A New Perhaps Better Way To Hold the Prius Up For An Oil Change
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by 2010priusowner, May 31, 2011.
  1. 2010priusowner
    2010priusowner New Member
    37
    FL
    First off like many I hate the idea of the low man on the totem pole changing my oil, I do not trust that they will use the oil I give them and lastly as a former mechanic I am afraid of allowing strangers work on my cars. Yeah I have seen allot of foul ups.
    That being said I decided to look on these forums and elsewhere only to find not very good info on placement of jack stands that did not require removing the under cowling to get at the frame. Or so I see on the pics.
    Then I saw posts of people using plastic ramps and thought no one better be around when trying those. As they are liable to shoot out from under the wheels or damage the vehicle.
    Then I thought why hasn't anyone developed Pinch weld jack stands yet?
    Which led me to buy a pinch weld adapter for my low profile 3.5 ton floor jack, for tire rotations etc.
    Then I thought hey what is wrong with buying the rhino ramps then using the floor jack to lift from the center front lift point and just slide the ramps under the tires lower the car onto them and do the work? It seems to me the biggest danger with ramps is getting on them under power.
    So can anyone see a flaw to this idea besides the obvious needing a good floor jack. I am unfamiliar with rhino plastic ramps.
  2. wesayso
    wesayso Member
    385
    35
    Hampton, VA
    I've always done that with my wife's Hyundai.
  3. tomlouie
    tomlouie Member
    118
    Boston, MA, USA
    2023 Prius
    One disadvantage of using the wheel ramps versus jack stands is that the car is still on its suspension, so it will move a bit if you tug or push on it hard while trying to loosen bolts, filters, etc.
  4. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    What is the issue with the Rhino ramps? I drive my cars up on them all of the time. Then set the parking brake and chock the back tires. Never had a problem.
    There are many on here that use the ramps and I have not heard of an issue yet.
  5. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    You would have to jack the car way up in order to slide the ramps underneath as the suspension drops as it is lifted. By the time you were able to get the ramps underneath the car would be precariously high.
  6. dustoff003
    1,371
    335
    Waianae, HI (Oahu)
    I used a combination of ramps and jack stands. I drove on to the ramps then I jacked up the back this gave me allot of room and allowed me to open the access panel.
    Side view jack stands place at tire changing jack points.
    Floor jack at rear jacking point.
    There is no need to get a pinch weld adapter or whatever you call it for your floor jack. Toyota was kind enough to provide two floor jack jacking points one front and one in the back, check your owners manual for details.
    Posted from my iPhone via the Tapatalk app.
  7. ahmeow
    ahmeow Prius Lover
    366
    70
    North CA
    Me too. I use this method for many years and no issue. Set secure the parking brake and block the rear wheels are good enough . Of course don't do the under body job alone. Must let some one know you are working under the car body and those members come to check you time by time is OK. :)
  8. tumbleweed
    tumbleweed Senior Member
    4,067
    692
    Eastern Oregon
    Rhino ramps are the answer for me also. I have used them for oil changes with my last three cars.
    When changing transaxle fluid I used Rhino ramps for the front and jack stands for the rear because the car needs to be level to get the fluid level correct.
  9. 2010priusowner
    37
    FL
    Thanks for the reply but those my friend are not Rhino Ramps what are you using they appear to be metal and look very nice. Where did you get them and what should I look to pay? Thanks.
  10. 2010priusowner
    37
    FL
    Take a look at the reviews on Amazon they are enough to scarE anyone.
    http://www.amazon.com/dp/product/B000AMMN9O?tag=priuschatcom-20
  11. car78412
    car78412 Member
    284
    32
    Hudson Valley, NY
    Would the Rhino Ramps raise the car high enough to swing open the oil flap all the way? I have been raising my car with a jack then resting the car on jack stands high enough to allow full access to the oil drain plug and filter. The ramps don't look like it would raise the car high enough.
  12. jdcollins5
    5,131
    1,346
    Wilmington, NC
    2010priusowner,
    There are idiots everywhere. Most of the reviews were positive.
    If you cannot figure out how to safely drive a vehicle up on these ramps, you should not be using them.
  13. 2010priusowner
    37
    FL
  14. 2010priusowner
    37
    FL
    Heh,heh ya got that right!:)
  15. jdcollins5
    5,131
    1,346
    Wilmington, NC
    The Rhino Ramps will raise it where you have to bend the oil flap a little to get it out of the way. It is tight but works. It could use a couple more inches to give more working room. But it is easier than hydraulic jacks and jack stands for changing oil.
  16. Mendel Leisk
    41,923
    Already been pointed out, but: when you jack up the front end the suspension relaxes through a lot of travel before the tires finally lift off.
    Personally I'm using a 3 ton jack with an unloaded lift height of 21". I think I might be able to get enough lift to slip in ramps, but it would be close.
    I used ramps a few decades back but switched over to jacking up and settling it down onto jack stands. Still, with the Prius, I was not happy with the way the jack stands acted under the front scissor jack points .
    They don't look to be any thicker than the rest of the rocker panel, I found the jack stands had an unnerving tendency to shimmy forward when you settled the car down onto them.
    I found this recommendation, support points on the body rails, much more stable and secure:
    http://john1701a.com/prius/documents/Prius_Maintenance_Changing-Oil.pdf
    (on page 6)
    I've tried this once, just for practice, and then put the back end on jack stands just on the rear scissor jack points. Since the rear points are putting less load, and because the car is back to level, this combo seems to work quite well. So to summarize:
    First: front jack stands on the sub-rails, then raise the rear to level, setting it on the rear scissor jack points.
  17. Insight-I Owner
    Insight-I Owner 2006 Insight-I MT + 2011 Prius
    505
    100
    Essex, CT
    Nice writeup, thanks!!
    But one additional safety thing I have always done when working under cars that are up on jack stands is to leave the floor jack under the car with me. Out of my way, but close to me and jacked up so its load pad is just underneath something structural. That way if the car topples off the jack stands, it lands on the floor jack rather than on me.
    almypal26 likes this.
  18. 2010priusowner
    37
    FL
    I confess I have not crawled under the vehicle and really looked at it with more than a passing glance, but with maintenance coming due I am gathering my tools and knowledge base.
    The oil change guide is very nice BUT
    This document also appears to be updated from an earlier document and depicting the outside of a 2010 Prius but it looks like that is not a 2010 Prius, underneath but an earlier model.
    I have added some pictures below from the document you are writing about and a portion of a picture of the same area on a 2010 Prius from elsewhere on this site, to better illustrate my description. The one on the lift is what my car looks like when I looked underneath.
    if I am in error someone please point it out I would much prefer to use the frame as a holding point for stands than the pinch welds.
    UPDATE: I just printed out the document and went over it again the author is using two different vehicles in this document. Page 4 shows the front of an older model Prius. Page 5 shows the rear of a 2010 or newer Prius. Take a look, this document needs updated as it is no longer valid or helpful when it comes to depicting the points one can rest the jack stands on for later models.
  19. Mendel Leisk
    41,923
    I'll do that, as long as it's not going to be in the way of something, say the plastic aero panel being removed. Also, and I should stick to doing this, though I've been goofing off: I've always got at least one stack of 4 tires (either reg or snow, depending on the season) handy, I'll put them in stacks of two under each rocker panel, near the front jacking points, for life insurance.
  20. Mendel Leisk
    41,923
    Those first two pics may be from an earlier Prius model (note the absence of the plastic shield), but the 3rd gen architecture is very similar. When I tried it out I went back and forth between the computer pic and the garage to find the spot. It is very similar, the same rails etc. The rails dip downward near the end (as you can see in the pics), so when you jack up the front their underside is near horizontal. It gives a nice wide bearing surface, much more solid than the rocker panel edge.
    BTW, I picked up a spray can of black Plasti-Dip a couple of weekends back: I'm going to try coating my jackstand cradles, see how that goes. Hopefully doesn't just get chewed up immediately.
