Prius04
Discussion in 'Gen 2 Prius Main Forum' started by Ryan46, Jun 29, 2011.
  1. Ryan46
    Ryan46 New Member
    Winston-Salem
    Weird Air Condition Issue
    My 04 prius air condition blows hot air when I am stopped. Seems to work fine when we are moving. Took it to dealership, they said everything checks out.....? Any suggestions?
  2. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
  3. Ryan46
    Ryan46 New Member
    Winston-Salem
    Thanks.. I checked out that thread, gave me one thing to check, the radiator fan, however, I don't think my outside temperature goes up when we are idle, but I will watch it closely now. Thanks for the thread. I'm new to this, how can you get mechanics interested in your problem?
  4. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,518
    Santa Fe, NM
    There is a hybrid specialist in Sanford, Taylor Automotive. It's probably worth the drive.
  5. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    Warm the engine up and put ac on max cold. Open hood and see if both electric rad fans are moving.
  6. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    Also if the fans are rotating, are they blowing air out of the front of the car, or are they sucking air in, you can check this with a kleenex. The kleenex should get forced into the grill and stay there.
  7. spitinuri
    spitinuri Member
    317
    Inverter coolant pump could be going bad. When mine did I pretty much lost all ac when I was stopped. It is a warranty item.
  8. Ryan46
    Ryan46 New Member
    Winston-Salem
    What is the solution if the fans aren't moving or if they are rotating the wrong way?
    Also, I can see one fan pretty easy, its hard to see another, do I need to remove something to see the other?
  9. Ryan46
    Ryan46 New Member
    Winston-Salem
    Is there a way to check if inverter coolant pump is working properly?
