7500+ Mile Roadtrip in Prius about to begin
Discussion in 'Local Clubs, Events, and Road Trips' started by 102605, Jun 29, 2011.
  1. 102605
    102605 Junior Member
    31
    Check out the route!
    I am about to embark on a month long coast to coast journey. Does anyone have any advice for my 2010 Prius? I love the car but have not taken it longer than a few trips between San Diego and LA and Lake Arrowhead.
    I leave July 1 for the first stop at the south rim of the Grand Canyon. Can't wait!
  2. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    31
    I heard this could be a bit of a climb for the Prius so I am hoping it will handle it well. I will only have 1 passenger and a dog with me on this leg of the drive so my weight shouldn't be too bad.
  4. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    One month? Wow. I just high tail it for a day straight and cross it. :)
    Advice in general learned from many cross country road trips:
    In metro areas you don't know, tuck behind a semi truck.
    In general, don't tailgate. Not just because it is safer, but because you wont get as many dings in your paint.
    If you see a car on the side of the road, move over! One instance of a guy opening his driver door directly into the right most lane with a constant flow of high speed traffic and the other of a lady that decided to retrieve something she dropped on the road in the middle of the night. Blinking truck was all you could see until you see the reflection in her eyes as you whiz past at 90mph in the left lane...
    If you see a shredded truck tire in the middle of the road, brace the wheel and ram it. Bumper damage, and plastic shield damage is likely. But you wont swerve into a median or another car. In one month and 7500 miles, you will more than likely hit more than one so be careful.
    The sections between J and K... Well, fill up before you get to Wyoming and don't anticipate having anywhere to fillup while there if you are there at night. This is the state where I have almost run out of gas 2 times because all service stations off of interstate exits close at ungodly early hours.
    When driving through Kansas, do not go more than 70mph. Kansas is 65-70mph versus Nebraska's 65/70/75 speed limit. For a state that takes 8 hours to cross, it makes a difference. And cops have nothing better to do than hide out in the middle of the divided highway. It is the longest and most boring 8 hours, but do not try to make it shorter.
    And one closer to home, use B mode when going down the I-70 passes from Vail through the Eisenhower Tunnel.
  5. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    The Prius is a beast. It makes it up the steepest I-70 grades at full speed.
  6. fuzzy1
    10,588
    If visiting Badlands NP and Mt. Rushmore, spend at least a day in and around Custer State Park.
    I would suggest either adding more time, or cutting back on the distance. Don't spend more time driving than visiting and sightseeing.
    Three months after getting my Prius, we took a month long trip from WA as far east as Badlands NP, through CO including four days in Rocky Mountain NP, through AZ and into CA to visit friends before returning home, and visiting very many parks and other sites/sights along the way. This loop rolled up nearly 6000 miles, despite never getting even half way across the country. This was actually the third broadly similar loop in just two years, but the only one in this car.
    Your route could easily roll up much more than the expected miles, and cause considerable road fatigue. Try to spend a larger fraction of it not driving.
    Re: Mt. Evans:
    Mt. Evans was closed, but I did climb Pikes Peak up to the snow closure at the Devils Playground. No problem going up. Descent was a bit of a challenge due to traffic going too slow for B mode to generate much compression.
  7. Michgal007
    Michgal007 Senior Member
    1,321
    98
    Macon, GA
    In WY, you won't find gas stations for 200 miles in some stretches.
    Very true about Kansas highway being the most boring 8 hours. This is coming from someone who loved driving through Nebraska...
  8. 102605
    31
    Thanks for the tip. I would love to extend the time I am spending but unfortunately I can't. I think I will have enough time to soak in the scenery a bit but your right, this is a lot of driving! I'm also going to be driving a bit around Chicago when I am staying there with family. The miles will definitely add up.
  9. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    I've been up it in cars with less power than a Prius. IIRC, our 1983 Camry had 90 hp, when I was in the Air Force in 1961 I rode up in a friends well worn 1950 Chevy. 36 HP VW Microbuses and Ford Model Ts have been driven up it.
    It is surprisingly non-steep.
    If you try to do more than sit or walk a bit, you will have more problems at 14,000+ feet than the car will.:cool:
    Google Maps street view included the road and parking area at the top.
  10. mikewithaprius
    mikewithaprius New Member
    656
    103
    Rhode Island
    I'm sure you're cognizant of your oil change intervals, but if you forgot, change your oil.
  11. tomlouie
    tomlouie Member
    118
    Boston, MA, USA
    2023 Prius
    Make sure you tell family when and where you'll be, in case you get stranded and need assistance. Bring plenty of drinkable water. Check your car fluid levels and tire pressure before your trip. Use a gas price website like gasbuddy.com to find local cheap gas.
  12. mbartley
    mbartley Junior Member
    48
    LA County, CA
    Wow, I've been thinking about my upcoming summer road trip a lot, delivering a car (that gobbles up twice as much fuel as my Prius - yikes!) from Iowa back here to Orange County, CA. But wow, this is much more ambitious.
    I'm still deciding on my route. I'll probably go south and then follow as much of Route 66 as I like, but I may go to Colorado first.
    I just noticed on your Google Maps routing, between points H and I, it has you going past my starting point - Clear Lake, IA. I'll be there around August 1; I guess you'll probably be long past there by then.
    BTW - last weekend I took my Prius on its only road trip so far: to your corner of the world, San Diego (old town and Mission Bay).
  13. 102605
    31
    My car had 4700 miles on it and I just got the first oil change today at the dealer. I should be set there. However, I realized they probably readjusted my tire pressure. I had not been paying attention too closely but I previously set them at 40 psi each.
    What does everyone recommend for this type of trip on my tire pressure?
  14. 102605
    31
    I've got the Google Latitude app on my phone to give a real-time GPS picture on a map to log where I am and where I have been.
    The dealer checked my fluids and did the oil and tire rotation today. I'm ready and set and just need to pack the car now.
  15. fuzzy1
    10,588
    That is a tradeoff between comfort and fuel economy that only you can decide. But I know of no reason why this type of trip calls for a setting different than your ordinary daily driving.
    40-44 works for me, except on the washboard that masquerades as a road to Chaco Canyon. My older car needed some air let out.
  16. 102605
    31
    Does the long drive make any difference to the tire pressure? Should I expect to lose some psi during the route? I suppose I should invest in a good tire pressure gauge. Thanks everyone for the tips.
  17. ksstathead
    ksstathead Active Member
    1,244
    245
    Kansas
    KS speed limit on the turnpike (Wichita to KC) just raised to 75 mph on 7/1/11.
    You should get great fuel economy coming across KS to Wichita. Through the Flint Hills east of Wichita, not so much, but not horrible. Watch the weather in these parts for strong T-storms and try to avoid monsters with potential for large hail and tornados.
    You'll pass within 1/2 mile of my house.
    Enjoy the trip!
  18. Guy in WNY
    Guy in WNY Junior Member
    83
    17
    Western New York
    2018 Prius Prime
    Just east of the Grand Canyon be careful of your speed up to four corners. I got a speeding ticket there in 1987 going down a 7 mile downgrade in my 1987 LeBaron. 107mph! The car didn't go that fast on it's own power, without the hill. It was in Keyenta, IIRC, just past Monument Valley. That's where Hollywood came to shoot many famous Western movies. Stunning!
    Be sure to stop at four corners. It's fun to be in 4 states at the same time! Be sure to get your picture taken doing a "crab" over the monument, with each foot and hand in a different state!
    Looks like you're going the same way I went up through Durango, Silverton, Ouray then east to Denver. It's a beautiful drive.
    31
    Any recommendations for things to do in Kansas west of Wichita? Seems like a pretty quiet stretch. Yeah those storms worry me but hopefully I will have an easy day through Kansas.:car:
  20. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    Run the same pressures you normally run for fuel economy, 42 front 40 rear is popular on.
    When you check your tire pressure, check it in the morning before you have driven more than a mile. If you have your own gauge and check it before you leave your hotel, that's even better.
    Your tire pressure will go up about 1 psi for each 10F temperature increase and also up about 1 psi for each 2,000 feet elevation increase. Fortunately, as elevation increases, average temperature usually drops. I would suggest ignoring those changes, it's a waste of time to adjust your tire pressure every time you change altitude a few thousand feet or the temperature changes 40 degrees, changes you will experience on several days.
    A big advantage to higher than stock tire pressure is that the tires flex less, so heat up less. Tire heat is what damages tires in hot weather, not pressure.
    The hard part is staying awake. And, the previous poster wasn't exaggerating about police radar in Kansas. They should put up microwave radiation warning signs at the Kansas border.:D
