P0A2D, Technical opinion deeply appreciated
Discussion in 'Gen 2 Prius Technical Discussion' started by Ilona, Jun 23, 2011.
  1. Ilona
    Ilona New Member
    17
    Rochester, NY
    I would appreciate somebody's second opinion on this issue. I understand that it is difficult to write something with such a limited information. I will gladly respond to any additional questions (if I know the answer).
    Thursday morning – got in the car, no problems, drove 2 miles, master warning light, VSC, (!) and hybrid system warning popped up. Car drove normal. Lights stayed on all day.
    Friday morning – VSC and (!) disappeared. Master warning and hybrid light still on. Drove 2 miles. VSC and (!) popped up again. Stayed all day.
    Saturday, Sunday, Monday – same routine.
    As long as car is cold in the morning (first two miles) no VSC and (!).
    Took to dealer:
    “Inspection of vehicle shows code P0A2D drive motor a temperature sensor circuit high. Many of the connectors on the wiring harness to the hybrid motor are broken or poorly repaired. Vehicle has had prior damage. It is recommended to replace the hybrid transaxle harness and transaxle.†Cost - $6,125 plus tax.
    Additional info – car drove 4 mph (I was making sharp turn) and electric motor was not spinning when malfunction occurred for the first time. Very high temperature recorded in ECU. I drove under 30mph prior to it.
    Dealer will replace all harness on Monday. If it does not help I will have to pay for new transaxle and labor. I do not have money for it. I do not know what to do.
    They recommend that I get rid off the car. Can't do either.
    They say that transaxle may need to be replaced because “female connector†inside of the transaxle is MELTED and since it is integrated with transaxle, it cannot be replaced without replacing all transaxle. They think that the fact that the connector is melted may indicate more serious problem.
    Car was salvaged in 2007 with 112 miles on odometer and repaired in January 2009. Drove over 26,000 miles since then. No problems except for occasional problems with wiring going to ABS / brake system on rainy days (malfunction lights).
    Can’t sleep, can’t eat.
    Question:
    1. Is it true that the connector inside of the transaxle cannot be replaced?
    2. I can’t understand how could hybrid system overheat after driving for only 2 miles at very low speeds. Any ideas?
    Car was coasting most of the time. How could ECU record such an incredibly high temperature?
    It happens consistently every single morning, so there is a pattern to this problem.
    I asked dealer to inspect all hybrid cooling system for possible leaks / other problems. No issues found.
    All “technical†responses will be deeply appreciated.
  2. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
    How do you know that the "electric motor was not spinning"? Do you have something to monitor MG1 and MG2 speeds? Please see Toyota Prius - Power Split Device (try out the simulator and mouse over the sections of the animation) and Graham's Toyota Prius for info about the power split device.
    I don't have any technical advice for you but that's the risk you take when you buy a salvage vehicle. There's no warranty and who knows how good of a job the repair was or whether it suffered water damage?
    Without knowing more about your vehicle, I wouldn't spend $6K on a salvage vehicle.
  3. uart
    uart Senior Member
    4,220
    1,211
    Australia
    Yeah I'm pretty sure the OP just meant to say that it wasn't running in EV mode when it happened. :)
    Hi Ilona, not that it makes any difference to your problem but at least one of the motor/generators is spinning whenever the car is moving.
    We've heard stories like this before, from other users with salvaged Prius's that had poorly repaired wiring harnesses causing problems. I think that at least one of these was repaired at an independent Prius specialist for much less money than the dealers quoted. Hopefully someone else can chime in with some more information or recommendations of independent Prius specialists in your area.
  4. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    As for technical answers to your questions none of the PC members could possibly answer these questions. It was your obligation to totally inspect or have it inspected before purchasing this salvage vehicle. High voltage is delivered to the area of your concern, and especially high amperage so the melting od a connector would not be unusual. This can occur at 5MPH, gliding or not. Your obligation when you got these warnings on the dash was to STOP driving immediately. You did not. Your basic problem is monetary, if I were you I would get rid of this elephant. Also, your next car, read the owners manual.
  5. vertex
    vertex Active Member
    672
    144
    new york
    2018 Prius Prime
    The connectors are replaceable. I replaced them on my Prius when I rebuilt it. They unscrew from the transaxle. By the way, I have the same problem when we have heavy rain, which happened here yesterday, third time in the last 6 months. I would not replace the cables. I would replace the connectors if they are broken, and replace the melted part in the transaxle. Also, you can check which connector has the sensor that is giving you the problem, that will tell you which connector needs to be fixed. The problem is probably a bad connection, and not the transaxle.
    SFO, andyprius, Ilona and 1 other person like this.
  6. Ilona
    Ilona New Member
    17
    Rochester, NY
    Regarding electric motor spinning - dealer read to me what ECU had recorded when mulfunction happend.
    Thanks for reply.
  7. Ilona
    Ilona New Member
    17
    Rochester, NY
    Thanks for reply.
    I did not write that neither MG1 nor MG2 or ICE was working. Based on what the dealer said I understood that MG1 was off which is pretty normal when car slowes down, I guess. One way or another, it does not matter. What matters is the information that none of MG1, MG2 or ICE was working hard enough to cause temperature in the circuit to rise. Assuming for a moment that it is not a harness problem either, what else could cause temperature spike in such a short time (3-4 min of driving at a very low speed)?
    Sorry for my bad english.
  8. Ilona
    Ilona New Member
    17
    Rochester, NY
    I STOPPED IMMEDIATELY. I took it to the nearby Toyota dealer and they said that car is SAFE TO DRIVE but will need to have the repairs done in the near FUTURE.
  9. Ilona
    Ilona New Member
    17
    Rochester, NY
    Thank you vertex. That was actually helpful. I noticed that you are located in new york. Do you know by any chance any place, other than dealership, where I could tow the car to get second opinion? Do you live in NYC or other part of the state?
    Your response will be deeply appreciated.
  10. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,518
    Santa Fe, NM
    MG1 did not over heat. P0A2D indicates an open circuit in the temperature sense, i.e. connection was lost, something that is easily explained by a shoddy repair to an electrical connector. If something was actually overheating, you would have P0A2B. I expect that life inside the transaxle is normal, it is just the delicate sensor wiring outside that is messed up. We are not talking about HV/high current wiring here. Start with having the connector fixed. It might be simpler to look for a local shop that does auto electric.
  11. uart
    uart Senior Member
    4,220
    1,211
    Australia
    Hi Ilona. In my previous post I mentioned recalling at least one other user with a salvage Prius having similar problems but at the time I couldn't locate any relevant posts.
    Anyway here's one from someone who had what is possibly a similar problem to yours. This particular person ended up towing her Prius all the way from Colorado to Indiana to get the problem fixed (for about $1000 as compared to the $9000+ that the dealer quoted). I know this is not near-by for you either, but maybe the story will give you some hope. :)
    See http://priuschat.com/forums/gen-ii-prius-technical-discussion/75575-i-robbed-3.html
    Maybe someone will chime in soon with some recommended independent specialists a bit closer to you.
  12. vertex
    672
    144
    new york
    2018 Prius Prime
    Ilona:
    I am near the Tappan Zee bridge. I don't know any mechanic that I can recommend here. The only ones that I know are at least 1000 miles away from both of us. However, I have first hand knowledge of how to make these repairs. I would find someone that specializes in auto electrical system repairs. Have them repiar the broken connectors. I bought the connector parts from Saddleback Toyota in Phoenix. They were helpful in identifying the broken connectors. The only thing that you cannot by from Toyota is the replacement contacts for the connector. They do sell them as "pigtails" but they overcharge by 100X there value for that. I did find a source for the pins, and have many extras. I can provide them, if you need a few pieces. Usually, the old contacs can be reused, unless the contacts were crushed.
    SFO and Ilona like this.
  13. vertex
    672
    144
    new york
    2018 Prius Prime
    Ilona:
    I would guess that the problem is an open connection on connector M10 either pin 1 or 4. This is on the front of the transaxle. This should be relatively easy to fix.
  14. Ilona
    Ilona New Member
    17
    Rochester, NY
    Seilerts, you ROCK !!!
    This is exactly what I needed to know.
    Thank you.
  15. Ilona
    Ilona New Member
    17
    Rochester, NY
    You are the best! I may have to share this info with the dealer on Monday. Hope you do not mind.
    Consider yourself officially "hugged" :).
  16. andyprius
    2,212
    188
    I apologize for being so strident in my remark, my tone was unnecessary. Please keep us informed. :cheer2:
  17. vertex
    672
    144
    new york
    2018 Prius Prime
    Ilona:
    You may have problems with the dealer. They will probably try to get you to change the harness, rather then repairing it. Don't fall for it. Good luck, and let us know how things turn out.
  18. douglasjre
    douglasjre Senior Member
    2,172
    716
    Null, NL
    Where was the problem after all?
    SFO likes this.
