Transaxle Replacement
Discussion in 'Gen 2 Prius Technical Discussion' started by Patrick Wong, Oct 10, 2008.
  1. Patrick Wong
    18,200
    6,498
    Mod Note:duplicate posts merged, but the OP for the merged posts ended up time stamped later than this reply. Quoted is the text of the OP:
    Your post is the first that I've noticed showing a 2G transaxle replacement at such low miles. Please post any details from your repair invoice, including DTC logged (diagnostic trouble codes) and the part numbers/descriptions of replaced parts.
    Thanks!
  2. Berle
    Berle New Member
    Jamul, CA
    :mad:At 39,000 miles my 2007 Prius (bought new in January 2007) transaxle failed Oct 4, 2008. I was driving on the freeway and the master warning light came on and the vehicle stability control system warning light came on indicating I should stop immediately. We stopped and turned off the power. When I turned it back on all the warning lights came on and I couldn't shift into reverse or drive. We had to get a tow truck to take the care into our Toyota dealer. They determined it was a transaxle problem, but no details and it was replaced under warranty ($5k worth!). Are transaxle failures a problem?
  3. qbee42
    3,079
    Transaxle failures are a big problem. Fortunately they almost never fail. You just happened to have a bit of bad luck, which is why we have warranties.
  4. rigormortis
    rigormortis Active Member
    1,340
    26
    san jose, ca
    how long did it take to fix?
    did you have the extended warranty?
    did they give you a rental?
    with no extended warranty & warranty coverage of the transaxle at 60,000 miles
    do they still provide a rental?
  5. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    They're quite rare...we've only seen a few reports with over 1/2 million 2nd gen on the US roadways.
  6. Celtic Blue
    Celtic Blue New Member
    2,224
    139
    Midwest
    Considering how easy it is to total the vehicle, I would anticipate there being an excess supply of salvage transaxles for any who might have theirs fail outside of warranty.
  7. galaxee
    galaxee mostly benevolent
    9,810
    469
    MD
    DH knows of tw 2g prius transaxles being replaced. only one had an actual problem with the transaxle, the other was a guess from tech support. both in warranty.
  8. joe53
    joe53 New Member
    Massachusetts
    Just had mine replaced at 115K. Fortunately, Massachusetts is a California Emissions State (along with 8 other states-------150K mile or 180 months warranty on transaxle and hybrid battery, eyc.) and it cost nothing. Just got it back today and have driven only 9 miles. So far, so good. It's performing very well. Hope it continues. If I had had to pay for the diagnostic work abd the replacement, etc, it would have cost 7K. Bought it in NJ (NJ is also a California Emissions state) with 111,600 miles in October and it sat all winter while my son was away at college.
  9. M8s
    M8s Retired and Lovin' It
    614
    113
    33
    Colorado and Arizona
    Okay, so we had a reported failure on 10/10/08 and another one today. That's two failures (reported on PC) in a period of 32.5 months. I guess I can sleep tonight knowing that I've got at least two and a half years to go before another transaxle failure - hopefully not mine - occurs.
  10. brick
    brick Active Member
    1,083
    79
    Upstate NY
    There have been other reports, just not in this thread. (But you still shouldn't lose sleep over it, especially if you have done "early" transaxle fluid changes.)
  11. M8s
    614
    113
    33
    I slept like a baby.
    I had the dealer do a "drain and fill" at 20,000 miles and sent a sample of the old stuff to Blackstone Labs. The results (posted here somewhere) were just fine. (I'm still glad I sent in a sample; it sets a base line for comparison with later sample analyses).
