LOUD Banging/Rattling at Start Up!!!
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Blind Guy, Sep 16, 2009.
  1. Much More Better
    Much More Better Active Member
    655
    163
    This happened to me this morning. Exactly as the OP described, normal behavior when the electrical system is booting up, and then this loud plastic clanging sound just as the ICE kicks in. Sounds like a spinning object hitting something else. Went away after 5-7 secs without throttle input. As if the problem wasn't bad enough, it's downright embarrassing if it happened in a mall.
    I didn't even take the car out yesterday. I did wash it though but I did not spray water into the engine bay. My car is always garage parked, probably 5 deg C overnight last night. 10003km
    Is this a random problem or is predictable? I was also dealing with a buzzing noise at startup (during the electrical startup phase) under the hood last week, but I'm thinking it's tied to the cabin fan. I'd hate to think of this car as a Cracker Jack box, a surprise under hood every time you fire it up. :(
  2. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    The good news is is that is seems to go away with age. I had it happen to once about a year ago and never since (14K miles now).
  3. Skoorbmax
    Skoorbmax Senior Member
    2,641
    265
    Western NY
  4. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    I'm sure I've read somewhere that it was a batch of dodgy coil packs which may have been replaced under warranty at service time?
  5. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    I think it's the ghost of Toyota Quality past...trying to escape.
    2 people like this.
  6. Much More Better
    655
    163
    So I explored the other threads and I'm blown away by how common this issue is. Like a few others, I moved by car down the driveway to wash my car, so the ICE ran for 3-5 sec before shutdown. Then repeat to put car back in. Then, next morning, BAM! You get that rough start very much like that youtube video.
    I'm glad to hear that some of you have only experienced this once. I had a weird squeak under the driver's footwell while stopped at a light. Somebody thought it was brake pump or actuator!? Haven't heard it for a couple months now. I'll chalk up the rough start to teething pains.
  7. dragonslayer8228
    dragonslayer8228 Junior Member
    Herndon VA
    I had this happen once last fall when it was about 70 deg F out at the time, probably about 18K miles, after sitting for 9 hours (8-5 work) after a 28 mile highway drive, and I thought the same about the whole animal under the hood thing. I was working kinda in the sticks at the time (figuratively of course not actually in the woods) so it seemed likely. It went away after running the engine for a litttle while and I was a bit shaken by it, definitely different from the annoying buzzing that my A/C made in the summer.
    Back in January I started my car up, 23K miles, 7 deg F, sat overnight after coming home from work (28 miles) loud knocking sound. I had enough time to pop the hood and stick my head in the engine compartment. The ICE was running smoothly and the nasty TACK TACK TACK!! sound was coming from between the ICE and the Inverter box right where that Transmission Input Damper Assy and the flywheel are.
    I took it to the dealer and they were certain they reproduced the sound I was hearing. I told the service manager I found that a little hard to believe being that it had happened twice in five months and the last time was one week before the service appt. I told him that I didn't blame them for it I just found that very hard to believe.
    Being a mechanic I totally understand not being able to reproduce a problem, it happens all the time and it's frustrating for the customer and the service provider. It may be they don't know whats wrong or honestly think that's the answer but I think there's more to it.
  8. Canard
    Canard Member
    223
    Ontario, Canada
    How many hundred threads are we going to start about this? :) Can we collate these down into one massive "My engine rattles sometimes" thread?
  9. tdm1103
    tdm1103 New Member
    Bay Area
    Hi FireEngineer,
    Did anything ever come of your noise? I washed my Prius last night and this morning when my wife left for work the sound happened when the gas engine turned on. We turned car off, repeated and the sound came again. We'll see if it continues. I am very tempted to call the service shop and have it looked at.
    Thanks
  10. 2010priusowner
    2010priusowner New Member
    37
    FL
    Possible solution if this is true my car from new always showed oil up to the full mark. I just changed my oil yesterday and put in the 4.4 quartes as specified in the owners Manuel. The oil level is exactly where this video states it should be which is below the full mark.
    Thus far prior to this oil change I have had two instances of this issue posted in this thread.
    Please see this link and video. Overfilled oil in a Toyota Prius. | evtalk
  11. TheSpoils
    TheSpoils Member
    304
    49
    New Jersey
    This is going to sound weird, I had that same issue today, and after washing the car last night too. I used a pressure washer, and gave extra attention to the front air damn and bumper. I normally use a bucket and hose. Not overly concerned about it, but a coincidence how a few happened after washing...
  12. Troyroy
    Troyroy Member
    373
    30
    Troy, NY
    Everyone is banging their heads about this. Here is my opinion.
    MG 1 is a AC Motor/Generator, I think what is happening for a very brief time 5-7 seconds. Or until MG 1 spins up the ICE. During this brief time.....somehow MG 1 is getting DC current.
    What we are hearing is a MG that is sputtering, not spinning, but rocking back & forth. This is what normally happens when DC voltage is feed to a AC motor.
    Unless you have heard this before during your life....you would never recognize the sound from coming from your engine compartment.
    For those who want to experience this.....take a AC motor, feed DC current to it...it won't spin,,just rocks back & forth. Magnify this by the amount of DC current going into MG 1,,,,,,you will get the idea.
  13. paprius4030
    paprius4030 My first Prius
    2,077
    296
    York,Pa.
    This has now happened to me 2 days in a row during the first start in the am. I guess there is nothing new from Toyota regarding this?
  14. 2010priusowner
    37
    FL
    Just out of curiosity since it is occurring consistently check you oil level, let us know what you find. Thanks
  15. whaler
    whaler New Member
    MI
    Had this happen to me for the first time today (about 34k miles on a 2010). The best way I can describe it is that is sounds like someone shaking a box of rocks.
  16. Troyroy
    Troyroy Member
    373
    30
    Troy, NY
    Try starting the car in a different pattern.
    Instead of your normal start........put the car in Aux mode for a few seconds. (Press the start button without your foot on the brake)
    After a few seconds......then start the car......foot on the brake,,press start button a 2nd time.
    see if this changes anything.
  17. paprius4030
    2,077
    296
    York,Pa.
    Oil is full but it is at the end of it's oil change cycle now that you mention it. It's got 9800mi since last oil change. I can't rmember when it did it earlier in the year how many miles the oil had on it.
  18. paprius4030
    2,077
    296
    York,Pa.
    Trouble is now it's been fine the last few days and it probably won't do it again for a few months. Maybe it's a mood thing:eek: LOL
  19. Troyroy
    Troyroy Member
    373
    30
    Troy, NY
    It's very possible that our Pri are female (only kidding girls) that would explain why they only do certain weird things when they want to, never when we want them to.
  20. TX10Prius
    TX10Prius New Member
    Blind Guy/and others...I have experienced this very situation. Have you had your oil changed recently? It is a stretch but I was leaving the house this morning...heard the same noise when I started the engine...as I drove down the highway the undercarriage oil panel/cover fell off and was lodged under the engine. There is a TSB on this...dealer will replace under warranty.
