automatic door locking after exiting car
Discussion in 'Gen 3 Prius Accessories and Modifications' started by everette13, Jun 9, 2011.
  1. everette13
    everette13 New Member
    los angeles
    automatically lock doors 30 seconds after exiting car.
    for anyone interested, i have found a maker of a simple module that can be easily added under the dash with five wires. easy to install and does NOT require integration into the databus (CANbus) system. installed on 2011 GenIII currently.
    The processor looks for the (+) ignition to be turned on, then waits for it to go back off. It then looks at the (-) door pin input and waits for the door to open then close again. At that point, there is an LED output that starts flashing slowly for 20 seconds. During this 20 second period the processor is monitoring both the ignition input and the door pin input - if either of them toggle their state the timer pauses, then starts over once both signals are clear. After 20 seconds the module outputs a short beep through an external hood mounted beeper and then the LED starts flashing quickly for 10 seconds, while the processor continues to monitor the inputs (and resets to the very beginning if something changes). At the end of this 10 second period the module outputs a (-) door lock signal. Finally, the LED output flashes at a slow rate to simulate an aftermarket security system.
    LED and beeper optional when installing.
  2. olyprius
    olyprius Member
    194
    31
    subscribed! :popcorn:
    Funny, I was just thinking about this the other day when I left the Prius thinking it would be an even smarter system if it would lock itself after you leave.
    Have you already done this mod and if so, any drawbacks to it?
  3. Judgeless
    Judgeless Senior Member
    1,821
    257
    Cleveland, OH
    Or you can install an aftermarket alarm system that does this.
  4. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    So that is what you were up to. Who is the manufacture?
  5. mpgz
    mpgz Junior Member
    24
    Indiana
    Hmm... Unless the system knows the key is not in the car, sounds like this is just an easy way to automatically lock your keys.
  6. 2ZR JDM
    2ZR JDM Active Member
    106
    142
    Redondo Beach
    Here's a alarm system with "Smart Door System", it arms and disarms automatically when you approach or leave the car. You're going to have to carry another annoying FOD tho
    http://www.easycaralarms.com/
  7. everette13
    los angeles
    you people are funny.
    if you think you'll lock your keys in the car (really??)- the same keys you don't have to take out of your pocket (again, really??), then you don't want this...... seriously, the keys stay in your pocket!!
    if you want a $400+ alarm system vs. a tenth of that, then you don't want this.
    anyone who wants the makers name and the precise pins to wire when installing, just PM me.
  8. BrettS
    BrettS Active Member
    290
    137
    Orlando
    I think the chance of locking the keys in the car is a lot lower for me, because I do keep my keys in my pocket than my wife who keeps them in her purse.
    However, there was one time that I did leave my keys in the car. I took the car to a car wash and had to get out while they ran it through the machine. I was afraid they'd shut off the car and not be able to start it again, so I left the keys in the cupholder. I got back in and drove to work and didn't remember that the keys were in the cupholder until the car yelled at me when I tried to lock it with the SKS system. That's one time I left the keys in the car out of probably hundreds of times that I've left the car in the 5 months I've it, however, if I had locked the keys in the car that would have made for a pretty bad day for me (and my wife, who would have had to drive 45 minutes out of her way to come rescue me).
    If this system works for you, then more power to you, but until it can detect if I've left the key in the car I think I'll stick to manually locking it.
  9. Judgeless
    1,821
    257
    Cleveland, OH
    With the Viper System if you lock your keys in your car, you can unlock your car with your cell phone anywhere in the world. Both my wife and I have the app on our smart phones. If I lose my phone and lock my keys in the car she can unlock it remotely anywhere in the world.
  10. twittel
    twittel Senior Member
    1,605
    148
    Mt. Pleasant, SC
    I keep the FOB in my pocket all the time while in the car. My wife keeps her FOB in her purse, but wrapped in alum. foil because sometimes she likes to keep her purse in the car rather than carry.
  11. k.s.c
    k.s.c Junior Member
    73
    SW Florida
    did anyone ever get the info from Everette on this?
  12. BSWEET
    BSWEET New Member
    52
    Suisun City
    Hi Everette,
    I am very interested in this relay. I would like any and all information you could send to me about this. I have the smart key on my Prius III and it is a pain sometimes because I have forgotten to lock it a couple of times.
    Thanks,
    BSWEET
