new 8kwh ,need srings
Discussion in 'Prius PHEV Plug-In Modifications' started by playcool-7, May 21, 2011.
  1. playcool-7
    playcool-7 New Member
    Raleigh nc
    hi I am installing ,2 new 4kwh battery and2, 5kw conv. parallel in my 09 prius need to know from where I can get rear springs update. let know my progress.
  2. mrbigh
    3,686
    699
    Long Island, NY
    you're adding serious weight there
  3. playcool-7
    Raleigh nc
    I have place order for springs. POHL SPRING WORKS, tele # 800 777 1284 or Call MIKE 509 535 3649 .. It is 2 springs for rear 500 lb for $325. I got my second kit and working on it.
  4. ericbecky
    ericbecky Hybrid Battery Hero
    4,443
    3,351
    Madison, Wisconsin
    Be very careful running two converters. Test it out on a fairly deserted road before taking it into traffic. There are times with a Gen II Prius where you will put too much current into the Prius and the car will shut down. You will not be able to accelerate and will need to immediately pull over, stop the car, and turn it off and on again before it will work properly. I am speaking from experience. You do not want this to happen to you at freeway speed in traffic! It is dangerous to you and everyone around you.
    2 people like this.
  5. banshee08
    banshee08 Member
    284
    72
    El Monte, CA USA
    I have a Gen3 (2010 model year) Prius purchase in 2009. Is the two converters going into a Gen3 or Gen2 prius??? Make sure to have the voltages in both converters set to the proper voltages for your prius else you can easily over charge the battery stopped at a long red light.
  6. playcool-7
    Raleigh nc
    thanks It is for 2009 Gen 2 prius, it looks u have 8kwh , how is the set up, i am still working over it. thanks
  7. stefano5777
    stefano5777 Member
    380
    47
    St. Petersburg Florida
    You should be asking ericbecky that question since he is a installer of these systems with vast knowledge and experience.
  8. mrbigh
    3,686
    699
    Long Island, NY
    Do they have an specialized part number for this type of Prius rear springs? Is it a custom made part or an adapted generic one?
  9. playcool-7
    Raleigh nc
    It is a custom made, for prius. thanks
