Most recent tank
Discussion in 'Gen 3 Prius Fuel Economy' started by wesayso, Jun 2, 2011.
  1. wesayso
    wesayso Member
    385
    35
    Hampton, VA
    I turned off eco mode for this last tank and pretty much drove the car in a normal manner not paying attention to maximizing mpg's. I got 50.4 mpg calculated. I'm happy with that and enjoyed driving more than when I'm constantly trying to maximize efficiency. :rockon:
    Montgomery and Electric Blue like this.
  2. mgb4tim
    mgb4tim Noob
    1,153
    111
    Pittsburgh, PA
    I don't drive to hypermile, by any means. I think 43 MPG is good for the hills I have to climb around here. I'd love to take the car on a trip someplace flat to see the numbers in the 50's or 60's
  3. ncfishboy
    ncfishboy New Member
    KDH NC
    Living at the beach it is all flat except the one bridge I have to cross going and coming from work. I get 55-57 mpg without trying, but when I try to get better mpg I still get 55-57.
  4. Crazyhorse6901
    Crazyhorse6901 New Member
    114
    Hampton,VA
    I live about 0.6 miles from work which effects my overall MPG however as of today on a tank of gas with one pip left I have 415 Miles which isn't all that bad since short trips kill the MPG.
    b100 likes this.
  5. wesayso
    wesayso Member
    385
    35
    Hampton, VA
    513.3 miles - last pip had just begun to flash
    9.630 gallons
    $3.549/gallon
    $34.18 total
    53.3 calculated mpg
    55.9 computer mpg on tank.
  6. Ajvdub
    Ajvdub New Member
    51
    La Crescenta CA
    Last tank, computer said 626.7 miles, 52.4 mpg.
  7. wesayso
    wesayso Member
    385
    35
    Hampton, VA
    How many gallons to refill it?
  8. nerfer
    nerfer A young senior member
    2,507
    237
    28
    Chicagoland, IL, USA, Earth
    I hate to have to say this, but why even bother driving? A 1 km walk is good for the body and mind, and takes less than 15 minutes (you're probably already walking 1/4 that distance when you consider the parking lot and such). If you have a major street to cross, I assume there's a light someplace nearby, in reality it's probably nearly as safe on foot as it is in a car.
    I also have a short commute, 2.9 miles, and I bike that as much as possible. The winter is out with the snow banks and dark, but otherwise I rack up about 500 miles a year on the bike, all 3 miles at a time. You're right about it killing the mileage, so I figure I turn a bad thing into a good thing by getting some exercise to help the cholesterol levels.
    Montgomery, mengoni and Mendel Leisk like this.
  9. Ajvdub
    Ajvdub New Member
    51
    La Crescenta CA
    I took it to the bitter end, 11.2 to fill
    [​IMG]:rockon:
  10. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    Wow, that comes out to 55.9 mpg, usually I get about 3 mpg less than what the computer mpg guage reads. Look like your guage reads the other way....
    alfon
  11. coach81
    coach81 Active Member
    758
    116
    Louisiana
    Sure beats the 13-14 MPG on the Frontier... LOL
  12. Mendel Leisk
    41,787
    I'd be sceptical of that calc. Maybe the pump shut off early? I've found every tank calc not as good as what the dash display reads, anywhere between 5~9%.
    ralleia likes this.
  13. wesayso
    wesayso Member
    385
    35
    Hampton, VA
    517.1 miles
    9.734 gallons
    $3.439/gallon
    $33.48 total
    53.1 calculated mpg
    53.9 computer mpg on tank.
    $0.065/mile
  14. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    miles: 148.9
    gal's used: 2.067
    MPG Guage: 62.0
    MPG Calculated: 72.036
    Reg. Unleaded with 10 Ethanol
    Hwy 90% 10% City
    Note:
    When I filled last time at slow speed when the pump stops thats it...
    So after 148.9 miles the guage was still reading full. Normally it would drop down to 2 -3 pips from full.
    So I went to the same gas station I had previously filled up, a different pump but the same type and filled at slow speed, first click that was it....
    So I am baffled why. I could see if it took 2.5 gal's but a little over 2 gal's. I have never had this happened. Also the gas guage still read full.
    This is the first time in over 51,000 miles this has ever happened. over
    10 mpg more than the computer read out.
    alfon
  15. DBaum
    DBaum Junior Member
    Pennsylvania
    2020 Prius
    L Eco
    My last tank the my best ever. 60.6 mpg / 2 blocks left ( I don't like to fill up when its close to empty ) / 501.0 miles driven. Mostly standard driving habits.
  16. wesayso
    wesayso Member
    385
    35
    Hampton, VA
    517.3 miles
    10.074 gallons
    $3.379/gallon
    $34.04 total
    51.4 calculated mpg
    53.7 computer mpg on tank.
    $0.066/mile
  17. GreenClipper
    GreenClipper Senior Member
    116
    Tulsa, Ok.
    My average mpg shows that "extra" high FE is not a constant that's for sure. We took some trips when the car was new, (dead of winter) where mileages, at least one direction were under 40mpg. Evidently I am unwilling to "pay the price" consistently, to rectify that initial low mpg, because my average stays just under 48. I did do a 170 mile trip yesterday from the Ozarks to NE Okla. and went way over any previous mpg I've ever got. 65.1mpg for 170 miles. Took 2.61gal. to top up tank after that journey. However that was/is obtained at a "price"! After refueling (beginning), I got out on a four-lane hwy and set the cruise at 60mph............for 170 miles. No stops, and maybe only took off cruise one time. This distance was basically out of the Ozarks, so not too many hills. But it appeared to me it was the consistency that got that mileage. I can do such to see what the possibilities are of the car, but this is not something I can do on an ongoing basis. Maybe over time, but I now am nearing the 36K mark, and haven't got an "average" over 50mpg yet..... Anyway if you have the patience to let everyone pass you out on the interstate, you can rack up some impressive figures! Probably didn't cost more than 20 minutes time increase to do the slower speed. But it sure wasn't pleasant to get passed by everyone on the road, although it made the drive more relaxing.
  18. wesayso
    wesayso Member
    385
    35
    Hampton, VA
    477.2 miles
    9.437 gallons
    $3.489/gallon
    $32.93 total
    50.56 calculated mpg
    52.8 computer mpg on tank.
    $0.069/mile
  19. wesayso
    wesayso Member
    385
    35
    Hampton, VA
    440.6 miles
    9.154 gallons
    $3.589/gallon
    $32.85 total
    48.13 calculated mpg
    51.1 computer mpg on tank.
    $0.0745/mile
  20. minh240z
    minh240z New Member
    Placentia
    First tank with the new Prius I got 49.8 MPG calculated.
