how to tell what kind of lights in a 2006 prius?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by erkman, Jun 7, 2011.
  1. erkman
    erkman New Member
    virginia
    I thought the HID lights had a blue tint, mine do not.. I assume they are halogen?
    I have the blinking/going out light issue... If toyota thinks I am going to give them $500 for changing a light bulb....
    nope
  2. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    If your car has fog lights, you have HIDs.
  3. LIPriusFreak
    LIPriusFreak Can I haz JDM?
    449
    34
    Long Island, NY
    stock HID has a blueish tint but its more white than anything. and yes if you have stock fogs, you have HIDs
  4. kenmce
    kenmce High Voltage Member
    1,552
    525
    NY
    The Toyota HIDs are not particularly bluish.
  5. erkman
    erkman New Member
    virginia
    got it thank you
  6. F8L
    19,011
    4,083
    Grass Valley, CA.
    If you continue to have problems with your HIDs (if you have them) and Toyota won't help you out then I would suggest changing out the stock ballast and bulbs and going with a quality aftermarket kit. They can be purchased for $35-$150 and are fairly easy to install.
