04 Prius squealing noise left front wheel
Discussion in 'Gen 2 Prius Main Forum' started by wgrotheer, Jun 27, 2011.
  1. wgrotheer
    wgrotheer Junior Member
    Edmonds, WA
    Car suddenly started a high pitched whistling noise/metal on metal sound at highway speeds. It is intermittent, no noticeable pattern w/acceleration or breaking. Similar sound at lower volume when the shock/spring is depressed (pushing down on that corner of the car). Louder at low speeds.
    Thanks for any ideas.
  2. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,520
    Santa Fe, NM
    Sounds like a wheel bearing or something like a rock caught between the pad and the rotor. Are you planning a DIY repair or taking it to a dealer?
  3. wgrotheer
    Edmonds, WA
    If it's a rock & I could do it myself, that would be wonderful but am trying to get to my mechanic tomorrow so I don't damage anything.
  4. seilerts
    3,326
    1,520
    Santa Fe, NM
    Please do post the outcome, particularly if you are not using a dealership. People here ask about finding independent Prius mechanics all the time.
  5. wgrotheer
    Edmonds, WA
    Outcome - it was a rock inside the hub area that would get lodged & rub on the inner corner of the rotor. I now have a rock w/a very shiny edge. The mechanic had to remove the caliper, pads & rotor to get it. Total bill $95. Thanks for the advice.
    P.S. the mechanic - Superior Auto Service in the Fremont area of Seattle. I take the Prius & our Honda Element there for everything & have been quite pleased.
  6. seilerts
    3,326
    1,520
    Santa Fe, NM
    Cool, thanks for coming back. Can't tell you how many times someone asks for help and then we never hear back.
  7. MannyCT
    MannyCT New Member
    Connecticut
    Had the same horrendous noise -- high pitched squealing like super chalkboard scratching. I removed the decorative wheel cover -- after letting everything cool overnight -- and felt around behind the brake disk. There's a thin round metal piece that runs right up behind the disk; it must be a protective shield. There's enough room for a piece of gravel to lodge between it and brake mechanism. I moved my fingers along the space between the shield and the disk and a very small piece of gravel fell out. Voila; no noise. I hope that works for anyone else with the noise.
