Generation 1 Oil Change; Need new gasket / special wrench?
Discussion in 'Generation 1 Prius Discussion' started by BentSpace, Jun 24, 2011.
  1. BentSpace
    BentSpace Member
    195
    Reno
    Have 2002, doing oil change. I've seen the repair manual for a 2005 which say to put a new gasket on the drain plug each time you change oil. Does the repair manual for the 2002 say the same thing?
    Is it really necessary / do you guys change it each time?
    What about the oil filter wrench is that necessary?
    Last time I changed oil I managed to loosen it with a large adjustable pliers, but I suppose the oil filter wrench has the benefit of being able to torque the filter to the specs.
    Thank you.
  2. Patrick Wong
    18,210
    6,512
    Yes, Toyota requires that the oil drain plug gasket should be replaced each time the drain plug is removed. I buy the gaskets in qty and routinely replace them after each change.
    Whether gasket replacement is "necessary" depends upon whether you care about an engine oil leak, or not.
    If the oil filter is mounted very tight, then yes, a cap wrench is necessary.
    The spec when tightening the oil filter is 3/4 turn after the gasket contacts the engine machined surface. I usually tighten the filter 1/2 turn.
  3. BentSpace
    BentSpace Member
    195
    Reno
    I know some people here were saying that when they put 3.9 qts in according to the manual they were going over the full mark.
    I noticed something when trying to put 3.9 qts in there. The .9 qts is a little more than 28 oz, so I took a full qt and was pouring into an empty one and filled it up to 28 oz expecting the full one to have 4 oz left. Strangely it had about 6 oz left, which had me wondering if they gave me more than a quart or if the marks on the side were off. Not sure, but if the quarts contain sometimes more than a quart that could be why people are going over. However I ended up putting the whole 3 qts 28 oz in and it brought it up to full if not slightly over. Is that bad? Wondering how bad it could be, if the official instructions tell you to put 3.9 qts in there. On my '95 F350 the manual says that right after an oil change the level can actual be over the full and it's ok as long as it doesn't surpass the "F" in Full. Doesn't say that in the prius manual, but still wondering how important it is to fill it to full when changing the oil.
  4. Patrick Wong
    18,210
    6,512
    Good observation. It is certainly possible that the quart bottles are overfilled.
    The Prius engine can operate with the oil level anywhere between the top and bottom dipstick dimples. The reason that you might want to fill the oil level near full is if you want to have some reserve in the event the engine starts to consume oil and you are not in the habit of frequently checking the oil level.
    I usually fill 3.75 qts and the oil level is ~1/8" below the top dimple.
    Another issue that affects oil level is how much effort you exert and time you allow to drain the old oil. I have found that after removing the drain plug, if I lower the right (passenger) side of the car while the left (driver) side remains elevated with a jackstand, that more old oil will drain out.
    You are supposed to continue the draining process until you see only one drop per minute or so, but I am not patient enough to wait that long.
  5. Mendel Leisk
    41,865
    One trick is to start the drain, then go in for supper.
  6. jamesearthdrum
    jamesearthdrum Junior Member
    MA
    2002 Prius
    I agree with Patrick, a new crush washer, the "gasket" is cheap insurance. A new one will also help with the tendency to over tighten the drain plug. If you don't mind the expense, K&N oil filters have a 1" wrench fitting to facilitate removal. Only tighten by hand. Make sure you lubricate the new filter seal with clean oil. Over tightening can cause the filter gasket to distort which will cause a leak.
  7. BentSpace
    BentSpace Member
    195
    Reno
    Wow, it actually says that somewhere?
    If you take it to an oil change place they probably wait for it to drain all of a minute or so. :rolleyes:
    That's why I like doing it myself. Also one time I took my first car, a jeep cherokee, into a QLube or some such place and they managed to strip my drain plug. So they fixed it and soon after I left for college in colorado. I made it about 50 miles out of town before the engine blew up. Turns out when the put the oil pan back up, they left a shop rag in there. So yea, if you want something done right, you pretty much got to do it yourself.
    On some of my old vehicles I have let them drain over night. Though not sure if the extra drain time is beneficial as it's also leaving it open for dust and what not to enter the system.
    That's interesting.
    Officially (where did the 3.9 come from), are you suppose to drain the oil with the front elevated or the car level? Which way gets out more oil?
  8. DRACO
    DRACO Member
    362
    78
    Rancho Palos Verdes, California
    2002 Prius
    Sorry to bring up this old thread. But so what is the TRUE torque if one uses Toyota's fiber washer for the drain plug?
    Almost everytime I do an oil change on my Lexus ES300, and I forget, the fiber washer squeezes out the side at recommended 33ft lbs. When I do 18 ft lbs it does not squeeze out and does not leak. So what gives?
    I am reading 27-30 ft lbs for the 02 Prius. I can see that if it was aluminum washer but for the OEM fiber clad washer I think it is too much.
    Has anyone else seen their washer squeeze out at 27-30 ft lbs?
    TIA,
    Jim
  9. Mendel Leisk
    41,865
    Third gen Repair Manual says 27 ft lb, fwiw. I've not notice undue compression. Do the washers you get have extra thick coating?
    I don't much like the coated washers, for a couple of reasons. With a Honda I'm changing the oil on, I'd torque to the spec. value, and the next time I came to remove the bolt, it was practically loose. Seemed like the coating was compressing. I mentioned at a Honda parts counter, and they came up with plain aluminum washers, they stock both types.
    And with the Prius, the (coated) drain bolt washer always royally glues itself to the oil pan, when you're removing the bolt. I'm used to it now: loosen the bolt a couple of turns, then break the washer loose with a tap from a screwdriver/hammer, then carry on removing the bolt.
  10. DRACO
    DRACO Member
    362
    78
    2002 Prius
    They are Toyota Factory seal washers. Extra thick? I do not know, I do not have anything else to compare to except my Porsche Aluminum crush washers which require 51 ft lbs at the crank plug and 31 ft lbs at the tank plug.
    A long time ago when I had jiffy change the oil, they tightened to spec 33ft lbs (upon my demand, they complained it was way too much) and it leaked out the side.
    #10 DRACO, Dec 7, 2015
