least the failure circumstance was benign.
  10. romad
    320
    57
    Prescott, AZ
    Except that the part that actually broke wasn't replaced 6 months ago; it was replaced 3 years and 11 months ago as part of SSC-60C. Additionally the clock spring had never been replaced. What I think is that because they could not say for sure if it was a manufacturing defect in the part that broke, or possibly something as a result of the work back in November, they decided to just cover everything, parts & labor.
    Yes, we were lucky. We had made a trip to Las Vegas & back in early March. The night before it broke, I would have normally used the Prius to attend a meeting in a neighboring town, but used my Miata instead.
  11. Patrick Wong
    18,210
    6,526
    This is scary to think about. What if the steering failed while you were at speed, traveling on a curvy mountainous road.
    Any accident history on that car?
  12. romad
    320
    57
    Prescott, AZ
    Nope. We bought it new in August of 2004.
    It makes me wonder about Toyota's parts quality. First, the Sliding Yoke and Intermediate Shaft #2 are the subject of a recall in 2006. Then in Nov 2010, the Sliding Yoke (again), Shaft #1, and Steering Rack all have to be replaced because of a failure. And now in May 2011, the Sliding Yoke (again) and Intermediate Shaft #2 (again), and the clock spring. So in less than 4 years we've gone through: 1 steering rack; 1 steering shaft #1; 1 clock spring; 2 Steering Shaft #2s; 3 Sliding Yokes.
    In 25 years of owning GERMAN-built VWs and 21 years of a JAPAN-built Mazda Miata, we've never had as many major problems. The only other vehicles we've experienced similar problems were AMERICAN-built vehicles, which is why I refuse to buy anything built in the Americas.
    However, the Prius is back home and, as promised, at no charge to us. The dealer is great; it is Toyota itself I wonder about. They seem to be more concerned about out-selling GM world-wide than quality. Quite frankly, I may be in the market for a German-built vehicle to replace the Prius as I've lost confidence in Toyota.
  13. seilerts
    3,326
    1,520
    Santa Fe, NM
    Your story makes me wonder if the initial recall repair was botched. Otherwise, if it were a problem in general with the parts, there would be class action lawsuits for multiple out of warranty repairs and many accidents due to unintended steering.
  14. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
    In the cases where you've had the shafts break or other safety issues, you guys should definitely file a safety complaint w/NHTSA, if you haven't already. That is scary.
    That is unfortunate about your Toyota experiences. I can't explain it... Statistically, VWs (even some German made ones) seem to have generally poor reliability records in Consumer Reports. Perhaps you've been unlucky w/your Prius or something else is at play?
