Understanding battery life and issues
Discussion in 'Gen 2 Prius Main Forum' started by msprinkle13, Jun 8, 2011.
  1. msprinkle13
    msprinkle13 New Member
    North Carollina
    I have a 2007 prius, love the way it handles and the great gas mileage. There is one issue, the battery life keeps showing that it is loosing power very quickly, I believe this is the 12 V that operates the computer, it is viewed on the smart screen. My questions are: since my car is still under manufacturer warranty does this cover the 12 v battery or do I have to replace it myself? Can a standard 12 v battery be used to replace it? Is it really a gel battery and if it is does this mean it doesn't work well when it is hot? It has been warm lately, the car has been 100 degrees at the end of my work day everyday this week and I need to know if there is something I can do to reduce the risk to the battery when it gets hot outside.
    Thanks!
  2. brick
    brick Active Member
    1,083
    79
    Upstate NY
    Are you talking about the battery display on the energy monitor? If so, that's not the 12V. That's the big hybrid battery. If you sit in traffic on a hot day with the A/C running it will deplete very quickly. It takes a lot of power to cool a hot car.
    That said, if you are on the original 12V then it might be time to replace it. The two options I know of are a new OEM battery from the dealer, or an Optima yellow top and associated conversion kit that elearnaid sells. It's a tiny, unique battery so you can't exactly buy it off the shelf at Sears.
  3. msprinkle13
    North Carollina
    Thank you, so if I am in traffic on a hot day then the AC needs to be turned off, I can do that. I bought the car last fall, used at only 27,000 miles so I am not sure about the age of the battery. Is there a way to look at it and know if it is the orignal or a replacement.
  4. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
    No, it doesn't necessarily need to be turned off. It's just that running it, esp. on a hot day puts a big drain on it compared to not having it on.
    As I posted at http://priuschat.com/forums/gen-iii...3-same-prius-not-same-mpg-11.html#post1146128
    Using the AC helps w/cooling the HV battery. The intake is the vent next to the passenger side rear seat.
    I don't know of an easy way to check in the car if the HV battery has been replaced, but I find it highly unlikely that it has as it's warranted for 8 years/100K miles in your state (10 years/150K miles in CA and other CARB states) and not many people have had failures on 2nd gens prior to either warranty period. If it were replaced for some reason, I'm sure the previous owner would've had it done under warranty.
    You should able to see the work done by dealers on your car by registering at http://www.toyota.com/owners/ and putting in your VIN.
  5. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
  6. bisco
    52,351
    you're not having any issues. your car is running normally. there are no signs that either battery is deficient. relax and drive it like any other car. enjoy!
  7. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    The rule is: IF you feel uncomfortably warm, turn on your AC, your HV battery will thank you, too much heat can kill a HV Battery, over time. Don"t worry about what the MFD is displaying, the computers take care of everything. Just drive it. Later as you drive it, you will understand the car better.:cheer2:
  8. qbee42
    3,079
    This is the key answer - read it and take it to heart. You can't hurt the big battery, and you don't have to do anything special to manage it. Stop looking at the battery display and let the car do its job.
  9. brick
    brick Active Member
    1,083
    79
    Upstate NY
    No, you can do what you want. I usually crawl a few miles during my evening commute and most days I choose to roll down the windows instead of cranking the A/C. But I'm perfectly comfortable doing that up to ~90F, and I do it for fuel economy more than out of aversion to depleting the battery. (I have a pet theory that this is better for the battery under my circumstances, but it's only a theory and I don't think many around here share it.) Worst case, you deplete the battery and the engine will start running to take the load.
  10. msprinkle13
    North Carollina
    Thank you all for the helpful insights. I love driving the car and really appreciate its low gas mileage and the way it handles on the mountain curves where I live. Thanks again!
    Danny3xd likes this.
  11. bisco
    52,351
    welcome. i also appreciate the low gas mileage.
