So Long, 50+ MPG! It was fun knowin' ya!
Discussion in 'Gen 2 Prius Fuel Economy' started by priusham, Nov 16, 2005.
  1. priusham
    priusham New Member
    525
    Michigan - land of everlasting snowflake icon!
    Incredibly... the first snowfall here in metro Detroit is about a month behind schedule. :huh:
    Well, it's snowing outside right now. My typical 50+ MPG trip home looked suspiciously close to 44 MPG :angry: with the heater running and outside air temp @ 32 F.
    And it's not even COLD yet!!! :blink:
  2. A2Prius
    A2Prius New Member
    We only received proto-flurries here in Ann Arbor. It'll be interesting to know how a Michigan winter affects your MPG.
    A2Prius
    2006 Prius due to arrive in mid-January!!!
  3. catsbox
    catsbox Member
    295
    Bellevue, WA
    I have found that running the fan with the vent only (using outside air) and setting the cabin temp at 75 or so keeps me from having to use the heater at all. I do wear a coat when I do this, but it really helps save the mpgs!
  4. ThunderJon
    ThunderJon New Member
    69
    San Ho, CA
    I'm curious... since I can't compare where I am... how does the weather affect your mpg in a 'regular' car?
  5. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    I believe that if you run the fan at all with the temp set anywhere
    above "max cold", the heater core receives coolant and you get
    cabin heat anyways. So far I'm theorizing that using "recirc"
    should conserve that already-warmed air a little more, but that's
    often impossible because of the windows fogging up.
    _H*
  6. Maytrix
    Maytrix Member
    742
    Marlborough, Mass
    Only 32F and you are using the heat? Get a jacket! :p I have actually turned my heat on a few times, but just for a few minutes at a time. I fortunately park in a garage, so it's a reasonable temperature when I get started every day.
    On a side note, I've been keeping our house at 60F and just dressing warmer. Temps are about to drop form the 70 we had today to the 20's tomorrow!
  7. legendsguy
    legendsguy New Member
    31
    Kalamazoo, MI
    It's 25 and snowing like the dickens here. My mpg went down to 37 :angry: tonight while driving around. I guess I got spoiled with the high 40's average since we got it six weeks ago.
  8. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    well already had a below 50 mpg tank and currently sitting at 51.5 so holding out hope for this tank... go9ing from summer to winter formula gas immediately drops you about 10% here
  9. Prius Maximus
    Prius Maximus Senior Member
    956
    811
    Northeastern IL
    Much worse than the temperature is the wind here. 40 mph winds the last few days are killing my mpg. started at 55 mpg after 100 miles. 2 days later, at 300 miles, 46 mpg.
  10. bookrats
    bookrats New Member
    2,843
    Seattle, WA
    Be patient.... Before you know it, Spring will be right around the corner, bringing songbirds, tulips, and better MPG.
    But until then: Welcome to a Frozen Hell!
    (Uhh... unless you live in Arizona.)
  11. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    Jeff...
    as you well know we dont live in Frozen Hell,... we live in Soggy Heck
  12. Tideland Prius
    16,604
    I dropped from 4.5 to 5.0L/100km (53 to 47mpg) and it's still above 5°C/41°F
  13. HybridVigor
    HybridVigor New Member
    96
    Chandler, AZ
    So I just finished suffering through summer in Arizona with nearly three months of 105-110 degree high temps. I plan on enjoying MY vacation from seasonal hell. (I'm half tempted to start posting how great my mileage is now that my A/C doesn't run all the time, but that seems a little cruel...) Currently the snowbird population in Phoenix is enjoying highs around 80 degrees, lows around 55 at night, and lots of flat cruising space on surface streets.
  14. TidelandAZ
    TidelandAZ New Member
    62
    Arizona
    I started reading this thread with sympathy and feeling a little nostalgic for the White Christmas I was assured of when I lived in Michigan. But now I'm with you here in AZ, and read your comment, and I couldn't agree more!
    Actually, I try to keep the Auto A/C on such a high temp that it doesn't kick on much. As I was merging onto US 60 yesterday morning, I realized that the heat had kicked on to try and warm me up. :D
  15. bookrats
    bookrats New Member
    2,843
    Seattle, WA
    You're absolutely right, Dave -- I stand corrected.
    (A grey, Soggy Heck.)
  16. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    I got rid of a 2000 GMC Sierra SLT 4x4 - an unreliable POS - to get my Prius. In summer city driving when I didn't need the A/C, I could routinely expect 22 litre per 100km or about 13 MPG Imperial gallon.
    In winter at -40, stuck in stop-n-inch due to backed up traffic from the blizzards and Snow Routing, the defroster at full blast and the electric rear window defrost on, the same commute was more like 45 litres per 100km, or around 6 MPG Imperial gallon.
    I was still pissed off at getting "only" 9.8 litres per 100km in my Prius while stuck in traffic last January, but compared to what I was driving and what everybody around me was driving ... still much better fuel economy.
  17. priusham
    priusham New Member
    525
    http://www.w8kc.com/priusmileage.htm
    You can see my MPG since the 2005 was obtained almost a year ago.
    Keep in mind the slowly improving MPG figures are also attributable to the car "breaking in."
    I was only a mildly experienced Prius driver having owned a 2004 for just 12,000 miles, previous to getting the 2005.
  18. galaxee
    galaxee mostly benevolent
    9,810
    471
    MD
    dropped to 49.9 for the first time in a while, well not including when i let hubby drive ;)
    air temp on the drive to work today was 37, had the heat on medium, set to 72.
    bah. at least if it's gonna cool off into the 30s, bring some snow! <_<
  19. slortz
    slortz New Member
    316
    I bet you all couldn't wait till someone from southern CA chimed in with, "My butt was freezing this morning at 68F!" :D
    Just goes to show how truth is relative, I guess.
  20. jimgraffam
    jimgraffam New Member
    131
    Sterling, MA
    Got cold here (New England) this week (highs in 30s or low 40s lately). My first week with the Prius and was glad to keep it between 52-53 mpg. My wife borrowed it for a few short errands and did pretty well... even though she took me down to 51.3.
    I'm hoping to get it back to 52 before my first fill up :)
