I found this in my oil
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Lather, Jun 7, 2011.
  1. Lather
    Lather New Member
    27
    Anyone recognize this? I found it in the oil after I changed it.
    thanks,
    51,840
    looks scary but probably an extra part left in the pan by accident.
  3. Lather
    Lather New Member
    27
    Hopefully, but I've got 90k on the car. If it was a leftover manufacturing part, I think I would have found it before.
    Plus, the wear pattern on top is very defined. It looks like it had a function.
  4. fotomoto
    fotomoto Senior Member
    5,632
    3,810
    So. Texas
    Unless you witnessed it come out, there's no guarantee that it wasn't in the drain pan before hand or fell into it from another source besides the draining oil.
  5. Hal W
    Hal W New Member
    872
    53
    Grand Forks,B.C. Canada
    Looks like the hardened end for a push rod?{ Valve push rod} Do you have noise in the valve train? Hal
  6. bisco
    51,840
    could be a moscam lifter tip, but how would it get in the oil pan?
  7. tomlouie
    tomlouie Member
    118
    Boston, MA, USA
    2023 Prius
    But the wear on the part don't look look like it's been banged around the engine a few times either. I'm guessing it was put in the pan by someone by accident, and it's never moved since.
  8. Lather
    Lather New Member
    27
    Personally, I hope it's not an engine part but I can't think of any other source. I'm the only one that's changed my oil since the dealer did some maintenance at about 60k. There's some wear in a ring around the side but it only goes halfway around. The opposite side is worn at the base.
    I don't really hear any engine noise but my mileage dropped about 5mpg. I also changed the air filter and pumped up the tires today so I don't know if the mileage change is permanent. (I drop the tire pressure in the winter for traction. Since it snowed last weekend, I wasn't sure it was spring until yesterday when it hit 90.)
    I guess I'll have to take it in and play Prius trivia with my dealer. Hopefully it stumps them. I thank everyone who offered an opinion.
  9. M8s
    M8s Retired and Lovin' It
    614
    113
    33
    Colorado and Arizona
    I was thinking the same thing, but wouldn't it then have a hole in the center for oil passage? (Besides, I'd bet the Prius has overhead cams, not pushrods.) Still, the wear pattern looks like it's part of the heads/valve system. Are the oil return passages large enough to allow something that size to drop into the oil pan? I'd do a compression test to start.
  10. tomlouie
    tomlouie Member
    118
    Boston, MA, USA
    2023 Prius
    Maybe it fell into your oil collection bucket and has nothing to do with your car?
  11. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    It's a vernier caliper...
  12. J5A
    J5A Active Member
    592
    83
    Severna Park, MD
    At least it's not a finger in your chili :D
    or..maybe it's like finding one.
  13. Britprius
    Britprius Senior Member
    5,194
    1,921
    Herefordshire England
    Looks to me like a gear change indent plunger from a gearbox (non Prius) even has typical wear pattern on tip.
  14. Troyroy
    Troyroy Member
    373
    30
    Troy, NY
    It is strange...what type of car do you have???
    What work did the dealer to, that you mention in your OP ???
    The part does not look used.....is the small end broken or machined flat. ???
    I'm guessing that it's a oil pump push rod.
  15. Lather
    Lather New Member
    27
    Gear change indent plunger? Hopefully Google will be my friend.
    And, 05 Prius. Dealer does standard maintenance. I've done all but 4-5 oil changes and I've never had a problem with it. Not even now. I got gas this morning and after about 20 miles (typical commute), I'm at 55mpg.
    This would have been from one of the last two oil changes (I was making room for yesterday's change).
    The part is flat on the bottom and has wear marks on the top and sides.
    The odds are, it came from my engine. When I change oil, my face is a foot away from the drain plug and I like to think I would have heard/seen something unusual. But on the other hand, if someone can convince me that I'm an idiot, I will be grateful.
  16. San_Carlos_Jeff
    San_Carlos_Jeff Active Member
    871
    160
    Northern California
    2012 Chevy Volt
    Do you use a filter wrench to remove the filter? Maybe this doo-hickey broke off or fell out of the wrench mechanism.
  17. atroader
    atroader Engineer
    39
    Atlanta, GA
    If you get desperate and have the time, drain your engine oil, then see if this fits up in the threaded hole for the plug. Odds are it would have to line up perfectly to be ejected, unless it was at the edge of the pan by the plug or perhaps attracted to the plug magnet...
  18. bisco
    51,840
    are you married?:D
  19. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    It looks like the nozzle from my garden spray pump, I lost it 5 months ago, how did you get it?:cheer2:
  20. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    Thats pretty strange. It would drive me crazy.
    I would stop by the local dealer and go to the parts counter and politely ask for a peek at the motor breakdown schematic. There very nice at my local dealer parts counter and show me schematics every time I have asked.
    For some strange reason I think its part of the VVT Actuator assy.
    Let us know!
