Can "Cambridge Crude" Sludge Revolutionize EV Battery Charging?
Discussion in 'Environmental Discussion' started by hybridtwins, Jun 13, 2011.
  1. hybridtwins
    hybridtwins Member
    202
    Van Nuys, CA
    2002 Prius
  2. DonDNH
    DonDNH Senior Member
    1,711
    655
    Nashua, NH
    Four Touring
    Very interesting technology. I might have named it Cambridge Crud however.
  3. bisco
    51,838
    nice to see people thinking out of the box.
  4. cyclopathic
    cyclopathic Senior Member
    3,292
    547
    2014 Prius c
    wonder what the energy density they achieved..
    Li-Ion is 0.90-2.23 MJ/L and Gasoline is 35 MJ/L. Liquid natural gas is 25 MJ/L. E85 is 31 MJ/L
    with ~35% ICE efficiency you figure it has to be 15-25MJ/L range to be comparable
  5. austingreen
    austingreen Senior Member
    13,671
    4,209
    Austin, TX, USA
    cool tech with future potential.
    Semi-Solid Lithium Rechargeable Flow Battery - Duduta - 2011 - Advanced Energy Materials - Wiley Online Library
    This allows the anode and cathode to be scaled for the power needed in the battery, but the energy is in solution and can be stored in a tank. You can charge the semi-solid energy carrier on-board or off board. This seems like it has huge potential for cars and electrical buffering on the grid. It sounds like it will be a while before it is commercialized.
  6. cyclopathic
    3,292
    547
    2014 Prius c
    yeah it has the potential to solve current EV shortcomings: long charge time and range. Given that pumping in/out would take minutes/not hours and 5-20 time density would give 350-1400mi range in current packaging.
