Which Brand Of 0w-20 Does Your Dealer Use?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by The Critic, Jun 22, 2011.
  1. The Critic
    The Critic Resident Critic
    3,193
    2,332
    CA
    One of my local dealers uses Service Pro Full Syn product and charges $65. The other dealer said they use a Mobil 0w-20 product and only charge $45, but are not sure if it is Mobil 1.
    What does your dealer use for 0w-20 and what do they charge for an oil change?
    MB860 ?
  2. dustoff003
    1,371
    335
    Waianae, HI (Oahu)
    But they will put in what ever you bring them.
    I am not sure of the cost of the oil change as of yet because they are free with Toyota Care. My wife's Tacoma is usually about $150 for a 5k mile service.
    Posted from my iPhone via the Tapatalk app.
  3. tumbleweed
    tumbleweed Senior Member
    4,067
    692
    Eastern Oregon
    The dealer here uses Toyota 0W20 or whatever you bring in, they will use your oil if you prefer. I think the only 0W20 oil Mobil makes is Mobil 1 synthetic.
    EDIT: Actually there are two Mobil 0W20 oils, see next page posts 12 and 13. Hint get the one with the green cap.
  4. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    I've used a few different dealers for oil/filter service (depending on who had the lowest web coupon special at the time), and they all use Toyota 0W-20. Cost around $40 (including synthetic oil premium).
  5. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    My dealer uses the Toyota 0W-20.
  6. LulzChicken
    LulzChicken Prius Enthusiast
    791
    135
    Alabama
    I assume my dealer uses Toyota 0W-20. The last oil change I got was about 2 weeks ago. Before that, maybe a year ago. A year ago the oil changes cost 65 bucks or so (price of their oil) and I went about two weeks ago and it was only 45 bucks. They told me that they started buying in bulk a while ago, which made prices cheaper. I kinda wanna buy my own oil and give it to them to use. Are there any other brands like Mobil 1 that are actually better than the Toyota oil?
  7. Mendel Leisk
    41,210
    The Toyota 0W20 is hands-down the cheapest 0W20 I've ever seen, maybe barring sale prices. Up here I picked some up at the dealership for somewhere between 5 and 6 dollars per liter. Cross the street at Honda their 0W20 is around $9.
    The only other 0w20 I've seen locally is Pennzoil (sic), typically on sale at ~$10 a liter, or more, regular price. Costco sells no 0W20, D.O. for Canadian Tire.
  8. wick1ert
    wick1ert Senior Member
    1,311
    183
    Delawhere
    I used Amsoil for all my vehicles. Mainly because it's a heck of a lot cheaper than the Harley oil at their Dealership, and since I've already paid for their "membership" I figure I may as well order everything at once. I think it was roughly the same price, after shipping, as the Toyota oil 2 years ago when I looked at their price (around $8/qt). If 'Yota has come down a bit, I will probably switch back once I finish my Amsoil. I have enough for 1 more change, and I think 1 more filter at home also.
  9. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    If you are paying for it, they use the Toyota brand oil, otherwise if it is a freebie, they use Mobil 1.
  10. tumbleweed
    4,067
    692
    Eastern Oregon
    No one knows which brands are better. There have been no objective tests.
    The API and ILSAC rating systems don't seem to give much useful information about quality. Under those rating systems Mobil 1 or Toyota oil (probably made by Exxon Mobil or Eneos) will have the same rating as any other brand. ACEA, the European standard, tells you a little more about some viscosities but all of the 0W20 oils are only rated for A1/B1 by that standard.
    I use Mobil 1 because it is available and I have been able to find it on sale several times for $5/quart. My UOA tests have come back with good results and that's about all we have to go by.
    I suspect all of the 0W20 oils will perform about the same. I have never heard of a documented case of an engine being damaged because someone used the wrong brand of motor oil.
    Here is a fairly good reference for the three rating systems: Motor oil - Wikipedia, the free encyclopedia
  11. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    My dealer uses 0w20 synthetic oil Toyota brand. I don't
    believe that Toyota manufactures their own oil so
    it must be a major oil company.
    I do all my oil changes and I use Mobil One 0w20. I used Valvoline
    0w20 once when I could not find Mobil One.
    I change every 10,000 miles with a new oil filter and add only 4 quarts in the crankcase so not to overfill.
    Seem like when I drain and fill up a gallon container for recycle
    it nearly fills to the top minus maybe 8 ounces or so....
    alfon
  12. rrolff
    rrolff Prius Surgeon
    1,610
    246
    So Cal
  13. tumbleweed
    4,067
    692
    Eastern Oregon
  14. Mendel Leisk
    41,210
    Click on the "Compare to More Products" button in above, to include extra bottles, including the green cap one.
    My take, just from a marketing standpoint: I think they've got too many choices. Confusing for the consumer.
    In our area it's mainly specialty automotive stores selling 0W20 (only seen PennZoil), and high cost, typically around $10CAN per liter. Bigger automotive outlets, and places like Costco, are like blind dinosaurs as far as 0W20 is concerned.
  15. The Critic
    3,193
    2,332
    CA
    Dealer said they use Toyota 0w-20 and are willing to do an oil service for $42 out-the-door. Deal.
  16. LulzChicken
    791
    135
    Alabama
    That's a good deal. I say take it.:cool:
