2005 Transaxle Replacement
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by mahen, Jul 15, 2009.
  1. mahen
    mahen Junior Member
    I have a 2005 prius with 125,000 Km and we lived in a country where we have only 5-6 prius. The toyota dealer has just started selling prius and we have to rely on our own for diagnostic etc.
    Two days ago while driving i got a M.I.L. "ON" condition.
    I went to a local garage and they diagnosed a DTC P0AA6 with information codes 526 and 613.
    Generator Mg1 Revolution -2944 RPM
    M2 Revolution 1024 RPM
    Mg1 Torque 0
    Mg2 Torque -28Nw
    Inverter Temperature (Mg1) 41
    Inverter Temperature (Mg2) 42
    Motor Temperature(Mg2) No2 42
    Motor Temperature(Mg2) No1 49
    I referred to the toyota Repair Manual and checked insulation resistance on the 6 terminals of the 3 phase alternating cables on the transaxle side and the body ground. Resistances on 3 terminals on the HV Generator side were all above 10 M ohm while on the other 3 terminals on the HV Motor Side, they were less than 1 ohm.
    As per the repair manual i need to replace the HV transaxle assembly.
    I want to buy one from a salvage car but i just wanted to know if i am right what i am doing and if there is anything i missed here as i am a newbie and the toyota dealer here are not reliable.
    I need your guidance about the replacement of HV transaxle assembly
  2. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
  3. joe53
    joe53 New Member
    Massachusetts
    I live in Massachusetts. I bought a 2005 with a 111K on it in New Jersey and brought it home. Love the car. However, I have had some recent problems and the RED Triangle Light, brake light, and another light came on so that it wouldn't start. I was advised yesterday that by a Toyota Dealer that I need a new transaxle. Fortunately, the car is under warranty up to 150K because Massachusetts, like New Jersey, is one of about 9 states to have adopted the California Emissions Statute which lengthens the warrant on certain hybrid components. I was lucky. Hopefully, after the dealer puts in the new transaxle, this will remedy the situation.
  4. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,519
    Santa Fe, NM
    You are lucky. The transaxle is usually considered to be a powertrain warranty item, 5yr/60,000 miles. Sometimes, but not always, will Toyota cover this as a hybrid component.
  5. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    512
    63
    Good for you! Which dealer is it?
  6. 3prongpaul
    3prongpaul Hybrid Shop Owner, worked on 100's of Prius's
    956
    730
    Boulder Hybids, Boulder, CO
  7. joe53
    joe53 New Member
    Massachusetts
    Surprisingly, it was Boch.
  8. joe53
    joe53 New Member
    Massachusetts
    Toyota did cover it. Otherwise, I would have been looking at a $ 4,100.00 bill. I've only put 15 miles on the car as I type this, but it really seems to be running well.
  9. 2009Prius
    2,705
    512
    63
    Indeed!
  10. bisco
    52,404
    that's not surprising. it's shocking!
