Electrical/Relay Clicking Sound
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by nicolengr, Jun 1, 2011.
  1. nicolengr
    nicolengr Junior Member
    Kansas
    Hi everyone, I was wondering if you could help me.
    My 2010 prius is making a strange sound, and has been since day one. I have looked around on the forums and have seen a few people mention it but no solutions/explinations.
    It makes a "Clicking" sound sometimes that can be heard inside the cabin and sounds like it is coming from the center dash. It is definitly NOT a squeaky dash or door panel or anything like that. It is definitly electrical in nature. It almost sounds like a very fast clicking relay or maybe another electrical component. It is fairly high pitched (not like the inverter whine, though) and definitly clicking (maybe buzzing), not constant. It sort of sounds like a cricket. I am working on adding some audio/video to this post, should have some up today.
    Here are some things I have noticed about the noise:
    1. Only happens when gas pedal is depressed, not when braking or coasting.
    2. When the display is in "Eco" it happens loudest and consistently when the bar is 3/4 of the way full, but it can happen (although the clicking is slower and less consistent) at 1/2 or just before the power section of the bar.
    3. The car must be "warmed up" i.e. doesn't happen right away, car must be driven for 10-15 min if engine is cool.
    4. Seems to be happening more/more quickly after starting the car in the hotter weather (I purchased my car in Feb.)
    Hope you can help! I haven't taken it in yet, I was tying to get some ideas before talking to the dealership.
  2. nicolengr
    Kansas
    found a youtube video, this is exactly what my car is doing!
  3. bisco
    51,853
    what is it?
  4. PaJa
    PaJa Senior member
    678
    114
    92
    Czech republic
    I'm hearing the similar sound when i accelerate to higher speed around 120 lmh (75 mph), but it is not so constant and pronounced as your sound. I hear it from the passenger under dash area, where some ECUs are placed. I heared i from test car before my purchase as well, So it looks to be common (minimally for EU models).
  5. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    Sounds like something loose under your dash - like plastic rubbing plastic. Does it do it more when the a/c has been blowing really cold? The reason I ask is that mine squeaks and rattles more when the a/c has been on for a while - seems to contract the plastics? Just an idea.
  6. nicolengr
    Kansas
    It's in the shop today, the tech drove with me and agreed its not normal. They are having a specailist come in to look at it today, so who knows what he will say.
    It does not matter if the ac is on or off, it does it almost anytime the engine is warm and the eco bar is 3/4 full, I assume it relates to engine rpms'. It was more sporadic when the weather was cooler. It doesn't sound like plastic, but who knows.
    I didn't hear it when I test drove the car, but the engine probably wasn't warm enough. Surely something this loud, inconsistent, and annoying isn't normal. Also not many people have said they have the noise, making me think its not normal.
  7. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    It is not normal for sure... thanks for keeping us up to date.
  8. nicolengr
    Kansas
    I don't think its common, and I hear it from the same place.
  9. nicolengr
    Kansas
    ust got my car back from Toyota. It seems they have fixed it! They called in a specialist (after their technicians couldn't diagnose it) and he said that it was a rattle of the "heater hoses and clamps" caused by the engine/antifreeze temperature combined with the RPM's of the motor. They rerouted the hoses and installed the clamps in different locations. Currently, my car is not making the noise. They said if it comes back let them know and they will try again.
    So, if your car is making this noise - its not normal but it could be a common problem, seeing as to it was an engineering/design issue. If anyone is having this problem and takes their car in and the technician can't figure out what it is my service manager said they can reference this claim number: 111570301, to see what my service dept. did to fix the problem.
    Good Luck!
  10. James Scott
    James Scott New Member
    Nashville
    Hi Nicole,
    Was your issue resolved completely after the work was completed?
    I ask because I have a 2015 Prius 2 and it’s doing the exact same thing.
    It’s driving me insane.
    I would very much appreciate hearing if there was anything that was done to fix that clicking sound. It definitely sounds electrical, and definitely has nothing to do with the type of surface the car is being driven on.
    Totally unpredictable.
    Thanks a bunch!
    -jS
  11. bisco
    51,853
    welcome!
    nicole hasn't been here for 5 years. maybe take a look at your hoses and clamps like hers
