Radio Problem HELP!! No Music :(
Discussion in 'Gen 3 Prius Audio and Electronics' started by mstrkoffee, Jun 22, 2011.
  1. mstrkoffee
    mstrkoffee New Member
    Hollywood, FL
    2010 V with ATP - my radio is not working anymore. By not working I mean none of the music sources produce music through speakers - sat shows channels and text and so does FM radio, and USB. AM/FM/SAT/USB/BT. It worked normally for the first year and then about 1 month ago problems started -it would work for about 5 minutes and then die (seems heat related) - it would also stop working and start woking during that time period based on position (if I moved the car forward an inch I would have a working radio-if I traveled at speed it was garbled faster was better) - The bluetooth audio for telephone calls works perfectly fine. It has been to the dealer twice - they have tried changing the head unit to no avail. They are ordering me a new amplifier. Has anyone ever heard or seen anything like this?
  2. jjlawyer
    jjlawyer Junior Member
    Same thing happening to me. Just started, garbeled sound on all sources then no sound. Volume control not showing on display but rest of display still working. Had in & out faulty connection for 2 days before it just quit. Across the board- sat/am/fm/bt. Driving 5 hour road trip no tunes. Wow.
  3. jjlawyer
    update - car is at dealer and they say it needs new amp
  4. mstrkoffee
    Hollywood, FL
    They replaced my amp and all is well :)
